Interior/Exterior Mini Cooper S Overlay Grill Opinions
Old Feb 4, 2010 | 06:55 AM
stt816's Avatar
stt816
do you think this would look dumb? Its just an overlay grill. I like it because its easy to install and i wouldnt have to pay anyone, but i dont know if it would look good. what do you think?
http://www.btgmotoring.com/Merchant2..._Code=AT971086
Old Feb 4, 2010 | 07:25 AM
Bigshot's Avatar
Bigshot
Looks like a replacement and not an overlay to me......but it does look nice.
Old Feb 4, 2010 | 07:29 AM
edisonian's Avatar
edisonian
I like it cause it has that industrial air conditioner grill look.
Old Feb 4, 2010 | 07:49 AM
stt816's Avatar
stt816
it says in the description "Easy to install with applied 3M tape!" and it says "Grill Cover" so im guessing you just put it over the existing grill. So you think it would look good?
Old Feb 4, 2010 | 08:38 AM
Bigshot's Avatar
Bigshot
I don't think it would be something that you just stick over the existing grill.....no room to do it.
The OEM grill is easy to remove, the middle section on the bumper is harder as you have to remove the bumper to get to the tabs.
Old Feb 4, 2010 | 09:01 AM
N2MINI's Avatar
N2MINI
IF, it was a true over lay, wouldn't you be able to see the old grille thru it???
bout looks like an aero grille, and sometimes you can find one in the market place cheaper then that..
Old Feb 4, 2010 | 03:26 PM
Bigshot's Avatar
Bigshot
Here is another sorce for some OEM grills......
http://www.outmotoring.com/mini-coop...rsion_kit.html
Good price and you are supporting a MINI vendor.
Old Feb 4, 2010 | 05:17 PM
Mello_Yellow's Avatar
Mello_Yellow
Not to crap on a thread, but what "modifications" need to be done to the bumper for the lower grill? His site isn't exactly clear....
I love my yellow grill, but I flirty with the idea of putting the honeycomb ones on. If it's an easy job (I can take off the bumper.. that I know you have to do) then I'd seriously consider purchasing these for my Mini.
Old Feb 4, 2010 | 05:50 PM
stt816's Avatar
stt816
would it look good with just the top aero grill and not the middle or bottom done? does any one have a picture of it...i dont want to take off my bumper
Old Feb 4, 2010 | 06:53 PM
Fatherdeth's Avatar
Fatherdeth
I saw something similar on Ebay one time. It said you place this over the existing grill with 3M tape. You could see the slats from the stock grill behind it. I'm thinking this is the same thing, except the picture is really bad. Look real closely at the lower grill, and you can see a chrome slat. If it is what it says it is, it's an easy remedy to get rid of a chrome grill. I'd expect some fit and finish problems though.
Old Feb 4, 2010 | 07:58 PM
JohnnyVillan's Avatar
JohnnyVillan
Its a pretty involved job to do the middle grill in the stock non-aero bumper if you arent a DIY kind of person. It requires cutting the grill and the bumper.
Old Feb 4, 2010 | 08:47 PM
MrCooperS's Avatar
MrCooperS
Moderator
The top grill is just a straight swap. The non aero grill is a different design, so the link he provided, does not look like a 'overlay' because you'd be able to see the lines from the non aero grill.
The middle grill requires a bit more work, about 6 hours if your just a regular average Joe like me. Basically the Aero grill was designed for the Aero Kit front bumper, which has a deeper indention (pocket). So if you tried to just pop the mid aero grill into the non aero bumper, it would protrude and stick out. Also the holes on the bumper would not match to the aero grill. So you have to do 2 things. Dremel the aero grill and make it thinner, and then you have to physically cut holes into the bumper for the new clips. Another thing is, the non aero bumper has this plastic piece that is attached to the bumper under neath the non aero grill. In order for the aero grill to sit flush, you'd have to trim that off as well. PM me for more info. if you want to know more.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
