Interior/Exterior LED Fog Light DRL's from OutMotoring
Old Jan 25, 2012 | 05:26 AM
  #26
onefish2's Avatar
onefish2
Ryoma111 - Those last 2 pics of your car are amazing. You have a great setup!!
Old Jan 26, 2012 | 08:55 AM
  #27
Bluenik25's Avatar
Bluenik25
Does not fit my 2011 :(
Old Jan 26, 2012 | 09:47 AM
  #28
gds194's Avatar
gds194
I like them! But not a fit for the 2012... Discrimation! Maybe if I mix up a heap of JB Weld I can get them to fit!!!
Old Jan 26, 2012 | 11:04 AM
  #29
Bluenik25's Avatar
Bluenik25
If you can make them fit let me know. Post a DIY.
Old Jan 29, 2012 | 10:15 AM
  #30
rubberwheels's Avatar
rubberwheels
So if i want this on a justa cooper. The car needs to have the fog lights option already installed. because this is just a quick swap?
Old Jan 30, 2012 | 11:08 PM
  #31
ryoma111's Avatar
ryoma111
Thanks for the positive feedback guys!
rubberwheels- I believe the standard cooper shares the same fog light assembly...so they should be a direct swap.
Old Jan 31, 2012 | 06:34 AM
  #32
sLy201's Avatar
sLy201
these are some super sexy fog lights my man !!! love the mini as well !!
Old Jan 31, 2012 | 06:36 AM
  #33
sLy201's Avatar
sLy201
quick question ... did the driving lamps get in the way of removing the bumper ???
Old Jan 31, 2012 | 11:10 PM
  #34
ryoma111's Avatar
ryoma111
sLy201- the driving lamps must be removed with the upper grill in order to gain access to a couple of bolts and plastic clips to remove bumper. thanks for the posotive feedback!
Old Feb 2, 2012 | 07:49 PM
  #35
wineguy's Avatar
wineguy
Ryoma111 those looked so good on your car, I ordered a set today.
Old Feb 2, 2012 | 09:00 PM
  #36
1bigpea's Avatar
1bigpea
Nice! Some pics (of the install?) would be sweet.
Old Feb 2, 2012 | 10:09 PM
  #37
inh's Avatar
inh
I would LOVE a set of these for the CM, they look great!
Old Feb 6, 2012 | 07:29 PM
  #38
world_famous's Avatar
world_famous
Any updates on 2011/2012 comparability?
Old Feb 9, 2012 | 12:47 PM
  #39
gelinas's Avatar
gelinas
ryoma11--
nice looking mini and cool pics of it.
So colol in fact that outmotoring put them up on their website!
Old Feb 9, 2012 | 01:52 PM
  #40
Jolio's Avatar
Jolio
Old Feb 9, 2012 | 02:21 PM
  #41
Keysersozeh's Avatar
Keysersozeh
I found these last night.
"This is a pair of replacement lamps to replace the fog/sidelight units in the front bumpers of all 2nd gen MINIS, R55 Clubman, R56 Hatch, R57 Cabrio, R58 Coupe & R60 Countryman."
http://www.newministuff.com/new/shop...ctshow&id=1000
Old Feb 9, 2012 | 02:45 PM
  #42
GTECKO's Avatar
GTECKO
Ebay is your friend
DRL
Old Feb 10, 2012 | 11:36 AM
  #43
teamrubixcube's Avatar
teamrubixcube
Just ordered a set from outmotoring. Looking forward to the install and new look.
Old Feb 10, 2012 | 01:12 PM
  #44
malinh2o's Avatar
malinh2o
Those are some nice looking lites
Old Feb 12, 2012 | 01:07 AM
  #45
pocari's Avatar
pocari
Originally Posted by GTECKO
Ebay is your friend
DRL
Are these the same as the ones selling on outmotoring?
Old Feb 12, 2012 | 06:36 AM
  #46
sLy201's Avatar
sLy201
they do not fit our cars .. i emailed the company he bought them from and there is no ETA on when or if they are going to make these for the 11+ models ...
As far as the other guy saying hes going to try and fit them, let us know if it works and how much it cost after the install ...
Super sexy fog lights, just not for 2011 +
Old Feb 12, 2012 | 11:15 AM
  #47
Dr Strangelove's Avatar
Dr Strangelove
These look great. For a novice is it easy to install?
Old Feb 12, 2012 | 12:06 PM
  #48
teamrubixcube
I'm relatively new to modding cars and should be tackling the install within the next month. Seems like all you need to do is remove the front bumper, replace the OEM housings, then plug in stock plugs with the addition of an extra wire to the battery. Shouldn't be too bad....plus it will give my practice removing the bumper for when I eventually get a FMIC
Old Feb 28, 2012 | 05:38 PM
  #49
XRAMX's Avatar
XRAMX
When taking off the bumper how did you access the tork 25 bolt that is under the fender bumber near the side marker light?? I am stuck there. Did you remove the black side bumbers (how)?
Old Feb 28, 2012 | 06:25 PM
  #50
teamrubixcube
Using pliers there should be little clips (fragile) that you can release to remove the first part of the fenders. Take a look at Alta's guide to removing the bumper.
http://www.altaperformance.com/share.../ampeng420.pdf
