Interior/Exterior DIY clear front turn signal lenses
Old Mar 14, 2010 | 01:26 AM
  #151
Sketch's Avatar
Sketch
Clear lenses arent neccessary, you can just take out the orange ones and you will be fine. Just be sure to get chrome painted bulbs to swap out the clear ones already there.
Old Mar 18, 2010 | 09:44 PM
  #152
k3v1n's Avatar
k3v1n
What about the possibility of dirt/dust/moisture getting in your housing? Have you had any problems?
Old Mar 18, 2010 | 09:54 PM
  #153
Oxybluecoop's Avatar
Oxybluecoop
The light assembly is still sealed up so unless you have a leaky rubber gasket there won't be any dirt,dust or moisture.
Old Mar 19, 2010 | 06:14 PM
  #154
k3v1n's Avatar
k3v1n
^ Thanks
Old Apr 20, 2010 | 11:33 AM
  #155
wxviewer's Avatar
wxviewer
So is there a difference between removing the amber lenses with Halogens .vs the HIDs?
Has anyone documented how to do it with the HIDs like below?
Originally Posted by c615586
Bruce sent me two of his early lens samples this week. I decided to install them this morning... 45 minutes and a couple of skinned knuckles later, the "egg yolk" look is banished!
Before:
After:
Old Apr 23, 2010 | 08:46 AM
  #156
bagwell's Avatar
bagwell
and ONE MORE TIME.....plz help.
the front turn signal bulb is a 1156 or 7506 or 7507?
the rear turn signal bulb is a 1156 or 7506 or 7507? pretty sure this is 7507 right?
Old Apr 25, 2010 | 06:19 PM
  #157
Sketch's Avatar
Sketch
7507 looks about right. Just google the bulb type and compare the results to the one you have.
Old Apr 26, 2010 | 05:21 AM
  #158
bagwell's Avatar
bagwell
7507 is correct (the prongs are not 180°) but 7506 will work.
also -- since my car came with clear lenses (THANK GOD) I just lightly painted the amber bulbs with silver paint; even the silverstar bulbs need to be painted as well or they are too blue.
in my limited experience with the chromed out bulbs they're pretty dim compared to standard amber or painted amber bulbs.
Old Nov 7, 2010 | 11:09 AM
  #159
mini_mini's Avatar
mini_mini
Originally Posted by ChubbyChecker
I don't mind the Joey mod look on some cars. It's just not what I want on Chubby. But I do like the clear lens look. Unfortunately I didn't think about it when I ordered him. Here is a pic of how it turned out. I finally chose the silver painted bulbs.
I understand the way you remove the orange lens but how you replace it with the clear even if you disassemble the headlight.
https://www.northamericanmotoring.co...nses-small.jpg
Old Nov 7, 2010 | 06:14 PM
  #160
cenobyt's Avatar
cenobyt
does anyone know what happened to this project? Were a good set of clear lenses ever made?
Old Dec 25, 2010 | 12:17 AM
  #161
Rob490's Avatar
Rob490
bump? Anyone offering clear lenses?
Old Dec 25, 2010 | 08:47 AM
  #162
Mini Fireman's Avatar
Mini Fireman
Nope. The OP bailed on us after making his own.
Old Dec 27, 2010 | 07:04 PM
  #163
Rob490's Avatar
Rob490
Not cool. He couldve made a good bit of pocket change. Anyone else willing to give this a shot?
Old Dec 28, 2010 | 06:21 PM
  #164
automan21's Avatar
automan21
Originally Posted by mwedge
I can confirm the clear lenses that Chubby is making fit the halogens. I took my headlights apart and replaced the orange lenses. I used a heat gun and it took about 7-8 minutes per light to get them apart. Here is a pic of the headlight apart with the clear lens installed.
I see your lights are apart but just want to know if you did a joey mod cuz everthing is black except the reflectors... or was there more chrome housing.
Old Dec 29, 2010 | 06:15 AM
  #165
amberback's Avatar
amberback
Thought I would go ahead and post some pix of Coop with his complete set of turn signals.
