No experience of the size you mention, but after a week I removed the run flats from mine and went with 205/40/18 Michelin Pilot Super Sports and I've never looked back!
Has anyone replaced the tires on the F56 Cooper S? I am looking to replace min with 215/40/17. Wondering if anyone has had experience with this.
I have an F56 Justa without adaptive suspension and with the stock 17x7 Cosmo wheels. I put on a set os Dunlop Dirrezza Star Specs size 215/40 R17. They fit with about 1/8" clearance between tire and front strut. I suspect a taller tire might rub.
Ditto on the Michelin Pilot's; replaced my OEM 15" Continental Summer (just'a Cooper so no run-flats w/spare) with these All Weather's from Tire Rack, super coordination by them with local Tire Kingdom for a great deal!
OEM's still had 5-10,000 miles life left, but was starting on an 8,000 mile cross country.
Problem is the awful oem offset et54..I changed to a et45 and now running 225/45/17 no rubbing it scrubbing and I am lowered on NM Alpha springs.
JD, love your car and what you've done...Do you have spacers behind those wheels? I figured the offset difference from stock at 54 to the wheels at 45, pushing the wheels 9mm closer to the fender edge. Does a 45mm offset wheel get you flush to the fender? I just realized you're also running 225's, that will also make a difference...
I have 215's in both summer and winters. But that sounds like an odd size.
Don't you mean 215/45/17 or 215/40/18" They don't rub but the fronts are close 10mm or 3/8".
... that sounds like an odd size.
215/40-17 has a smaller diameter than either of these sizes or stock 205/45-17 ... and will introduce more wheel gap and more risk of wheel damage from pot holes.
As I stated above. I have been running 215/45/17's on my MCS with DDC without incident. Only close on the front but clear and I'm around lots of snow and ice.
