Interior/Exterior Painted Interior Part I
Old Mar 5, 2006 | 04:49 PM
skitelluride531's Avatar
skitelluride531
I just got finished with the first stage of painting my interior. Will continue working on it on Tuesday.
Tuesday - Re-paint dash panels in black (this time doing a much better job)
Wednesday - Paint Downtubes...this is where I need help. Do you guys think I should paint the downtubes red or black? I am still undecided. Also, do you think I should paint the speedometer trim above the steering wheel?
Picture 1
Picture 2:
Picture 3:
Attached Thumbnails Painted Interior Part I-reddash1.jpg   Painted Interior Part I-reddash2.jpg   Painted Interior Part I-reddash3.jpg
Old Mar 5, 2006 | 04:51 PM
skitelluride531
Picture 4:
Picture 5:
Attached Thumbnails Painted Interior Part I-reddash5.jpg   Painted Interior Part I-reddash4.jpg
Old Mar 5, 2006 | 04:54 PM
mdsbrain's Avatar
mdsbrain
I vote for Black downtubes. I like what your doing!
Old Mar 5, 2006 | 05:03 PM
The MINITOR's Avatar
The MINITOR
Black downtubes, yes paint the speedometer trim to match the other trim.
Old Mar 5, 2006 | 05:19 PM
skitelluride531
I think I will ultimately do black downtubes. Now, if only I could afford some racing seats... :D
Old Mar 5, 2006 | 05:30 PM
Wake|MCS's Avatar
Wake|MCS
Black downtubes and red odometer trim rings... have you considered red odometer gauges?
Old Mar 5, 2006 | 06:07 PM
myzamboni's Avatar
myzamboni
If you go red with the shift boot ring and cup holder rings, then black downtubes. Metallic black would be even more unique (downtubes and dash)
Old Mar 5, 2006 | 06:29 PM
Ministi2005's Avatar
Ministi2005
I agree with the black on the downtubes --- what you're doing is very interesting. Looks great!
Old Mar 6, 2006 | 06:54 AM
62Lincoln's Avatar
62Lincoln
Black downtubes, red trim on the speedo/tach cluster. Have you considered carrying the red trim color to the doors - perhaps the speaker surrounds?
Old Mar 6, 2006 | 08:58 PM
skitelluride531
Finished up a few hours ago. I was able to re-paint the dash black (did not turn out nearly as nice as I wanted it too - more on that later), and painted some of the other parts that I wanted red.
Tommorow or Thursday, I will be finishing up painting the downtubes black, and painting the door panels. I will paint the "Y" part of the door panel red, and the outer trim, black.
1st:
2nd:
3rd:
Attached Thumbnails Painted Interior Part I-day2reddash1.jpg   Painted Interior Part I-day2reddash2.jpg   Painted Interior Part I-day2reddash3.jpg
Old Mar 6, 2006 | 09:00 PM
skitelluride531
More pictures:
4th:
5th:
6th:
Attached Thumbnails Painted Interior Part I-day2reddash4.jpg   Painted Interior Part I-day2reddash5.jpg   Painted Interior Part I-day2reddash6.jpg
Old Mar 6, 2006 | 09:02 PM
bumble's angel's Avatar
bumble's angel
That's hot.
Old Mar 6, 2006 | 09:03 PM
skitelluride531
One more (I know...kind of went crazy with the pictures)
Old Mar 6, 2006 | 09:04 PM
not-so-rednwhitecooper
Originally Posted by bumble's angel
That's hot.
What do ya know, paris with meat in her mouth.
some things never change!
Old Mar 6, 2006 | 09:05 PM
bumble's angel
Always good to see pics.
Old Mar 6, 2006 | 09:08 PM
skitelluride531
That's hot.
Thanks Paris . I never thought eating a burger could be so hot . If only that ad wasn't cut from TV.
Ok, seriously though. So, I repainted the dash black, and I am still not satisfied. It does not have that really glossy look I am looking for such as on the piano black dash, or even like what this guy did: https://www.northamericanmotoring.co...t=painted+dash" .
Anyone have any tips/ideas? Mine still remains dull and flat, no matter what I do.
Old Mar 6, 2006 | 09:09 PM
Motor On's Avatar
Motor On
Nice job !
Any plans for the MFSW and speaker rings?
Old Mar 6, 2006 | 09:11 PM
skitelluride531
Originally Posted by motor on
Nice job !
Thanks!
I might paint the speaker rings black when I paint the door panels. As for the MFSW, I do not think I want to mess with taking apart the steering wheel to get the pieces out, so for right now, that stays how it is :D .
Old Mar 6, 2006 | 09:14 PM
bumble's angel
Did you do any kind of clear coat? That always makes it look better on OverHaulin. I don't know much but that seems to add depth to the paint.
Old Mar 6, 2006 | 09:37 PM
skitelluride531
Yes, I did use clear coat. But, now after reading very detailed instructions on the site I bought the paint from, it says to let everything sit for three days. So I guess that was problem.
Old Mar 7, 2006 | 05:01 AM
fj0's Avatar
fj0
Tell me more, I wanna do this! I didn't think you could remove the ring of the tach? Or did you mask it? I really want to do this. :bow:
Old Mar 7, 2006 | 06:29 AM
skitelluride531
The tach ring comes off really easily. There are two screws behind it that connect it to the steering wheel which you take out (they have torx heads). Then, on the back on the tach, one you remove it an unplug it, there are two more screws with phillips heads. Remove these, and then begin gently prying the pieces away, by first depressing the two white clips on the bottom on the tachometer (you may have to remove the white sticker first). After you get it split into halves, there are maybe 4 or 5 square metal clips that very easily come off on the outer edges to remove the outer tachometer ring. Voila!
Old Mar 7, 2006 | 07:14 AM
fj0's Avatar
fj0
Thanks! Do you know about the speedo? I have the big one. Where did you get the handbrake and shifter boot? Did you spray the stuff yourself? How hard is it?
Old Mar 7, 2006 | 07:25 AM
skitelluride531
Hmm, the speedometer ring, as far as I know, should just pull straight off. I am just assuming this based on the fact that my navigation ring just pulls straight off. I am not sure about this as I do not have the big speedometer.
I got the handbrake and shifter boot from http://www.redlinegoods.com/
They have the best of the best. The leather is very high quality, and smells great .
Yes, I sprayed everything myself. Besides taking 12 hours (including having to wait for stuff to dry), it was fairly easy. I first tried some automotive paint that I got from www.paintscratch.com but it was not bonding correctly to the plastic for some reason, so I went to the hardware store and used some stuff that bonds to plastic. I then did a few coats of clearcoat. I immediately followed it with some rubbing compound, which kind of screwed up my dash panels since I was supposed to wait three days. But, overall, I'd say the process is fairly painless .
NYXF56JCW
Nov 17, 2024 05:06 AM
Bennyboy
Aug 18, 2015 07:28 AM
Dashdog
Aug 10, 2015 06:17 AM
