Interior/Exterior one touch sunroof mod
Old Feb 1, 2010 | 02:04 AM
oh mini me's Avatar
oh mini me
Hi folks, as anybody made this mod yet?
If so, how difficult was it and where did you acquire the unit.
Thanks,Johnny
Old Feb 1, 2010 | 04:55 AM
Poppa Bear's Avatar
Poppa Bear
Check this out:
https://www.northamericanmotoring.co...-motoring.html
I'm about to do this myself, after I figure out what has changed between the 09 and 10 models.
Cheers!!
Old Feb 1, 2010 | 05:14 AM
oh mini me's Avatar
oh mini me
Originally Posted by Poppa Bear
Check this out:
Cheers!!
Hi, thanks for the link, I found a thread in the "how to" site, shows you removal of the overhead module, the rest should be fairly easy.
Thanks again, Johnny
Old Feb 6, 2010 | 04:20 PM
oh mini me's Avatar
oh mini me
sunroof
Hi Poppa bear, please let me know how you make out w/ that install.
I purchased the unit from K-P and it would be awesome if you could give me any pointers.
Best wishes, Johnny
Old Feb 7, 2010 | 12:17 AM
Poppa Bear's Avatar
Poppa Bear
Yeah, I'll get some snaps, too. On the couple of mods I've done so far, Mini-Fini Arm Rest and the AutoSport Plus, the year model difference has been a bit of bother. I'm looking at using Posi-Tap connectors instead of soldering up in the overhead, so that'll be a change in the instructions.
Cheers!!
Old Feb 7, 2010 | 03:10 AM
oh mini me's Avatar
oh mini me
Hi, I like the Power Tap idea, my thoughts were....solder from above...bad idea....
Old Feb 24, 2010 | 11:22 PM
Poppa Bear's Avatar
Poppa Bear
Install went very smoothly, especially with the Posi-Tap connectors. Though I had to provide my own double-sided tape to mount the module onto the car (to keep it from sliding in the curves!!), there was plenty of room above the headliner for all the wires and connectors. Now, if I can only figure out the timing rate for actuation...
Cheers!!
Old Feb 25, 2010 | 03:49 AM
oh mini me's Avatar
oh mini me
one touch
Cheers!!
Hi Poppa Bear, thanks for the update, glad it went smoothly!
Question for you, was the wiring diagram that came with the unit correct?
Timing rate? I thought it was 2 touch express open, 1 touch to stop.
Johnny
Old Feb 25, 2010 | 04:14 AM
Poppa Bear's Avatar
Poppa Bear
I actually posted to the KP forum about the wiring diagram as it did not reflect the actual wiring order on the module. Kevin replied that the wiring sequence for the module was irrelevant and the install went quite well. As for the timing rate, I had the AutoUp circuit for my R53 and I'm used to it's timing. Seems that Ian's circuit expected the double click in less that 3/4 of a second while the KP mod wants them in no less than 3/4 second. Just me having to figure this out. Guess I should watch the training film a couple of more times!!
Cheers!!
Old Feb 25, 2010 | 05:23 AM
oh mini me's Avatar
oh mini me
Thanks Poppa......................
Old Feb 25, 2010 | 05:25 AM
oh mini me's Avatar
oh mini me
Poppa are you going to the Dragon this year?
I'm hoping to go, looks like a great venue.
Johnny
Old Feb 25, 2010 | 09:00 AM
Poppa Bear's Avatar
Poppa Bear
As my son is up in Boone, NC, I'll be on the Dragon for sure but it'll be late in the year after waiting for my car to get shipped from Europe!
Cheers!!
Old Feb 25, 2010 | 09:40 AM
scottmd's Avatar
scottmd
Cheers!!
The Posi-Tap is a great idea...can you tell me which part number Posi-Taps you used for this installation?
Old Feb 25, 2010 | 12:50 PM
oh mini me's Avatar
oh mini me
POSI-TAPS
Cheers!!
Hi Poppa, I just bought them @ Napa Auto Parts, question, did you seal the tops of the connecters to make them water tight?
Like using black gasket sealer............
Johnny
part # 785965 posi-tap
Old Feb 25, 2010 | 08:26 PM
Poppa Bear's Avatar
Poppa Bear
Because I'm overseas and really like these connectors, I bought a couple of assortments (ZRTL-PTA-24, ZRTL-PTL1026-30, and ZRTL-604-30) direct from their site. Their website mailing forms didn't have APO but they sent them anyways. Another example of excellent customer service!!
Johnny
I didn't even consider doing this as the connections are immediately on the other side of the headliner. If there's water in there, I'll not be worrying about opening the sunroof!!
I hope this helps ya'll do this mod and Good Luck!
Cheers!!
Old Feb 26, 2010 | 03:42 AM
oh mini me's Avatar
oh mini me
posi-taps
Cheers!!
Hi, the idea to seal the tops came to me due to possible condensation issues, which most likely is overkill..........
Thanks for all your help, Johnny
patsum
26
May 29, 2021 06:29 PM
hockeydad51
Oct 9, 2015 01:51 PM
sempaipaul
Sep 14, 2015 09:16 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
Accessory Products
Sep 10, 2015 11:38 AM
