Interior/Exterior Whalen Owners, What Am I Doing Wrong With Install?
Old Aug 27, 2007 | 08:28 AM
enologuy's Avatar
enologuy
Hello all you Whalen owners.
I just received the adapter for me Cravenspeed SS and [tried] to install my Whalen shift ****. It seemed to go on fine but it spins freely and is therefore not ideal when shifting aggressively. What am I doing wrong?
Thanks for any input and, if I am just being 'blonde', try to be nice.
Old Aug 27, 2007 | 08:44 AM
ScottRiqui's Avatar
ScottRiqui
Does your aftermarket shift lever have the same horizontal slot in the top of it that the stock shift lever has? If you look inside the Whalen shift ****, there's a pin that's meant to engage the slot in the factory lever.
If your shift **** is spinning freely when it's installed, then either your new shift lever doesn't have the slot, or you don't have the **** fully engaged.
Old Aug 27, 2007 | 08:59 AM
enologuy's Avatar
enologuy
The shift lever does have the slot in it but it seems that the plastice sleeve adapter does not screw down far enough to allow the shift **** to engage the slot/pin. I will look into it further.
Also, I bought the short shifter through Webb Motorsports and the adapter through Cravenspeed. Cravenspeed assured me that the adapters are the same...but I wonder.
Old Aug 27, 2007 | 09:10 AM
SayGoodbye's Avatar
SayGoodbye
Old Aug 27, 2007 | 09:51 AM
CR&PW&JB's Avatar
CR&PW&JB
^ And making sure the boot is not interfering with the sleeve slipping down far enough to engage the slot, right ?
Old Aug 27, 2007 | 03:39 PM
LordOfTheFlies's Avatar
LordOfTheFlies
If your Whalen shift **** is spinning and the locking mechanism is NOT, then your **** is broken.
This happened to me when I let someone check out the Whalen in my car and they somehow had the urge to twist it off...and broke it.
Doug sent me a replacement for half price and evidently changed the design with newer models.
This happened back in mid 2004.
Is your Whalen **** a brand new one or did you get it used?
Old Aug 27, 2007 | 05:34 PM
enologuy's Avatar
enologuy
The **** is not broken.
The shift boot is not in the way.
I am pulling up on the 'ringed' slider on the ****.
The plastic sleeve is not screwing down far enough to allow the pin inside the **** to engage the slot in the shift arm. Perhaps I need to just screw the plastic sleeve down with some assistance (plyers) to allow the **** to engage the slot. (?)
Old Aug 27, 2007 | 05:59 PM
CR&PW&JB's Avatar
CR&PW&JB
It shouldn't be that hard to install. If you need pliers or another tool, either there is operator error involved or Doug somehow machined it incorrectly.
If you continue to have problems, I'd contact Doug and talk with him about the problem.
Old Aug 27, 2007 | 06:11 PM
ScottRiqui's Avatar
ScottRiqui
As another quick check, does the factory shift **** fit completely down on the aftermarket lever? If the factory **** engages fully, the Whalen should too.
Old Aug 27, 2007 | 06:37 PM
enologuy's Avatar
enologuy
I figured it out guys. I just needed to take my time and screw the plastic adapter down far enough to allow the pin in the shift **** to engage the slot in the shift lever. I just wasn't twisting it hard enough to screw it down far enough. BTW, wow, what a difference in the way my short shifter works!
Thanks for all the help.
Cheers, Doug.
Old Aug 27, 2007 | 08:53 PM
SayGoodbye's Avatar
SayGoodbye
W0TM8
Dec 19, 2019 07:50 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