So, Coop started out with the standard clear side repeaters (standard on S) and the ugly orange lenses everywhere else. One of the options I REALLY wanted besides the chrome line interior was the clear turn signals, so I decided to make it happen.
- Removed my front orange turn signals, and bought some silver bulbs for them.
- I purchased stealth bulbs for the side repeaters to give it that 'all clear' look.
- I ordered some clear turn signal tailights from Classic mini for $100 each. (typically 125 but I got a nice NAM discount )
- I also ordered some stealth bulbs for the new tailights.
So im pretty happy with the new look, and heres some pix of the new look!!
That looks awesome! Where did you buy the rear tail lights from?
I'd like to do all clear lens on my 2010 Cooper (I was going to order them, but Oxygen Blue got discontinued & I couldn't order it specifically).
1. No one has found clear front lens, correct? But I can open up my headlights and just remove the orange one and leave it out without a problem? Then just replace the bulbs?
2. Can I get the link of where to buy the tail lights? Dealer?
3. is there a tutorial somewhere on how to remove the headlights from the car and take out the lenses?
Old Dec 29, 2010 | 06:20 AM
  #166
amberback's Avatar
amberback
Originally Posted by Coen_de_K
easy peasy 25min job :D
results :
What bulbs are these? Where can i get them?
Old Jan 13, 2011 | 09:01 PM
  #167
wxviewer's Avatar
wxviewer
So tell me, How did you remove the front lenses from the headlight assembly? I still haven't seen or read a description of how its done. I have my side markers white and tinted out. Now working on the fronts.
Any info would be appreciated!
And if Chubby is still out there, how can I get my hands on a set of those clear lenses?
Thanks!
Bob
Old Jan 13, 2011 | 10:10 PM
  #168
Rob490's Avatar
Rob490
Thanks!
Bob
https://www.northamericanmotoring.co...or-lenses.html
Simple instructions shouldnt take over 20min
Old Jan 14, 2011 | 09:51 AM
  #169
wxviewer's Avatar
wxviewer
Thanks for the help Rob, But I have the Xenons with the headlight washers. Anybody with those try this Mod?
Old Jan 14, 2011 | 04:29 PM
  #170
0utlier's Avatar
0utlier
I was going to take my headlight assembly's out and remove the yolk since I got some silverstar bulbs. However I ran into a snag. Anyone have this issue in the video I made?
http://www.youtube.com/watch?v=foSgcto5YMI
Old Jan 14, 2011 | 07:07 PM
  #171
toolazyforalogin's Avatar
toolazyforalogin
Yes normally I'd tell you to try the search button but I remember it was my post.
https://www.northamericanmotoring.co...4-post418.html
Old Jan 14, 2011 | 11:23 PM
  #172
Rob490's Avatar
Rob490
I would try pliers. THats how i got it out without any issue
Old Feb 27, 2011 | 05:00 PM
  #173
Scooter09's Avatar
Scooter09
How would I get my hands on a pair of these clear lenses? It seems to have been a while since Chubby even posted on this thread...
Old Feb 27, 2011 | 05:07 PM
  #174
Rob490's Avatar
Rob490
Seems like chubby just left. So the easy answer to your question is you dont.Go lensless its working fine for me
Old Apr 2, 2011 | 06:20 PM
  #175
amberback's Avatar
amberback
So I attempted this today and ordered these Orsam Diadem bulbs (http://www.powerbulbs.com/product_detail.asp?prod=102)... but they DO NOT FIT. The pins are not in the correct place! Now I'm out $15 with bulbs I don't know what to do with... and am driving around with a car with illegal turn signals...
Trying to find another set similar (or chrome) with the right offset.
Other places I'm seeing that a car with Orange lens comes with straight pins and the clear lens cars have the offset pins. If this is the case, I could maybe find a replacement socket from a white signal lens car...? Trying to decipher this... part 4? http://www.realoem.com/bmw/showparts...68&hg=63&fg=05
