Interior/Exterior Racing Harness question
Old Oct 10, 2008 | 01:01 AM
yellowbritishrocket's Avatar
yellowbritishrocket
im about to install a set of racing harnesses and i was wondering....i saw sometime ago a bracket that attached to either the headrest guides or the back of the seat that acts as a guide and holder for the shoulder harnesses
any ideas?
Old Oct 10, 2008 | 04:27 AM
cmt52663's Avatar
cmt52663
what's the application - road racing, or autocross?
Schroth works beautifully for autocross, it is a 4 point system that some folks think falls short of being fully road race spec...
Old Oct 10, 2008 | 07:04 AM
Bigshot's Avatar
Bigshot
We need more info on the harness you have and the intended use.
Old Oct 10, 2008 | 07:24 AM
quikmni's Avatar
quikmni
I to had seen the harness bar you are trying to find. The one I saw had brackets that mounted to the top seat belt mounts.
I thought it was a Brey-Krause part but this is all I can find on their webpage now:
http://www.bkauto.com/mini/r1305.php
I did find the following link to someone who made a bracket like I remember seeing. The link has many pictures of manufacturing and installation.
http://engr.smu.edu/rcam/cpm3v/minihbar/minihbar001.htm
Old Oct 10, 2008 | 08:58 AM
yellowbritishrocket
they are schroth quick-fits....i dont need the actual mounting bar but i remember it was a guide bracket that attached to the back of the seat itself and held the harnesses in place
Old Oct 10, 2008 | 09:27 AM
fastfritz's Avatar
fastfritz
I think it was mossmini that had them but quit handling them as they broke
shortly after being installed.
Old Oct 10, 2008 | 11:15 AM
batrugger's Avatar
batrugger
Just run the straps under the head rest it will work fine
Old Oct 10, 2008 | 04:11 PM
cmt52663's Avatar
cmt52663
amen - been running that setup for four years, no problems
Old Oct 10, 2008 | 05:12 PM
yellowbritishrocket
lol ups needs to be quick....im chomping at the bit to get them
Old Oct 10, 2008 | 05:15 PM
cmt52663's Avatar
cmt52663
at the risk of posting the obvious
when you get them installed, and adjusted to your driving position, and "just so"...
1. slide seat fully back to release belts and get out
2. when entering, start with seat fully back, connect the belts, and then slide forward into them
3. when encountering pucker factor - slide seat one tiny notch closer to the wheel which
a. bends the elbows just a touch, and
b. really snugs you into that seat!
Enjoy - the principal benefit is "light hands" so when you are belted in, relax your grip a little....
Cheers,
Charlie
Old Oct 10, 2008 | 08:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
So does anyone have the Brey-Krause harness bar?
Old Oct 10, 2008 | 09:11 PM
gnatster's Avatar
gnatster
Local Track Only MINI with the name of J Deere has one.
Old Oct 10, 2008 | 09:27 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Are they a NAM member by chance? I'd like to know more about this harness bar.
Old Oct 10, 2008 | 09:58 PM
gnatster's Avatar
gnatster
No, he's not a NAM member. Whats to know, you pull the seat bottoms out, drill some holes, bolt in the bar. connect seatbelts. Oh yeah there is the whole mounting of the crotch and side belts thing too too.
It's basically 1/2 a roll bar. The idea behind the product is you can bolt it in Friday night, do a track day and set the car back to carpool with 3 others on Monday. Bery krause makes some great stuff but I feel they missed the ball on this one. Who is gonna pop that in and out. Don't forget to fill the holes with something to keep rain out. Might at well pull the back seat and get a roll bar with a harness bar if you are gonna go that far. That's my thought on the matter anyway.
Old Oct 10, 2008 | 10:00 PM
second to none's Avatar
second to none
I have the stable energies harness bar. Simply running the harnesses through the headrests does not work for everyone, as a few have stated. I find the harness bar takes a lot of downward pressure off my shoulders (since it pivots over the bar and not the backrest of my seat, which is lower than my shoulders), and that I really don't want to be pushing my butt around in a wheelchair should I take a collission with an improper harness setup doing more bad than a stock seat belt. Unless your autocrossing, for your own sake invest in a harness bar. Looks cool too
Plus the bar bolts into the upper seatbelt mounts, keeping the stock belts functional as well
link:
http://www.stableenergies.com/prodinfo.asp?number=GB3
Old Oct 10, 2008 | 10:05 PM
gnatster's Avatar
gnatster
Stable Energies http://stable-energies.com/prodinfo.asp?number=GB3
This makes more sense than the Bery Krause unit. I've seen both in cars. With the Stable Energies the back seat is still liveable with ease, once the bar is out of course. You do end up with funky looking B pillars tho, but hey, your not sitting back there.
Old Oct 10, 2008 | 10:36 PM
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
There was a company called Topspin, which made carbon fiber harness guides for use with stock seats - so you didn't have to feed harness through headrest. Here's a +4 year old picture of Maxmini's interior when he had this setup.
Dr.Steve (Custom Mini Shop) is finishing up my Autopower 1/2 cage install + G-Force 5-point harness(s). I evaluated going the Brey-Krause route, the B-pillar option & ultimately decided the 1/2 cage was the best route to take.
Old Oct 11, 2008 | 12:24 AM
yellowbritishrocket
those are the ones i saw....are they still made?
edit....found the site...179 each bracket....anyone have a set they arent using?
Old Oct 13, 2008 | 07:10 AM
Bigshot's Avatar
Bigshot
So what is the benefit of these over running the harness thru the headrest posts?
Old Oct 13, 2008 | 08:26 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
For some, the Schroth can pinch your neck. But with the shoulder pads, it is less of an issue for me.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
eatsleepautox
Oct 30, 2015 06:46 AM
Tristankix
Aug 24, 2015 04:39 PM
ki7hy
Aug 12, 2015 07:07 PM
