Interior/Exterior How to remove R56 hood scoop
Old May 1, 2011 | 06:08 PM
sornstein's Avatar
sornstein
Can anyone provide detail on how to remove the R56 hood scoop?
I want to install a new SS grill in the scoop for better air flow.
Old May 1, 2011 | 10:24 PM
10Zero's Avatar
10Zero
A lot of people will tell you to pull straight up and/or yank...good idea if you want to take a risk of breaking a mounting post. So, if it means anything I'll tell you how I removed mine in under 2 minutes to install a SS scoop insert, with zero damage...
Hopefully you have access to a nylon (plastic) pry bar like the one in the picture below. First thing to do is lift the hood (bonnet), and remove the push in retainer or screw (depending on the year I guess) that is at dead center of the scoop, slightly to the back. Then, using the wide and thin end of the pry bar(arrow), wrap a t-shirt around the end for extra security for scuffing. Insert the pry bar down into the gap, either at the lower left or lower right corner of the scoop. Gently lower the pry bar, causing the corner of the scoop to "pry" up, until you hear a pop...that pop will be the first of several retaining posts popping out of it's retaining clip. Slowly work your way around the scoop in this gap, prying up and detaching the retainer posts til you reach your starting point...pick up the scoop.
I'm assuming all Gen 2 scoop retention is the same, mine was a 2010 I did it on. Here's my black stainless steel scoop insert from MinFini.
Old May 3, 2011 | 09:31 AM
sornstein's Avatar
sornstein
Thanks - worked like a charm! Now I hope the new grille, along with the heat shield I installed, keeps the hood (bonnet) a little cooler.
Old Jun 21, 2011 | 06:45 AM
Paguia's Avatar
Paguia
Is there anyway someone can make a video of this? I'm a visual learner and not trying to screw up on my beautiful MINI. I'm sure you understand haha. Thanks guys
Old Jun 28, 2011 | 02:43 PM
automan21's Avatar
automan21
nice work 10zero and good write up. I too have a '11 and wanted to remove the scoop. Now I can, Thanks.
Old Jun 28, 2011 | 06:35 PM
10Zero's Avatar
10Zero
Thanks, it's so simple it's scary. When that first pin pops (using the nylon pry bar and t-shirt), you're gonna say to yourself..."is that it?" I know I did. Start to removed, right about 3 minutes with zero damage or broken pins..
Old Jun 29, 2011 | 10:36 AM
Paguia's Avatar
Paguia
Time to order my Chrome bonnet scoop and Stainless scoop insert. I'll let you guys know how it goes.
Old Jul 18, 2011 | 04:05 PM
Paguia's Avatar
Paguia
Too easy... How do I add pics?
Bonnet Scoop With Shield
Stainless Intake Scoop Gril
Old Jul 18, 2011 | 04:28 PM
Paguia's Avatar
Paguia
Too Easy, but I broke a couple of clips haha... Thanks a lot for the write-up
My flickr
Old Jul 22, 2011 | 12:10 PM
automan21's Avatar
automan21
No broken clips and it took like 3-4 mins to get off.
dremeled out the grill and put it back in.
Old Jul 22, 2011 | 02:34 PM
Tata Steva's Avatar
Tata Steva
Same here...
Installed JCW CF scoop and dremelled the went holes...
Looks awesome!
Old Aug 8, 2011 | 06:23 PM
karlos's Avatar
karlos
This was super helpful but just to make it clear for anyone trying this, the scoop pops off straight up rather than sliding forward. To me it looked as though it should slide forward and wasted a lot of time without any progress. Maybe my '11 Clubman is different but I unscrewed the little black plastic expander screw. Directly behind (a few inches) that is a gray plastic expander peg- with the hood (bonnet, sorry) up lean in and look back, it's shielded from easy view by a metal shelf. I've read to use needle nose pliers but I couldn't find mine so used a putty knife to pop it up. Once that gray peg is out, I could get my fingers under the back of the scoop and pulled gently but firmly to one side until I heard a loud pop. I just worked my way around and lifted it out. There were 5 pegs to pop in addition to the big one in the back center that I pushed up from the underside. It was dark when I did it so of course have no photos but hopefully this will clear up any residual confusion. I put in the stainless Mini Fini screen and think it looks pretty cool.
Old Oct 25, 2012 | 09:35 AM
MiniAJ's Avatar
MiniAJ
I might have a little problem when I took mine out I broke the little clip under the hood. Is that bad. Without That little clip and anybody just take it out?
Old Oct 21, 2015 | 04:27 PM
thesilkiest's Avatar
thesilkiest
Damnit! late to this thread and all the pics don't work anymore.
Great info though thanks
Old Oct 23, 2015 | 09:36 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have an R56 hood scoop replacement DIY here with pictures that may be useful to you.
888.280.7799 | 6am - 5pm PST
Old Nov 19, 2015 | 09:42 AM
Daniel Wise's Avatar
Daniel Wise
One of my holding clips broke off and now the entire scoop has cracked. I notice I do not have a insulation panel at all! Which could have led to failure of that plastic part.
Does anyone recommend somewhere to purchase an aftermarket scoop+insulation panel + all needed hardware available? Thanks!
Old Nov 19, 2015 | 09:47 AM
PelicanParts.com
Vendor
We have the primed hood scoop HERE with the mounting hardware kit HERE. We have a hood scoop heat shield HERE to protect the hood scoop from turbocharger heat. Or you could go with the M7 Speed Vortex Scoop upgrade. Let me know if you have any questions.
Old Jan 9, 2016 | 12:25 PM
Daniel Wise
Heat Shield installation
So I also just replaced my Hood scoop due to plastic retainer failing and the scoop splitting before I found out what to do. I also ordered that Hood Scoop heat Shield, and although the installation seemed pretty straight forward, it does not look very study. Any thoughts?
kind of hard to see b/c my new scoop is so reflective, but the heat shield just seems to be floating
How I bolted the heat shield under the hood. Look correct?
Old Jan 9, 2016 | 12:41 PM
cactusjk's Avatar
cactusjk
What heat shield is that? Does it fit an R56 and how does it attach?
Old Jan 9, 2016 | 01:19 PM
Daniel Wise
Hood Scoop Heat Shield with Rivets
Part #: 51-48-2-183-986-M26
From Pelican Parts. Just two plastic pop in deals mount it, or so it seems.
It is on this page http://www.pelicanparts.com/cgi-bin/...-2-183-986-M26
Old Jan 14, 2016 | 02:57 PM
NeonLed's Avatar
NeonLed
I have the same heat shield. It slides right above between the bottom of the scoop and the top of the plastic piece that broke on you. Those 2 cut outs in the heat shield, slide and lock it down better so its not so loose.
Old Apr 29, 2017 | 02:59 PM
Katoo's Avatar
Katoo
Here is a video I found on youtube. Covers removal and installation.
boostedhaze
Jan 2, 2018 07:26 PM
marendt428
Feb 25, 2016 07:13 AM
TybeeJim
Aug 19, 2015 02:31 PM
O4mcs
Aug 10, 2015 10:22 PM
