Interior/Exterior Rear Tail lights
Old Mar 15, 2012 | 07:37 PM
MiniMe91's Avatar
MiniMe91
Rear Tail lights
Anyone know of a DIY on how to actually remove the tail lights? Ive found tons on how to smoke them or paint them and what not, but none on the actual process of getting them off the car...
FYI I have a 2003 MCS Hatch
Old Mar 15, 2012 | 08:16 PM
06barney's Avatar
06barney
inside the hatch right an left side small access door in the plastic panel
Old Mar 15, 2012 | 08:21 PM
06barney's Avatar
06barney
P0326 ?
Have a P0326 code book says knock sensor.Any ideas as to why?Thanks guys
Old Mar 15, 2012 | 08:24 PM
MiniMe91's Avatar
MiniMe91
First check if its fully connected,
but they are known to go out so it could be bad, hopefully not, you have to remove the SC to replace :(
Old Mar 16, 2012 | 12:24 AM
Eric_Rowland's Avatar
Eric_Rowland
There is one LOOONG bolt with a 10mm nut on it, about the center of the light, accessed from behind the light through the side cubbies. After that is removed, there are clips top and bottom, but the whole thing just pushes out fairly easily from the back.
Old Aug 23, 2012 | 06:28 PM
Deadwood's Avatar
Deadwood
Does anyone know how to remove the tailights on a 2011 Mini Cooper? Thanks
Old Aug 24, 2012 | 10:18 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'm not entirely sure, but behind the exterior tail light trim piece, there are three collar screws that you must remove. From inside, open the rear hatch and disconnect the bulb holder (should have some tabs or something), freeing up the assembly.
888.280.7799 | 6am - 5pm PST
Old Aug 24, 2012 | 07:50 PM
Deadwood's Avatar
Deadwood
Removing tailights
Thanks so much for the info. That is all I needed to know because I couldn't see any way to remove the light from the inside. Thanks again. Deadwood
Old Dec 25, 2012 | 02:54 PM
mickdayank's Avatar
mickdayank
Yep
Yep pop the trim piece, take off the 3 screws, find out that you got screwed and need a bulb for your back up light. They look absolutely amazing though! 2009 MCS
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
dyeLucky
Aug 7, 2015 07:10 AM
