Interior/Exterior Bimmian Gunmetal LIGHTED Shift Knob (pic).
Old Sep 9, 2010 | 05:12 PM
ellcapitan's Avatar
ellcapitan
Bimmian Gunmetal LIGHTED Shift **** (pic).
Thought it would be cool to get this, since I'm unwilling to separate from the cash to go with a Whalen. I bought it from NAM sponsor-vendor Coopersport/Bimmian. Went with the "gunmetal" finish to, sorta, match my R53 anthracite interior...
http://img64.imageshack.us/img64/5283/pbimknob.jpg
...Just thought I'd share a twilight pic. I realize the pic makes it look pink-ish--twilight shots are always difficult--this is due to it being closer and slightly brighter than the surrounding lighting, but trust me the color-match is actually spot on.
Installation was easy... I ran the two thin wires under the shifter boot, and I tapped into one of the illumination wires (and ground) from the nearby seat-heaters/mirrors connector. Only issue was they only supplied one "vampire clip" wire connector. Obviously, two was needed. Good thing I had more. My biggest fear was not being able to get the stock **** off, but I gave it a mighty two-handed yank and it came right off, first try. This **** has decent weight and feels great...but you may not like it at first if you actually prefer a ball-shaped ****; this one is more like a "conventional" teardrop-shaped **** (which, I actually prefer). It comes with four shift pattern caps. A plain 5-speed and a plain 6-speed, and an "///M" 5-speed and an "///M" 6-speed (if you want to pretend you're driving a real M-tuned BMW, LOL).
Old Sep 9, 2010 | 10:25 PM
Professor's Avatar
Professor
Nice! Been looking for one of those.
BlwnAway's Avatar
BlwnAway
Dude your out if gas....LOL
I like it, thanks for the pic. I've been looking for something different in this area.
Old Sep 11, 2010 | 04:09 PM
ellcapitan's Avatar
ellcapitan
Thanks. One thing I noticed after the fact was that now the shifter shaft and the neck of the boot are narrower than the base of the ****. With the stock ****, it didn't matter because it was ball-shaped. But with this one, it's noticeable because you feel the "step" with the bottom of your hand, as you grab the ****. So, I removed the ty-wrap that secures the neck of the boot, and I replaced it with a small piece of rubber hose. It's currently still not thick enough, but it did help...
Old Sep 11, 2010 | 05:08 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Any pics ?
Old Sep 11, 2010 | 05:43 PM
ellcapitan's Avatar
ellcapitan
^^Not of the piece of hose-thing, but there's a link to a pic in the first post, in case you didn't notice it.
Old Sep 11, 2010 | 07:30 PM
Professor's Avatar
Professor
I want daytime pics of the ****.
Old Sep 11, 2010 | 09:54 PM
arek's Avatar
arek
Where does the power source for the LED come from? Battery? Is it a wire you can see, or is it hidden?
Old Sep 11, 2010 | 10:56 PM
Eric_Rowland's Avatar
Eric_Rowland
From the OP
...I ran the two thin wires under the shifter boot, and I tapped into one of the illumination wires (and ground) from the nearby seat-heaters/mirrors connector...
Old Sep 12, 2010 | 05:28 AM
ellcapitan's Avatar
ellcapitan
Here ya go...
http://img694.imageshack.us/img694/41/p001b2.jpg
http://img710.imageshack.us/img710/1724/p001b3.jpg
http://img837.imageshack.us/img837/1708/p001b4.jpg
So far so good. The **** doesn't get loose or vibrate, and since it's more-or-less a solid chunk of metal, it has a kinda direct mechanical feel to it that doesn't seem to be there with the stock ball. One more thing I forgot to mention: I wrapped one layer of electrical tape around the shaft, under the ****, aiming to make sure it never vibrates.
Old Sep 12, 2010 | 08:03 AM
Professor's Avatar
Professor
Looks a little like the UUC *****. I like it.
Old Sep 12, 2010 | 10:34 AM
ellcapitan's Avatar
ellcapitan
I love this ****! (The more I drive with it, the more I realize this...) It makes the whole shifter mechanism feel totally different...more precise and direct, but with the illusion of lighter effort--this is due to the natural change in how you grip the **** due to it's shape. You tend to grip it lower--from the side as opposed to palm-down from the top, on the stock ball--so, it also makes the shift-throws feel slightly shorter.
I bought this thing mainly for the wowee-factor of the fact that it was LED-illuminated, but that now seems secondary to the fact that it's actually just a really good **** in own right.
Old Sep 13, 2010 | 04:48 AM
NightFlyR's Avatar
NightFlyR
Looks like a good match
Old Dec 7, 2012 | 05:02 AM
Villa8525's Avatar
Villa8525
Did you use the oem boot or thats the alcantara?
Old Dec 7, 2012 | 06:11 AM
submitaweasel's Avatar
submitaweasel
Lucky you...mine would not come off. At all. I even tried a wrench around the base and whacked that with a hammer for about an hour. All I managed to do was destroy the stock ****. Ended up having to use a hacksaw. Gladly I had a new shift lever waiting to go in...you have a link to where you bought your ****?
Old Dec 16, 2012 | 12:41 PM
OhBe1's Avatar
OhBe1
Coopersport.com, where, oddly, they do not list MINI's as fitting, even when emailed. They asked me for the shaft diameter...
theblackfalcon
Oct 11, 2015 09:49 AM
dyeLucky
Sep 11, 2015 10:41 AM
Aug 19, 2015 12:51 PM
dyeLucky
Aug 7, 2015 07:10 AM
