Interior/Exterior Need help removing rear hatch interior
Old Jan 16, 2009 | 03:42 PM
ocso1606's Avatar
ocso1606
I have a 2009 cooper s. I need to remove the interior panel and the inside of the boot/hatch. I have tried and cant get it off. Anybody out there can post pics or anyother help...I have a bent that needs to be taken out. THANKS
Old Jan 16, 2009 | 07:37 PM
PoktRokt's Avatar
PoktRokt
Nice Work! I placed a post on this same idea about a month ago. I used a old back pack strap. The only difference, I drilled a hole in the end that hooks on the head rest post so it the head rest sits down flatter than your loop. you can look it up here https://www.northamericanmotoring.co...imple-mod.html
Old Jan 17, 2009 | 06:15 AM
BostonR56S's Avatar
BostonR56S
did I miss something? Or are these two posts COMPLETELY unrelated?? lol
Old Jan 17, 2009 | 08:32 AM
ocso1606's Avatar
ocso1606
THAT DOES NOT HELP ME!
Old Jan 17, 2009 | 08:36 AM
PoktRokt's Avatar
PoktRokt
oops, sorry bout that...somehow I posted on the wrong thread. and sorry but can't help you either.
Old Jan 17, 2009 | 09:35 AM
Fatman's Avatar
Fatman
SH** I had mine off last night should of snapped some pics. I did a rear seat delete and took out the wiper as well.
Matthew
Old Jan 17, 2009 | 09:39 AM
djam43's Avatar
djam43
There was a post in the past that described the method of removing the rear hatch door. If I remember right it involved unpopping a BUNCH of the fasteners around the perimiter of the frame. I would use a plastic tool available from Harbour Freight for a few dollars for the set. If you break any of the fasteners they are available cheap from the dealers. See www.realoem.com for the part number and an exploded view of the assembly.
Old Jan 17, 2009 | 12:24 PM
BostonR56S's Avatar
BostonR56S
Matthew
sweet! did you buy a kit or just make the filler yourself? if the kit, does it involve much more than just that cover? some fasteners maybe? I'd like to make the 'false floor' people are doing in the audio threads for the subs and make that whole back area flat instead of having that dip there, that'd make it nice and clean! nice job though!
Old Jan 17, 2009 | 06:07 PM
Fatman's Avatar
Fatman
I made it my self. Took around 100lbs out of the car. the panel itself weighs maybe 10 lbs.
Here is another pic.
Old Jan 18, 2009 | 02:58 PM
BostonR56S's Avatar
BostonR56S
NICE! looks nice and clean! any write up for it coming? I'd love to have that on file for when I decide to tackle it. 100lbs though? thought it saved like 35 or somethin said outmotoring- though im probably completely wrong and the kit is like 35lbs. anyhow, nice job once again.
Old Jan 18, 2009 | 03:07 PM
MiniPOLACK's Avatar
MiniPOLACK
lol 100lbs???? nowhere near... i did the same, shaved about 50lbs the most....speaking of weight savings, your removing a rear wiper, but you have the arm storage compartment ???
Old Jan 18, 2009 | 04:48 PM
Fatman's Avatar
Fatman
I will get a scale to settle the weight issue Im sure its around 100lbs . I use the arm rest compartment for my blackberry/smokes.
Old Jan 18, 2009 | 06:21 PM
misslindsey's Avatar
misslindsey
Dent Guy just popped the plastic off the inside of my hatch yesterday. It has quite a few plastic clips around the outside of the plastic part.
You have a big dent and you need to take the whole thing off or you just need access to it? I somehow had a pretty good dent above the handle and he just needed enough room to get his little pokey things in there.
Old Jan 27, 2009 | 06:07 AM
Red Bull's Avatar
Red Bull
Its easy....just pulls off, took mine off when I did the rear wiper delete....feels like it wont come off but you have to pull pretty hard.
Toolman
Jan 20, 2016 06:50 AM
Mini'mon
Aug 26, 2015 01:02 PM
xraycat
Aug 12, 2015 02:36 PM
