Interior/Exterior R56 scoop removal
Old Jul 23, 2007 | 10:24 AM
JS's Avatar
JS
R56 scoop removal
Has anyone removed the scoop from the R56?
If so, what is involved?
Thanks in advance.
JS
Old Jul 23, 2007 | 12:59 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
There is a rubber plug on the under side of the hood directly under the scoop. The plug is hiding a screw. Remove the screw then pull REALLY hard on the scoop. The scoop will just "pop" off.
Old Jul 23, 2007 | 01:17 PM
JS's Avatar
JS
Great. I'll try that. Thank you.
JS
Old Nov 12, 2007 | 05:11 PM
ToMiTa's Avatar
ToMiTa
I am going to try this. Does it pop straight up, front end first, back end first, etc??? I don't want to bang my car up. Thanx!!!!
Old Nov 12, 2007 | 05:19 PM
pastabatman's Avatar
pastabatman
I've been thinking of popping mine to get it painted (along with rear door latch) to match my black roof - this tip will come in handy. Alternatively, I might just get the JCW CF scoop (heat concerns).
Old Nov 12, 2007 | 05:24 PM
chili_red07's Avatar
chili_red07
It is a little easier if you use a pair of needle-nose pliers to push the grey plastic thing (you'll know what it is when you see it) through its hole, pushing the scoop out enough to grab underneath. Once you can get your fingers under it, just pull. It'll have a little resistance and you'll hear it pop out one fastener at a time.
Old Nov 12, 2007 | 05:27 PM
ToMiTa's Avatar
ToMiTa
Thanks!! I will try it. I want to unblock it and then put it back in. I am getting prepared for Alta CAI.
Old Nov 12, 2007 | 05:34 PM
chili_red07
No prob... thats what I opened mine for (p.s. the ALTA CAI/ Inlet Hose is sweet!). If you get stuck feel free to PM me and I'll snap some pics of what I'm talking about (I would now, but I'm at work)
Old Nov 12, 2007 | 05:58 PM
ToMiTa's Avatar
ToMiTa
I just did it. No pliers needed.
For those that plan to do it, it is 1 torx head to remove then 4 phillips heads for the small grill. The grill is now out. Right now, I am going to paint the grey retainer flat black so it does not stick out like a sore thumb. Thanks!!
Forget the paint. Too messy!! I used a black Sharpie pen. It came out nice.
Old Nov 13, 2007 | 07:56 AM
andyde's Avatar
andyde
Yep, it comes out fairly easily...
I did paint mine and it came out great...take a look at this thread..https://www.northamericanmotoring.co...d.php?t=116016
Old Mar 12, 2008 | 11:38 PM
Sambo99's Avatar
Sambo99
seems I was a little too rough in "lifting" the scoop out, or are those clips meant to break???
Oh well - the new chrome scoop is in and now its a wait for the Alta CAI to arrive :P
Old Mar 13, 2008 | 03:53 PM
ANT818's Avatar
ANT818
good luck opening the holes
Old Mar 16, 2008 | 03:36 AM
donuttang's Avatar
donuttang
i posted in my gallery....check it out....i replaced the plastic with black metal grill in the scoop
Old Mar 16, 2008 | 01:04 PM
maximusGeek's Avatar
maximusGeek
Were did you get your metal grill?
Old Mar 16, 2008 | 06:01 PM
donuttang's Avatar
donuttang
I got it from local auto store. Cost 10 USD. It is a big piece that is made for the front grill actually.
Forgot to mention I did crack one of the slot on the scoop. So take it easy to pop it. I started from the back side towards the windshield.
Old Apr 11, 2008 | 11:18 AM
Lumberlog's Avatar
Lumberlog
donuttang, the wire scoop plug looks great! How did you connect it to the stock fittings?
Old Aug 30, 2008 | 06:42 PM
clnconcpts's Avatar
clnconcpts
That looks nice and exactly what i want to do.Why do you buy that grill?
Also i was looking at trying to remove the hood scoop today and wasnt able to do it.
I removed the pad and saw the gray tab that you push the tabs closed to release it.I didnt see anything else to remove nor did i see this black plug with a screw underneath to remove.
Please help
Old Apr 22, 2009 | 11:41 PM
asaulo1's Avatar
asaulo1
So, just to clear things up, you would need to pop off the entire hood scoop to get to the grill.... I just installed my ddmworks intake and am needing to do this to dremel out the grill... sucks that you have to take the whole scoop off first.
Old Jan 8, 2010 | 08:38 AM
Richieb0y28's Avatar
Richieb0y28
Hey guys, I plan on adding the Alta Cold Air Intake, but I know they suggest to remove the hood scoop grill. Does anyone have any advice or suggestions for when I try and do this.....?
marendt428
Feb 25, 2016 07:13 AM
Ovrclck
Aug 27, 2015 07:58 PM
O4mcs
Aug 10, 2015 10:22 PM
