Interior/Exterior Built in garage door remote
Old Jun 2, 2003 | 05:17 PM
SB's Avatar
SB
I finally got tired today of reaching in the glove box to use the garage door remote. That was the only place I found to store it because it clashed with the interior. The sunvisor was too thick plus I didn't want to have permanent marks on the visor from the remote clip. I looked at the inside of the remote and it's nothing more than a very small board with a switch then the 9 volt battery.
I purchased a normally open momentary switch and wired this onto the existing switch. I could have removed the current switch but this way made it more temporary. We've been house shopping. Here is a shot of the board, battery and switch I used.
:smile:
_________________
home.mchsi.com/~mini/index.html
Old Jun 2, 2003 | 05:27 PM
Pebbles's Avatar
Pebbles
This is fantastic!
Photos are great!
You are very clever!
Thanks!
Old Jun 2, 2003 | 05:32 PM
ronvan's Avatar
ronvan
I like it! I saw a garage door remote mod on a site that taps into the high-beam circuit. You just flash your high-beams and your garage door opens.
Honda Element Info
How difficult will it be to change the battery in the remote?
Old Jun 2, 2003 | 06:30 PM
SB's Avatar
SB
Knowing that I would need to take it back out I went ahead and used a new battery. The way I have it now it should take less than 3 minutes to change the battery. That includes the new tape for cover. I'm sure I have only used four batteries in the last ten years so it shouldn't be a problem.
Old Jun 9, 2003 | 07:12 PM
YellowCoop's Avatar
YellowCoop
SB,
Thanks for the great idea. I did this yesterday and it worked great.
Charles
Old Jun 9, 2003 | 07:16 PM
Flash's Avatar
Flash
Way to go SB! I just removed the clip and used some velcro to mount my remotebetween the sunroof switch and the temp sensor. Your install does look very nice
Old Jun 9, 2003 | 07:47 PM
CMINIGO's Avatar
CMINIGO
Very nicely done! It'd also be super cool to add the missing toggle switch to the instrument panel and have that work the garage door opener, but that's a lot more work and $$$ to execute. Very cool! I think this will be my next mod. Thanks for the detailed info and pictures, SB.
_________________
Silver and Black with a Silver Union Jack- I call her Dr. Emma Peel! GRRR BABY! VERY GRRR!!!
Old Jun 10, 2003 | 10:44 AM
ScooterMan's Avatar
ScooterMan
I just put mine under the center pod. If you reach up under the center pod under the dash you'll feel a cover. Just push up a little and it comes unsnapped. You can then use this ledge to put clip on your remote (it fits in backwards so the clip goes forward with the remote unside down). Total installation time: less than a minute.
Old Sep 9, 2003 | 07:09 PM
JackmanAVP's Avatar
JackmanAVP
outstanding Idea !!!! Great photos.....fun project for this Saturday !!!!
Thanks,
JackmanAVP
Old Sep 14, 2003 | 09:39 AM
guru220's Avatar
guru220
i would really like to wire it into the toggle switches. that would be so great. I want to try it but worried i mess something up. it would fill the empty swich holes so it would look complete. i would need a new chrome toggle swich (from mini im sure) and to drill out the hole. i could then wire the toggle swich to the opener and mount the opener near there and then thats it. i will look into it more soon see what it looks like under there and if it would be possible.
Old Sep 14, 2003 | 08:54 PM
scooterboy's Avatar
scooterboy
MINI isn't going to sell you a single toggle - you'll have to buy the whole european switch bank or find someone else who has bought it and will sell you a toggle from their original bank.
Old Sep 15, 2003 | 01:41 PM
jman2000's Avatar
jman2000
there is a how to out there on adding a toggle switch. I found it by going through Gab's page but here is the direct link. Add an Accessory Toggle Switch
Old Sep 18, 2003 | 04:39 AM
Aliron's Avatar
Aliron
I´ve done mine some few days ago, I´ll post pics soon, i have place it under the swichs case...
Old Sep 18, 2003 | 05:59 PM
05JCWS's Avatar
05JCWS
Another cool place to put the unit would be behind the European Parcel Shelf and then mount a switch on the blanking plate.
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Southern Marylander
Sep 3, 2015 05:46 AM
spackletooms
Sep 1, 2015 10:12 PM
