Interior/Exterior OnStar Antenna?
Old Jan 19, 2006 | 03:54 PM
Snappychip's Avatar
Snappychip
OnStar Antenna?
The new Pontiac G6's OnStar antenna is like 2 inches does anytbody know if it would work for a MINI? I found em for about $13 just a thought before I get a S2000 antenna.
Old Jan 20, 2006 | 09:28 AM
Trip024's Avatar
Trip024
a pic would be good. Where can you buy them?
Old Jan 20, 2006 | 10:34 AM
FUEGO's Avatar
FUEGO
If I'm not mistaken, OnStar is basically an analog cellular system and would be using an antenna designed for the analog cellular frequencies - not AM/FM. Probably not a viable option for a 'stubby' antenna. If you are looking for a really short antenna, check out the Ultrik stubby on MINI Mania. I have one and like the shorter look, but it does reduce FM reception.
Old Jan 20, 2006 | 12:41 PM
mbabischkin's Avatar
mbabischkin
I would advise against it, OnStar doesn't use the same frequency range as an AM/FM antenna. Plus it may not even have the proper connector...
Old Jan 21, 2006 | 08:19 PM
Snappychip's Avatar
Snappychip
Doesn't Work
Yeah I talked to a Pontiac guy he said he doubts it would work but the real problem is the female end on it. I am going to look into a Lexus RX antenna. Someone here mentioned it works and is 4in.
Old Jan 21, 2006 | 08:45 PM
Motor On's Avatar
Motor On
so is S2000
Old Jan 21, 2006 | 08:50 PM
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
OnStar switched to "Digital" a while back 3w cell antenna and combined it with XM antenna so you could use it for XM ONLY.. not am/fm
Old Jan 22, 2006 | 07:33 AM
mbabischkin
But is the XM in the antenna stalk or the antenna base?
Old Jan 23, 2006 | 06:02 AM
TheWrks's Avatar
TheWrks
In the base...
Old Jan 23, 2006 | 06:42 AM
mbabischkin
Then it'd be a royal pain to use it at all, swapping out the antenna base isn't exactly simple on a MINI...
daleCarlsbad's Avatar
daleCarlsbad
I bought one of these from ebay and it works great here in San Diego although your reception may vary depending on your location.
Well made, fast shipping and $13 delivered.
Why spend more?
http://cgi.ebay.com/ebaymotors/2-55-...QQcmdZViewItem
Old Jan 23, 2006 | 08:23 PM
Snappychip's Avatar
Snappychip
Thanks for the advice guys. I ordered up a S2000 antenna today should be here in a few days. We all know it works and it looks good so I went with it.
Old Jan 23, 2006 | 08:49 PM
TheWrks's Avatar
TheWrks
1ZigZag
Oct 6, 2015 07:08 PM
pglgp1292
Oct 5, 2015 06:47 PM
vetsvette
Oct 2, 2015 07:09 PM
simo711
Oct 1, 2015 05:36 AM
Mb460
Sep 14, 2015 05:50 AM
