Interior/Exterior How to Install a Cup Holder?
Old May 20, 2008 | 05:07 PM
myolady's Avatar
myolady
Could anyone direct me to a link to install the cup holder that is metallic
and is screwed onto the side??
Thank you!
Old May 20, 2008 | 05:20 PM
QXXOTIC's Avatar
QXXOTIC
OEM Cup Holder Install
This is EASY.
Just open the glove box and you will see 2 TORX screws in the downtube. One inside the glove box and the other below it.
Simply remove the torx screws, add the holder, and replace the screws using the same ones that were there. Takes about 5 minutes tops.
Jim
Old Jul 3, 2008 | 02:10 PM
thomastrain's Avatar
thomastrain
I am looking for a cup holder for my clubman so I can use large cups. Will the one above work and where can I find these online. I looked at the Mini Fini but I do not think it will work in the clubman.
Old Jul 3, 2008 | 03:39 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Open passenger door, place person with pulse in passenger seat, place seat belt around them, bend said persons left arm to desired height, adjust hand to cup size, and off you go.
Old Jul 4, 2008 | 05:04 AM
Bahamabart's Avatar
Bahamabart
Originally Posted by QXXOTIC
This is EASY.
Jim
This should be made a sticky .
Old Oct 2, 2009 | 08:25 PM
LadyTazmanian's Avatar
LadyTazmanian
Hey Everyone
WHere do I get the little black pin from?
Attached Thumbnails How to Install a Cup Holder?-mini-20cup-20holder-20front.jpg
Old Oct 3, 2009 | 05:36 PM
PA-MCS's Avatar
PA-MCS
I'm sure the dealership only sells this as a whole with the cupholder. I noticed my cupholder broke the other day at the mounting points. Damn heavy XL cups.
Just checked my broken cupholder, at first I thought it was all one piece. Then noticed it does come apart. Wonder if I can just buy the silver mounting piece or spend $68 for a new piece
Old Oct 4, 2009 | 10:03 AM
Yo'sDad's Avatar
Yo'sDad
Home-made Cup Holder
I offer the following home-made cup holder. All the parts are schedule 40 PVC plumbing parts from Home Depot. The cup container is nothing more than two off the shelf parts glued together with PVC cement. The cylinder that fits into the existing tiny factory hole is a piece of 2 inch PVC pipe. The bridge is made from sections from a different piece of 2 inch PVC pipe. The bridge that connects the smaller 2 inch pipe to the larger cup holder is glued with J-B Weld Epoxy. PVC glue is not good in this type of mechanical joint.
I carved out the relief in the bridge part with a hack saw and metal round file. I attempted some filler in the rough parts with the XS J-B and sanded and primed it. It is still a prototype and does not have a finished paint yet. It is very strong, totally and easily removable. Just grab it and pull it up in case you need to slide the pass seat all the way forward. It is large enough to hold a Big Slurpee sized cup. When using a regular cardboard coffee cup I throw a small piece of foam in the bottom so the cup sits up high enough to grab. So far it is working perfectly. This is easily made and easily removed if you need it to be gone. I tried it on the drivers side, but it hit under my knee and not comfortable.
Apparently this forum will only allow me to add three pics per post, so here are three pics. I'll do another post with more pics so you can see the relative size and location.
thanks YD
Cup Holder In-car top view.jpgCup Holder in car from pass side.jpgCup Holder top.jpg
Attached Thumbnails How to Install a Cup Holder?-cup-holder-in-car-top-view.jpg   How to Install a Cup Holder?-cup-holder-in-car-from-pass-side.jpg
Old Oct 4, 2009 | 10:06 AM
Yo'sDad's Avatar
Yo'sDad
Home-made Cup Holder more pics
More pics of my cup holder
YD
Cup Holder in car Cup Holder bottom.jpgfrom driver side.jpgCup Holder angle 2.jpg
Old Oct 4, 2009 | 08:47 PM
spinned's Avatar
spinned
Wow... good job!
adrchn
Aug 13, 2019 02:11 AM
sevin
Aug 24, 2015 09:26 PM
Aug 24, 2015 03:14 PM
