Interior/Exterior How do you remove the ring around the shifter boot?
Old Dec 5, 2008 | 12:27 PM
davisflyer's Avatar
davisflyer
I've got a rattle coming from under the shift boot and would like to pull it up and take a look. How do I take it off?
Old Dec 5, 2008 | 12:34 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Just grab on the inside of the ring with two fingers on each side and pull straight up.
Old Dec 5, 2008 | 01:05 PM
pauliekeys's Avatar
pauliekeys
I use my nails to get under the lip and then pry slowly up on one side and then the next ! The prongs that line the ring in place are very delicate and could easily be broken if you pull or twist it out to hard.
Old Dec 5, 2008 | 03:09 PM
xnotfunkylex's Avatar
xnotfunkylex
+1 straight up. Angles are a bad idea.
Old Dec 5, 2008 | 05:02 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Just for completeness, there are 4 prongs that form a square pointing toward the front of the car, so they are at 45, 135, 225 and 315 degrees.
They differ in diameter, so the ring only goes on one way. Some of the prongs are thin...
Old Dec 11, 2008 | 09:14 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
PS: make sure all pins line up before re-installing ! You will know what I am talking about after you remove it....
Old Dec 12, 2008 | 01:17 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I'll just say this now, if the rattle was not caused by this ring before you removed it, after you put it back you might have a new rattle to contend with.
Old Dec 13, 2008 | 09:01 AM
Winchm60's Avatar
Winchm60
+1, found this out yesterday!
jziran
Aug 24, 2015 04:50 PM
greekzilla
Aug 23, 2015 03:44 PM
kpl
Aug 11, 2015 04:52 AM
