Interior/Exterior Cravenspeed License Plate Mount
Old Feb 20, 2012 | 01:49 PM
Jeremy Brooks's Avatar
Jeremy Brooks
Here are a couple of shots of the Cravenspeed license plate mount on a Countryman. There are straight on images on their web site; I wanted to show the way the mount makes the license plate stick out. As you can see, it does not follow the line of the bumper, which makes it look very awkward. I'm going to end up using the factory mount on the bumper and get rid of the Cravenspeed mount.
Old Feb 20, 2012 | 03:43 PM
52804x4's Avatar
52804x4
Thanks for the pics! I was really considering this mount due to the fact that it doesn't mount dead center, and cover part of the drive/fog light port!
Old Feb 20, 2012 | 07:10 PM
Rktcyntst's Avatar
Rktcyntst
I've got the go mini go version with an offset bracket. Seems to follow the bumper lines better. Can post photo if requested.
Old Feb 20, 2012 | 07:39 PM
Eclipse11S's Avatar
Eclipse11S
I have the Cravenspeed and had to bend it a little.
Not so bad IMO.
Old Feb 20, 2012 | 07:40 PM
joenzy's Avatar
joenzy
+1 go the go mini go mount and offset bracket. Much better bumper clearance as well.
Old Feb 20, 2012 | 07:57 PM
52804x4's Avatar
52804x4
I'd like to see a pic of that one if the OP doesn't mind the hi-jack!
Old Feb 26, 2012 | 07:45 PM
Rktcyntst's Avatar
Rktcyntst
Sorry for the delay. Might not be the easiest thing to see, but here's some shots.
Attached Thumbnails Cravenspeed License Plate Mount-100_0068sm.jpg   Cravenspeed License Plate Mount-100_0069sm.jpg   Cravenspeed License Plate Mount-100_0070sm.jpg
Old Feb 26, 2012 | 08:44 PM
PatM's Avatar
PatM
It looks like it will rub on your bumper. That can't be good thing!
Old Feb 26, 2012 | 09:19 PM
52804x4's Avatar
52804x4
Thank you sir! I now know which plate holder to go with!!
Old Jun 2, 2012 | 12:41 PM
inh's Avatar
inh
Just noticed this as well. In all positions, it will rub if you try to rotate it. Pretty lame too because the website says this:
By using the tow hook, the plate is also easily removable for track days and shows; it takes only 5 minutes to install the first time and after that the entire plate can be rotated around for quick removal. That means if you ever need the tow hook in an emergency the Platypus will not cause you any trouble.
No way you can do that with the CM without scratching your bumper :( Emailed cravenspeed to see what they say..
Old Jun 2, 2012 | 02:44 PM
Koopah's Avatar
Koopah
I don't know about that picture, but my CravenSpeed LPH didn't even come close to touching the bumper cover! There are a number of adjustment holes in which the stalk mounts. I used the one toward the center of the plate and there was at least an inch or more of clearance.
In the picture, it looks as though the stalk was mounted in one of the leftmost holes instead of toward the center. That would make the difference, I believe...
Old Jun 2, 2012 | 08:36 PM
inh's Avatar
inh
Did you try rotating it out of the towhook? The center hole provides the best clearance while rotating but the nuts will still scratch the bumper.
Old Jun 3, 2012 | 02:01 PM
Koopah's Avatar
Koopah
Can't say that I tired rotating it off the tow hook receiver. However, what's to prevent you from putting some flat washers between the LPH and the stalk to gain some room?
Old Oct 18, 2012 | 08:07 PM
MiniMouse17's Avatar
MiniMouse17
Thanks for the posts guys! Just ordered my Go MINI Go tow hook mount based on the pics here. Would have ordered the platypus otherwise. But hate how it sits right on the bumper.
Check out this thread on a BMW forum:
http://www.zhpmafia.com/forums/showt...t-GoMiniGo.com
It includes a coupon code for the mount.
ptbster
Sep 13, 2015 07:22 AM
OutMotoring
Sep 8, 2015 06:27 AM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
Suspension Products
Sep 3, 2015 09:41 AM
M7Speed
Sep 3, 2015 07:48 AM
