Interior/Exterior left foot rest
Old Sep 14, 2002 | 07:43 AM
micky's Avatar
micky
Does anyone have any ideas on how to extend the left foot rest?
Kurt
Old Sep 14, 2002 | 08:36 AM
Solo's Avatar
Solo
:evil: :evil: :evil:
put your seat forwards
or. buy CVT
Sorry, just a joke !!!
Old Sep 14, 2002 | 11:59 AM
DavidG's Avatar
DavidG
Not sure what you mean by "extend". If you mean "move the rest closer towards the driver", you might try one of the aluminum "dead pedals" sold by Momo, Sparco, and others; and install a "spacer" plate behind the dead pedal. You may be able to move the surface of the foot rest towards you by an inch or so. Always have to be careful when drilling holes into the sheet metal, though!
If you would like URL's to possible sites, drop me a line.
Old Dec 17, 2002 | 11:43 PM
DVLMINI's Avatar
DVLMINI
I 'm looking for a way to do this, too as the foot rest in my Passat was of a much more natural height to get to from the clutch pedal. Maybe someone should make an extender...
Old Dec 18, 2002 | 12:08 AM
Calvin77's Avatar
Calvin77
I wish someone made an aftermarket extender for the dead pedal. The stock one is absolutely useless.
Old Dec 18, 2002 | 12:27 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
A bar of soap and some duct tape.
Old Dec 18, 2002 | 01:10 AM
MINIclo's Avatar
MINIclo
7th Gear Gal
>>A bar of soap and some duct tape. <<
sndwave,
would that be your favorite: soap-on-a-rope? tee hee!
Old Dec 18, 2002 | 01:49 AM
sndwave's Avatar
sndwave
Don't leave home without it.
Old Dec 18, 2002 | 04:54 AM
jwhcars's Avatar
jwhcars
YOU CAN FIX ANYTHING WITH DUCT TAPE
Old Dec 18, 2002 | 10:05 AM
sirron's Avatar
sirron
You can pry off the existing left footrest, then using any thick sheet of rubber, ie: a garage floor mat, cut one or two layers, then bolt or screw the rubber to the footrest. I extended mine because it was farther away from the driver (me) than the accelerator pedal, making the MINI uncomfortable to drive. I added about an inch in thickness. Moving the seat is useless! This is probably only a problem in a CVT car.
_________________
LTL YELO
Old Dec 18, 2002 | 10:15 AM
sirron's Avatar
sirron
>>or. buy CVT
The footrest distance is definitely a problem in the CVT MINI! This is not a joke, unless you are lucky enough to have a longer left leg. Merry Christ Mass.
Old Dec 18, 2002 | 07:16 PM
yellowminijim's Avatar
yellowminijim
Great tips on the left foot rest. I've had a similar problem and have a CVT.
yellowminijim
Old Dec 19, 2002 | 03:33 PM
Impish's Avatar
Impish
I'm glad I'm not the only one who finds the "dead pedal" so low that it's useless and feels wrong. It's really just a fancy spot on the floor. I've considered making an extension in fiberglass or carbon/fiber but the fusebox door is in the way and I didn't want to peel up the oval that is there w/out knowing if it would be damaged.
Has anyone lifted off the factory dead pedal?
How much interest would there be in an extension that slipped over the black part of the factory dead pedal and attached to it on the lower side and to the kick panel up higer and then had the oval indentation up top for the factory metal/rubber bit?
Keep in mind, installation would invariably require some holes to be driilled in the kick panel, and maybe the side of the factory dead pedal. I'd probably want to use riv-nuts because they're stronger than the plastic blind fasteners yet would still allow repeated removal with a simple tool whenever access to the fuse box is needed. That said, you might need to spend $20 for a riv-nut tool from Harbor Frieght to complete the install.
Too much trouble?
Better ideas?
Old Dec 19, 2002 | 03:38 PM
2minis's Avatar
2minis
An Elton John shoe from the 70s......
The left of course.
Old Dec 19, 2002 | 09:21 PM
sirron's Avatar
sirron
>>>Has anyone lifted off the factory dead pedal? >>>
Check above.
Casrio
Apr 20, 2021 01:52 AM
Camden90240
Sep 28, 2020 12:09 PM
QuickCooper
Dec 29, 2016 06:46 PM
Joeygonz
Oct 2, 2015 11:24 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
