Interior/Exterior Want to install 4 Hella, but need major help
Old Aug 30, 2010 | 07:39 PM
SheldynCooper's Avatar
SheldynCooper
I just meet a guy who did it to his VW R32 and now really want them on my mini. All the brackets I have seen so far put the lights way higher than I want. I want them infront of the lower grill. I have seen a couple people here who have done this but they dont show how they did it and most are for the first gen. If I could get pictures on how to remove what I need to remove and where to attach the mounts and where can I get the mounts or should I make one?
I went to check out the mount at outmotoring.com and there picture of at the top of the page is where I want the lights yet their mount puts the lights where my license plate is.
All useful help is greatly appritiated
Attached Thumbnails Want to install 4 Hella, but need major help-blackie.jpg
File Type: pdf
Old Aug 30, 2010 | 11:25 PM
BensMini's Avatar
BensMini
I saw an ad in Marketplace for a 4 Hella set up that were mounted low. He said his bracket was from Alta. I think it was in the parts for gen 1 you might look there on page 2 or 3. I think they were sold but you could PM him for info.
Old Aug 30, 2010 | 11:44 PM
R35P3CT DA M1N1's Avatar
R35P3CT DA M1N1
Outmotoring sells some adjustable mounts that go on the lower grill.
edit* nevermind, those are just on 1st gen. you might be able to fabricate them to work tho.
Old Aug 31, 2010 | 05:19 AM
mastawyrm's Avatar
mastawyrm
I have 4 on the top grill, I first tried some angle brackets(like for adding stability to corner joints on wood frames) but they ended up being wobbly. I used some large washers for support against the grill slats which are plenty strong enough for this purpose. I have since replaced the brackets with some straight metal brackets on the backside with the bolt going through the slat and into the Hella bracket. This way is much more stable. I'll try to find pictures
EDIT: this is how it looks now
Old Aug 31, 2010 | 05:26 AM
jonnieoh's Avatar
jonnieoh
Yes, Alta used to sell a 4-light kit for the lower grille for the 1st gen MINIs (R53s and R50s). I visited their web site, and it doesn't seem to be offered any more. I don't know if that bar would work on an R56 or not, with the way it mounts to the bumper.
I have the Alta light bar, but I'm only using the two outer lights, because I have a license plate in the front, where the inner two lights would be. I love the lights, but they're IPFs, not Hellas.
Maybe try eBay?
Old Aug 31, 2010 | 06:51 AM
callahan00's Avatar
callahan00
The lower mount will block your intercooler. Not a recommended situation
Old Aug 31, 2010 | 07:00 AM
iwashmycar's Avatar
iwashmycar
Yup there is a reason nobody wants them down there... Well, we do, but not smart
Old Aug 31, 2010 | 03:23 PM
Capt_bj's Avatar
Capt_bj
you could use the outmotoring mounts and then hang the lights rather than mount them on the top of the mount.... this would put the lights over the bumper ... you might want some fancy hardware to clean up the mounting points since they would be so visible .. grind off and paint or pick up chrome stuff.
But yes, the intercooler moved from GEN1 to GEN2 . . .
Old Sep 1, 2010 | 01:28 PM
jbewley's Avatar
jbewley
Vip has a very nice four light bar. There is a picture of mine in my gallery.
Jim
Old Sep 1, 2010 | 02:01 PM
Capt_bj's Avatar
Capt_bj
Jim
nice - but he wants 'em below the bumper . . . .
Old Sep 1, 2010 | 02:16 PM
jbewley's Avatar
jbewley
Thank you.
I missed the part about wanting them below the bumper.
Jim
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
