Interior/Exterior Xenon headlights and fogs
Old Oct 16, 2005 | 05:20 PM
Passat774's Avatar
Passat774
I installed a set of BMW projectors into my front grill in the factory location. After a lot of custom work it's all done.
Yes, they are aimed properly like the factory's. No, I do not run both sets of Xenons at the same time. Yes, I will have Xenon driving lights installed next
Old Oct 19, 2005 | 08:10 PM
Duck360198's Avatar
Duck360198
I am surprised no one has replied to this. HID retrofitting is very difficult and GORGEOUS on the road. I would think more would want to do this mod. I think you did some great work. More pics would definitely be nice. Did you use the same projectors that are in the headlamps and put them in the fog location? Why won't you run both HID's at the same time? What HID driving lights are you going to get?
Again, would love to see more pics, especially if you have pics during the process.
Great work!
Old Oct 20, 2005 | 07:13 PM
Passat774's Avatar
Passat774
Thanks your first post and such great words !!
I did try tonight running both sets and nobody flashed me so I have them aimed low enough not to bother anyone's eyes. They are BMW projectors from a set of Xenon headlights from a 5 series. So they are low beams just very low to the ground.
I did not take any step by step pictures as it took me a month to get it just right..
I plan on running Hella HID driving lights someday..
Old Oct 20, 2005 | 07:20 PM
johndjudd's Avatar
johndjudd
I would love to be able to put xenons in the fog light location. How did you wire up the lights? Do you have any pics of the process and the parts that you had to fab?
Old Oct 20, 2005 | 07:24 PM
Minifiend's Avatar
Minifiend
Temperature?
What temperature (K) are the BMW HID's? What are the Minis? 5000K? 6000K? I always wanted HID's, figured I'd do it after I bought the car, but then I realized not alot of people had successfully done it. Any more information would be great. Thanks.
Old Oct 20, 2005 | 09:24 PM
VoiD's Avatar
VoiD
wow they look great
take some pictures of the beam pattern.
Old Oct 20, 2005 | 10:14 PM
Duck360198's Avatar
Duck360198
I am really REALLY curious to see how you mounted the projectors in that location. You must have something protecting the projector, because if you get dirt and grime up there you're going to be in trouble. 5 series projectors I BELIEVE are Bosch, but not positive. Either way, they have fantastic output and a great blue cutoff.
The temperature on ALL OEM HID projectors are 4300K (I think all OEM projectors), and to be honest with you, 4300K is the WHITEST light you are going to get. In other words, OEM IS BEST!!!!!! 5000K, 6000K are just bulbs and get bluer and bluer to a purplish tint. You're actually making light output worse by doing that (and many would agree).
Is there anyway we can see more up close pics on where you placed the ballast and how you protected the projector?
Again, amazing work. Once you get the Hella's in the headlamps you're going to have an amazing setup....especially if you get Hella Bi-xenon (7 series and others). Good luck, and keep us posted.
HID IS AMAZING!!!!!!!!!!!!!!!!
Old Oct 21, 2005 | 12:15 AM
cooper99's Avatar
cooper99
For those of you S owners with the Xenon lights, what aftermarket high beam headlight bulb do you prefer the most? I want a nice clean look that matches the Xenons... Tomorrow, I am probably going to order some LED parking lights and some fog lights along with the full set of blue interior LEDs from http://autolumination.com. Any pictures of installed aftermarket front lighting? BTW I love the look of the xenon fog lights, but the time and $$$ that those require is out of the question for me.
Old Oct 21, 2005 | 02:49 PM
Passat774's Avatar
Passat774
The bulbs I used are a little higher color tempature than the factory, I think 5500K..
I do have some 8000K bulbs that I could install in the headlights but when I tried them I thought they were way too blue..
Beam pattern looks just like the factory with the _________/---------
Old Jan 30, 2006 | 06:21 PM
Wake|MCS's Avatar
Wake|MCS
I know i'm bringing up an old thread but I just got done installing HIDs on my friends CLK, low beams and fogs and they are sick. I may have a set of '05 projector headlamps available from a friends junk yard, if so I want to put my HIDs in the factory fog light location. I was wondering how you mounted the projector and if you spliced into the factory fog light socket. If you could take up close pics of the projector and how you wired the fogs I would appreciate it. Also, how much did you get the 5 series projectors for? And where? (If you don't mind me asking)
Old Jan 30, 2006 | 06:53 PM
Passat774's Avatar
Passat774
I used a fog light harness that allows remote operation, I did not tap into the factory wires except for power and ground.. I have a small key pad that turns them on and off..
I got the projectors from a body shop that was going to throw them away, so they were pretty cheap. I mounted them by using screws into the plastic that holds the normal fog lights.. Had to do some cutting.. If I took of my bumper you could see how ugly this mod really is !! Also, used zip ties to aim them some
The real issue you are going to run into is the depth or the lack of depth.. There is not much room for fog lights in there !!
Old Jan 31, 2006 | 10:26 AM
bMINIw's Avatar
bMINIw
Tell us about the keypad. What is it and where did you mount it?
Walt
Old Jan 31, 2006 | 10:29 AM
Passat774's Avatar
Passat774
It's just a wireless fog light switch. You can check out suvlights.com I think he sells a harness that would allow for wireless operation..
Just on and off, save a lot of hassel of running the wires thru the car..
Old Jan 31, 2006 | 10:31 AM
Passat774's Avatar
Passat774
Here is the link:
http://www.suvlights.com/product_inf...roducts_id=199
Old Jan 31, 2006 | 11:11 AM
OldRick's Avatar
OldRick
Just a silly question about HID vs. halogen beam colors: do you believe that anyone will ever notice whether your hi-beams and lo-beams are the same color temp?
I have factory HID and 1500 lumen halogens in the high beams, and I assure you that you can't tell any difference in the color when driving, so...
If one assumes that you aren't trying to blind someone, anyone looking at your car will be doing so when the hi-beams are off, and no-one will ever know...
Old May 6, 2007 | 07:16 PM
lunlun's Avatar
lunlun
Hi passat,
My mini has the OEM fog light and i want to get the following the FlowLighting True HID Headlight Kit at http://www.oznium.com/hid
I notice you mentioned " The real issue you are going to run into is the depth or the lack of depth.. There is not much room for fog lights in there !!"
so do you think this is possible?
Old May 7, 2007 | 07:26 AM
Passat774's Avatar
Passat774
your beam pattern will not be very good. You will have a bulb that is too bright for the halogen optics
Last edited by Passat774; May 7, 2007 at 07:50 AM. Reason: RallyMini Caught my mistake :)
Old May 7, 2007 | 07:29 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Originally Posted by Passat774
your beam pattern will be very good. You will have a bulb that is too bright for the halogen optics
i think you meant to say not very good? As far as i know......our fog lights arent projectors stock.....so the lights will just glare a lot
Old May 7, 2007 | 07:50 AM
Passat774's Avatar
Passat774
Thanks, typing to fast !
Old May 10, 2007 | 06:38 PM
lunlun's Avatar
lunlun
But didn't you installed hid fog light urself?!?!!!!!!!!!!!!!!!
Old May 10, 2007 | 06:47 PM
lunlun's Avatar
lunlun
OH, so yours are projectors?
ahh~~
Old May 10, 2007 | 06:56 PM
Rally@StanceDesign
ahh~~
yah he has actual projectors which makes it totally okay (awesome )
ryGuyMCS
Oct 6, 2015 12:04 PM
rbarakat
Oct 3, 2015 11:08 PM
molala
Oct 2, 2015 01:53 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
