Interior/Exterior DTM-style or Rally shifter?
Old Apr 20, 2009 | 11:09 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
So, has anyone found a nice DTM, or rally, style shifter for the Mini? I mean one with a short throw, that is tall and vertical? I have the Alta SS, and it's stubby, bent and really moves quite a bit given how short it is.
I am interested in working with someone to actually design and proto one of these if there isn't one out there. Any takers?
Old Apr 20, 2009 | 11:11 AM
gnatster's Avatar
gnatster
Quaife makes a sequential box for the MINI...
1 small problem with it...you can buy a good used MINI for the cost of the box.
Old Apr 20, 2009 | 11:19 AM
DrPhilGandini
I was thinking that would be one option...but maybe short of that, we could have a nice taller, straight lever with about 4" between 1 and 2 and 1 and 5? Now that shouldn't be too hard, should it?
Old Apr 20, 2009 | 11:37 AM
broadwayline's Avatar
broadwayline
I would love a tall shifter for the MINI, something similar to this for Honda's
http://www.fastlineperformance.com/shifter.htm
I really do not like hunching / reaching down when on the track with the driver layout of the car, makes the hands much too far from the wheel.
checkmate2006's Avatar
checkmate2006
I am up for something like this. I use solidworks alot
Old Apr 20, 2009 | 11:46 AM
BlimeyCabrio's Avatar
BlimeyCabrio
That FLP shifter ROCKS.
Old Apr 20, 2009 | 12:13 PM
DrPhilGandini
Yeh, that FLP is the exact item I was thinking about. I emailed them--maybe they will do a custom unit for the mini?
Old Apr 20, 2009 | 12:15 PM
broadwayline
That would be excellent, I would love a setup like that, and would purchase one if someone decided to make one without a doubt.
Old Apr 20, 2009 | 12:29 PM
JPMM's Avatar
JPMM
need alot of jack
http://cms.mini-clubsport.com/index....d=31&Itemid=79
OR
Old Apr 20, 2009 | 12:31 PM
JPMM's Avatar
JPMM
https://www.northamericanmotoring.co...r-shifter.html
Old Apr 20, 2009 | 01:08 PM
checkmate2006
The first pic which looks like the setup for the R53 is pretty sweet and From the looks of it being elevated above the factory mounting points it has to be a flick compared to a "throw"
Old Apr 20, 2009 | 01:31 PM
JPMM's Avatar
JPMM
a flick or a snick
Old Apr 20, 2009 | 02:20 PM
DrPhilGandini
Well, these are perfect examples of what I was thinking about--especially as I have quickly realized we must raise the pivot point--to get it out of the way of the exhaust, and to provide much more room to get the leverage required, and the **** close to the steering wheel.
Oh well...
Old Apr 20, 2009 | 02:57 PM
JPMM's Avatar
JPMM
I'm not quite getting what the vertical cables are doing. Must be little levers below transferring the vertical movements to the car's horizontal cables
Oh well...
Old Apr 20, 2009 | 03:24 PM
DrPhilGandini
The realoem picture is not very helpful, but the vertical rod you see shifts the gear plane (from 1,2 to 3,4 and then 5,6, and of course, R). It's a simple system: one cable shifts gears, say from 1 to 2, the other cable, engaged by moving the plane of the shift lever to the left or the right, determines which two gears you are selecting from. These racing shifters execute the same movements that the OEM shifter does, hence the need for two mechanisms--for and aft, and plane-shift. They are not sequential shifters, but maintain the H pattern, albeit with shorter travel, probably.
Old Apr 21, 2009 | 12:32 PM
DrPhilGandini
btw, FLP got back to me, and seem interested in the idea of making their shifter for the Mini. I got back to them, and will report on anything worth reporting on.
Old Apr 21, 2009 | 12:45 PM
maxmini's Avatar
maxmini
This is the optional shift stick to the Sequential Shifter System. The stick itself is not too pricey but the other items needed to make it work do add up a bit
Randy
M7 Tuning
Old Apr 21, 2009 | 12:46 PM
broadwayline
Amazing! Keep us updated!
Old Apr 21, 2009 | 01:26 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Randy,
Anyway that you guys over there at m7 would be interested in making that work with out the SSS?
Old Apr 21, 2009 | 01:32 PM
Jahmills's Avatar
Jahmills
That is one sexy piece of kit.
Old Apr 21, 2009 | 04:39 PM
maxmini's Avatar
maxmini
Originally Posted by ChrisMCS04
Randy,
We had a prototype billet cage system done up at one point but time and money kept it from seeing the light of day. I am not sure where it may have ended up but I can look into it.
Randy
M7 Tuning
Old Apr 21, 2009 | 09:25 PM
JPMM's Avatar
JPMM
don't think I could do Sequential
So you had a tall short shift setup like the Germans? ( pivot above the normal pivot linked together boxed in)
Randy
M7 Tuning
Old Apr 21, 2009 | 11:45 PM
maxmini's Avatar
maxmini
That was the general idea . Raise the pivot point and get the shift **** up close to the wheel " rally " style . I had nicknamed it the " tall short shifter ". I do not remember how far we got with the system as it was a few years ago and priorities tend to change towards the more pressing projects.
Randy
M7 tuning
Old Apr 22, 2009 | 12:18 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Thanks Randy, keep us posted.
Old Apr 22, 2009 | 02:14 PM
DrPhilGandini
I'd guess the project is dead, so you'll be waiting a long time for a post...
Time for someone else to pick up the mantle.
