Interior/Exterior power point in Euro shelf
Old Mar 25, 2005 | 03:09 PM
Eric_Rowland's Avatar
Eric_Rowland
For those who have installed a power point (cigarette lighter) in their Euro shelf, did you put it on the inside edge (toward center of car) or outside? I'm a bit torn as to which would work better.
Inside - out of the way, so the charger doesn't intrude on shelf space
Outside - easier to reach
I'm leaning towards inside, as it will likely be used for a cell phone, and I would just leave it plugged in.
Any thoughts? Pics?
TIA
Old Mar 25, 2005 | 03:53 PM
Smokey's Avatar
Smokey
I went on the inside. Here is a link to my install
http://forums1.roadfly.org/mini/foru...4757550-1.html
Old Mar 25, 2005 | 04:13 PM
tradiuz's Avatar
tradiuz
MTH Specialist
Where did you get your Euro Parcel Shelf?
Old Mar 25, 2005 | 05:11 PM
Eric_Rowland
Thanks, Smokey - that's exactly what I'm looking for!
tradiuz, I got the parcel shelf from Classic MINI 440-205-6404. It's ~$35 without the incredibly expensive (but very nice) rubber liner, and $65 with (+shipping)
As an alternative, you can get a liner from Uncle_John (NAM member) for $2, but you can easily cut your own from a sheet of rubber shelf liner if you're not lazy like me.
Old Mar 25, 2005 | 07:17 PM
AZMini's Avatar
AZMini
Here's where I mounted mine:
and here's the install writeup:
http://homepage.mac.com/rv6a/MiniParcelShelf.html
Chris
Old Mar 25, 2005 | 07:48 PM
mbabischkin's Avatar
mbabischkin
Mine's on the outside...
Old Mar 25, 2005 | 08:11 PM
jdor1's Avatar
jdor1
How do you hook up the power point
I'm about to install the euro parcel shelf. How do you hook up the power point? Is there some specific instruction for doing it somewhere?
Old Mar 25, 2005 | 08:29 PM
Smokey's Avatar
Smokey
If you'll check out the link I posted above and in that thread I've offered up some alternate fuse locations depending on if you want it powered with switched or unswitched juice. It's the reply called "Couple quick answers" this was on an 2002 build, so just double check that the fuses haven't changed.
Old Mar 25, 2005 | 08:31 PM
Yucca Patrol's Avatar
Yucca Patrol
Thanks for the write-ups. This is my next mod since I carry so many gadgets that I have been compared to the Japanese entry in the Cannonball Run!
Old Mar 26, 2005 | 06:41 AM
jdor1's Avatar
jdor1
I need better eyes
Doh! I overlooked the link you posted. Thanks for the gentle reminder.
Old Mar 26, 2005 | 06:50 AM
Smokey's Avatar
Smokey
No problem jdor1. After about 20 minutes of computer time, my eyes are shot, blood shot
Good luck with the mod, and check out AZmini's link as well. Good stuff in there too.
Old Mar 26, 2005 | 07:06 AM
Uncle_John's Avatar
Uncle_John
Mine's is toward the center. I used a "Victor" brand lighter from Auto Zone that has an amber lighted ring and looks very OEM. It's on a fuse that comes on and off with ignition.
I have a few of the shelf liners left. If you make your own, make your template before you install the shelf, as it's a pain after the shelf is installed.
The shelf is the handiest inexpensive MOD that you can imagine, still don't understand why MINI doesn't put them in north american cars . . .
Old Mar 26, 2005 | 07:38 AM
searocko's Avatar
searocko
Is there enough clearance behind the shelf between the steering column and the little "hump" on the left side of the shelf for another power outlet? I'm picking up my MINI next month so I can't check. I've already added an outlet on the right side but I may need another for all the gadgets I have.
Old Mar 26, 2005 | 09:48 AM
Eric_Rowland
I believe it's a DOT requirement for knee protection. My knees are shot already, so I'm not worried.
AZMini (Chris) Great write-up - it's awesome to have a photo library of mods like this to ease the mind (I fear drilling holes! )
EXCELLENT implementation of the GDO as well. I use Ian's module for that, but if you don't have one, that's very clean and efficient! I've been trying to think of what I can use that cutout for.
FWIW, I'm probably going to hook it up to an always powered source, so the phone can charge w/o the car on - shouldn't drain the battery as it's so small.
Old Mar 26, 2005 | 11:18 AM
AZMini's Avatar
AZMini
Thanks. Talk about drilling holes, I also own a heavily modified Jeep TJ (you can link to it from my main Mini page). I added a snorkle to it. Here I am cutting a huge (~4") hole in the side of it:
Took me 15 minutes to just get up the courage to start cutting.
As far as the power source goes, when I was looking for a switched source, I also found plenty of always on circuits that you could hook in to the same way.
Old Mar 26, 2005 | 01:20 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
This is where I installed mine. There is JUST enough clearance in this area for it. There is not much to the right of the little 'hump', as the bump is there for clearance for the clutch pedal arm. There is more to the pedal arm also towards the right of the bump:
I mounted the socket kinda high so as to not have anything falling into it. There is a lot of room on the right side of the column, and I am probably going to add another socket in this area.
Old Mar 26, 2005 | 02:28 PM
Paul!'s Avatar
Paul!
That's what I did in mine. And I have left my phone and other small doodads plugged in overnight with no ill effects. Strangely enough, the fuse socket for the cigarette lighter is always-on! (And yes, the cig lighter is switched, so I'm assuming that it's switched for some odd reason further down the line.)
-Paul!
Old Mar 26, 2005 | 03:43 PM
mbabischkin
Hey Paul, is your mount for your iPaq powered? And is it plugged into that jack?
Old Mar 26, 2005 | 04:02 PM
searocko's Avatar
searocko
Thanks for the pic. Exactly the info I needed!
Old Mar 26, 2005 | 04:29 PM
Paul!'s Avatar
Paul!
Err, it's kinda odd and a bit non-sensical what I did, but it works for me. (Imagine that! )
The mount itself isn't powered, but I ran the power cable for the IPAQ up between the dash and the A pillar, as you can see below. (It was easy too, I just popped off the side panel to the dash and 'flossed' the power cable in!)
Now a dilemma I had was this: I wanted constant power to the IPAQ, but I couldn't obviously keep the cable hooked up to constant power, or eventually my car battery would die. (Or at least I think so, maybe not, but I don't want to take the chance.) I really didn't want switched power to the IPAQ, otherwise every time I stop the car for a few minutes the IPAQ would turn off. This means that I would have to turn it back on, possibly reboot, and then wait for it to sync to the satellites again, etc. While I could set the IPAQ to never turn off, or turn off after an hour or so, it would only be a matter of time before I forgot to turn off the IPAQ when I was done using it, and due to the drain of the GPS sleeve, the battery would go dead, meaning that I would have to reinstall everything on the IPAQ. So what I needed was constant power, but only when I'm actively using the IPAQ. So, my solution was this:
The power adapter sitting on my shelf is the adapter for the IPAQ. Since my power outlet is constant power, I just plug it in when needed!
(And yes, I could have simply wired an on/off switch into my power adapter, but that would have been too simple! Actually, that's what I want to do eventually.)
-Paul!
theblackfalcon
Oct 11, 2015 09:49 AM
ej
Sep 28, 2015 05:41 AM
Branto
General Mini related Ads
Sep 11, 2015 07:49 AM
Manny_cooper
Sep 10, 2015 11:09 AM
tacticalbacon02
Aug 22, 2015 06:05 PM
