Interior/Exterior Hub Centric Rings?
Old Aug 28, 2007 | 09:55 AM
bdr127's Avatar
bdr127
Hub Centric Rings?
I have a 2006 Cooper S and just got a set of 18" Enkei RPM2 wheels. I really need to get a set of hubcentric rings, but I have no idea how to determine which size I need.... Any help would be appreciated. Thanks!
Old Aug 28, 2007 | 09:58 AM
goaljnky's Avatar
goaljnky
Mini hub is 56.1.
Old Aug 28, 2007 | 10:10 AM
bdr127's Avatar
bdr127
Originally Posted by goaljnky
Mini hub is 56.1.
Thanks. According to Enkei's website, it says my wheel has a "bore diameter" of "73". Can I assume, then, that buying the rings at 1010tires.com (http://www.1010tires.com/hubrings.asp), I'd need the 73mm outside diameter / 56.15 inside diameter?
Old Aug 28, 2007 | 10:16 AM
goaljnky's Avatar
goaljnky
Sound right.
Old Aug 28, 2007 | 10:25 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
If you check out this thread:
https://www.northamericanmotoring.co...gs#post1550597
you'll find the hubcentric spacers I use have the dimensions you are looking for.
Old Aug 28, 2007 | 12:26 PM
bdr127's Avatar
bdr127
What do you guys think about these?:
http://cgi.ebay.com/ebaymotors/MINI-...mZ180153647945
Old Aug 28, 2007 | 02:37 PM
kenchan's Avatar
kenchan
^^ those plastic ones work fine for cars that are not driven hard.
for cars that are tracked, you should get the aluminum ones.
Doc Pain
Mar 10, 2021 04:50 AM
vulkandino
Oct 31, 2015 08:29 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
JAB 67
Sep 29, 2015 01:34 PM
Nicefeet
Sep 24, 2015 06:53 PM
