Interior/Exterior Plasti Dip On Tail Lights?
Old Sep 27, 2013 | 09:46 PM
03.BRG.MCS's Avatar
03.BRG.MCS
What are your opinions on plasti dipping the tail lights? I like that it's removable, and I also like how it isn't as dark as normal VHT tint. Has anyone done this? Are the lights much dimmer during the day or no? For a $5 experiment I think it's worth a shot. thanks for any replies!
Old Sep 27, 2013 | 10:01 PM
papatom360's Avatar
papatom360
If you spray the plasti-dip too thin it is very hard to get off. If you spray it too thick the light bulb may not shine through enough. Good Luck!
Old Sep 27, 2013 | 10:28 PM
03.BRG.MCS's Avatar
03.BRG.MCS
How thick do you think I should go? Will 3 coats come off easy? I was debating 3 coats of the black, then maybe smoke or glossifier on top to thicken it up if needed.
Old Sep 28, 2013 | 06:10 AM
ViperNL's Avatar
ViperNL
Why dont you Just use smoke? That might darken it sufficiently.
Old Sep 28, 2013 | 06:44 AM
03.BRG.MCS's Avatar
03.BRG.MCS
Because the actual tail light smoke isn't removable (well not easily) and the plasti dip smoke isn't black, it's almost like a grey or a matte clear, it's odd.
Old Sep 28, 2013 | 07:18 AM
Da_Ghost's Avatar
Da_Ghost
Yeah, it does look good. They've done it on two different Toyota Tundra with a lift kit at work. It was done by the same company that installed the lift kit, so I have no idea how many coats they've used, but it's pretty thin. Your best bet if you can't find a how-to would be to test it using a piece of plexiglass or something similar until you are pleased with the result.
Old Sep 28, 2013 | 12:53 PM
03.BRG.MCS's Avatar
03.BRG.MCS
I found a few videos on youtube, seems like 3 coats of black will do it. I think I'll get the smoke and do a coat or two of that, then do maybe 2 coats of black just to cover the light. I do like the matte black finish of it, it's different.
Old Sep 30, 2013 | 05:20 AM
yetti96's Avatar
yetti96
Black will be dark and unsafe. Use their smoke product to darken the light is you insist of trying to get rear ended. Then use glossifier over it to shine.
https://www.dipyourcar.com/Plasti-Dip-Smoke-can.html
Old Sep 30, 2013 | 08:41 PM
03.BRG.MCS's Avatar
03.BRG.MCS
But won't that make it grey instead of black? I was thinkin 2 coats of smoke and 2 coats of black. To keep it more transparent but smoked.
Old Oct 1, 2013 | 06:00 AM
yetti96's Avatar
yetti96
It'll make it darker than stock. But yes smoke is more of a grey product.
Old Oct 1, 2013 | 07:49 AM
Saltysalt's Avatar
Saltysalt
i did stripes on my car with plasti dip black, no light is getting through that, i would stick with the smoke
Old Oct 2, 2013 | 06:02 AM
TheBigChill's Avatar
TheBigChill
Buy some Laminex or something, brother. Otherwise, you're just spraying lights with rubber.
Here, try these and let me know how they work...then I'll buy some
http://www.ebay.com/itm/321213046528...84.m1438.l2649
Old Oct 2, 2013 | 01:28 PM
03.BRG.MCS's Avatar
03.BRG.MCS
I completely forgot about tint film, haha. Maybe I'll just go that route. On a side note, does anyone know how to get rid of the glazing the lights get over time? My left one is almost white, which is why I want to tint them instead of buying a new set.
Old Oct 2, 2013 | 01:57 PM
TheBigChill
Mother's Headlight Restoration Kit
Old Oct 2, 2013 | 03:42 PM
Saltysalt's Avatar
Saltysalt
one of the headlight restorations, ATF works as well, but not permanent
youll also need alot of elbow grease
Old Oct 3, 2013 | 06:38 PM
03.BRG.MCS's Avatar
03.BRG.MCS
It's on the tail lights though, the headlight method will work? It just seems like it's on the inside of the light.
Old Oct 3, 2013 | 06:51 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've seen some that were done in the Smoke Plasti Dip that looked good. But I've also heard of people just using the plain black Plasti Dip, but I personally think that would be too dark.
Old Oct 3, 2013 | 09:57 PM
03.BRG.MCS's Avatar
03.BRG.MCS
Yeah, after a video I just watched, the black dip is too dark. I found tint film for $10 I'm gonna try out.
boostedhaze
Jan 2, 2018 07:26 PM
Dec 23, 2015 10:36 AM
smarsha11
Aug 24, 2015 06:03 AM
jr_R52
Aug 21, 2015 01:45 PM
