Interior/Exterior Rattle from speaker covers
Old Feb 2, 2005 | 05:57 PM
laxpimp6903's Avatar
laxpimp6903
The rear speaker covers are buzzing. i believe they are loose but do not know how to tightin them or insulate them to solve this problem any ideas for a solution would be great.
Old Feb 2, 2005 | 06:34 PM
ChiliCooperS's Avatar
ChiliCooperS
what stereo do you have?
I have an HK and mine did the same thing, and I know this will go against "pimp" ways but turn the base down and not only you'll get better sound quality they won't do that anymore!
Old Feb 3, 2005 | 05:53 AM
Dees Mini's Avatar
Dees Mini
Mine does the same thing, but on the front passenger side. A friend of ours, Adam, took the panels off of his doors and lined around the speakers with felt. The felt has a sticky side and he just cut it into pieces. It seemed to help!
Dee
Old Feb 3, 2005 | 06:08 AM
mini_this's Avatar
mini_this
same here
About 6 months ago i had the same problem with the passenger side. Took it to the dealer and the put some felt underneath the door panel and it stopped the ratling. I can NOT turn the base down cause you know I like to "PIMP".
Old Feb 3, 2005 | 07:15 AM
laxpimp6903
i agree with the bass you cant turn it down but it dosent even seem as thought they are rattleing against the speaker it is just the grate over the speaker because if i just touch it with a finger the buzzing stops i think that the covers themselves are loose.
Old Feb 3, 2005 | 07:50 AM
rsbell's Avatar
rsbell
Same here.
On my '05 Cabrio the back passenger speaker does this. The dealership told me it was "part of having a convertible". I disagree, if it is caused by the convertible, why just the one speaker?
They are re-checking it next week when I get it serviced and also have them fix the motion sensor on my alarm system. Let me know if you guys hear any other good tips...otherwise I will let you know what they say this time.
Old Feb 4, 2005 | 01:06 PM
jwardell's Avatar
jwardell
Due to my HK rattle, altho it did not fix the problem entirely until I felted the door panel, my dealer's fix was to "tighten" the speaker grille. I can see the plastic rivets were melted. So if you're sure the grill is buzzing, take off the panel and use a soldering iron or something to melt the plastic rivets holding the grill on.
Old Feb 4, 2005 | 04:12 PM
JCampos's Avatar
JCampos
Same problem. I just turned the bass down a tad and adjusted the balance a bit. Mines coming from the front right speaker.
Old Feb 7, 2005 | 09:21 AM
E1Designs's Avatar
E1Designs
Perhaps this should work?
http://www.jwardell.com/mini/hkdoor.html
Old Feb 7, 2005 | 04:46 PM
Darkness's Avatar
Darkness
This has happened to me 3 times. The dealer fixed it everytime no questions asked.
Old Feb 7, 2005 | 06:44 PM
Antranik's Avatar
Antranik
This is probably my one and only complaint about my MINI. The door buzzing from all the bass.
woodstudio
Mar 15, 2020 08:28 AM
alistaircookie
Oct 8, 2015 10:52 AM
Mini Koopa
R55 :: Clubman Talk (2008+)
Sep 8, 2015 02:58 PM
iclancy82
Aug 11, 2015 09:35 AM
OutMotoring
Aug 6, 2015 09:32 AM
