Interior/Exterior install problems some JCW carbon fiber parts - please help!
Old Jul 19, 2012 | 01:06 PM
mini_stig's Avatar
mini_stig
i recently ordered and received (from sewellparts) the JCW carbon fiber shift ****, JCW CF e-brake handle, JCW alcantara shift boot, and the JCW alcantara e-brake gaiter. i installed them w/ redlinegoods DIY but have found that
1. the e-brake handle is completely loose since it doesn't seem to attach to the actual e-brake like the OEM one does and
2. the shift **** seems to spin very easily which is annoying when i shift
does anyone else have this problem or know of a solution besides super glue or something that is irreversible?
Old Jul 19, 2012 | 01:46 PM
BlueToy's Avatar
BlueToy
Hopefully this will help. When I did mine, the shift **** needs to be pushed all the way down, until it clicks into place. You are seating it in a grove at the bottom, which keeps it from spinning. The e-brake needs to be cemented on the metal part of the handle. I used silicone on mine, letting it dry over night, and it worked great. It takes a little doing to keep the glue inside the CF handle and not all over the hand brake release button. Good luck!
-Steven
Old Jul 19, 2012 | 02:28 PM
ra2fanatic's Avatar
ra2fanatic
Not so sure about the #1 issue there, but with #2, I'm betting that you didn't pound it in there right and give it another pound with your fist and it'll lock into place.
Old Jul 19, 2012 | 10:29 PM
mini_stig's Avatar
mini_stig
yep. that worked. still not sure about #1 though.. also it doesn't even seem like the alcantara gaiter is long enough to cover the base of the e-brake handle when the e-brake is down and NOT engaged..
Old Jul 19, 2012 | 10:41 PM
onefish2's Avatar
onefish2
The CF e-brake handle gets glued on.
Old Jul 20, 2012 | 12:57 AM
BMC_Kid's Avatar
BMC_Kid
-Steven
Use a little masking tape on the end of the metal handle, covering the release button before sliding the carbon fiber part over it. Once you slide over that and the position is good, pull off the masking tape and clean any adhesive that managed to slip by. Let it set overnight and you should be GTG.
Old Jul 30, 2012 | 10:11 AM
cesar418's Avatar
cesar418
pics!
Old Jul 30, 2012 | 08:06 PM
mini_stig's Avatar
mini_stig
Originally Posted by cesar418
pics!
here you go
minimofo
Factory JCW Talk (2009+)
130
Oct 14, 2016 06:14 AM
marendt428
Feb 25, 2016 07:13 AM
O4mcs
Aug 10, 2015 10:22 PM
marendt428
Aug 9, 2015 06:54 PM
OutMotoring
Aug 6, 2015 09:32 AM
