:: ECS Tuning :: CM "Mickey" Center Trim Kit
Old Apr 9, 2014 | 08:10 AM
MINI Countryman Piano Black with Chrome Trim Set
This kit is a genuine MINI trim upgrade from the gray to the newer piano black with chrome, which matches the dash. These easily snap into location in place of the original trim. A complete set for an instant upgrade to the interior.
Incudes:
Center Mickey - Piano Black with chrome.
Left and right outside dash vents in piano black/chrome.
Fits MINI:
R60 MINI Countryman (2011+)
R60 MINI Countryman S (2011+)
R60 MINI Countryman SX (ALL4) (2011+)
R60 MINI Countryman JCW(2013+)
Click HERE for MINI Countryman Dash Trim kit or for more information.
Old Aug 10, 2014 | 01:33 AM
Erin Argent's Avatar
Erin Argent
Hi ECS, can you provide a link to the installation instructions for this kit? Thanks!
Old Aug 11, 2014 | 08:15 AM
Hello Erin,
#12 is the center and its snap in and out. #8 is a little more work. See the link below for how to DIY.
https://www.northamericanmotoring.co...dash-trim.html
Old Aug 11, 2014 | 09:39 AM
Erin Argent
Thanks ECST, we'll be sending a bunch of customers your way.
On a separate note, do you have any idea how to remove the center vent cover on the R60 Countryman? Does it just snap off and on? Is there a trick on how to properly remove it without damaging the piece or the clips?
Old Aug 11, 2014 | 10:19 AM
Thanks ,
On the Mickey Speedo :
You can see here the back tabs. Work your way around. And make sure you unsnap the hazard button after you clip it out .
" The center speedo trim pops right off, but you have to watch the wires that go to the hazard button. You'll need to pop it off and then disconnect the wire from the switch. Start pulling at the bottom and work your way to the top. Then getting the switch off you need to squeeze both metal spring clips at the same time and push it out from the bottom. "
From that thread above.
We have trim removal kits that make things a little easier: There is a 5 piece tool and 11 piece tool kit.
http://www.ecstuning.com/Search/SiteSearch/Schwaben_Tool_Trim/
Also here is the piano black with black chrome ( called the piano black / piano black trim kit )
Dash Trim Kit - Piano Black / Black Chrome 51459810000
http://www.ecstuning.com/Search/SiteSearch/51459810000KT/
thanks
Old Aug 11, 2014 | 10:27 AM
Erin Argent
Thanks for the extra information.
Unrelated, but any chance you may know how to remove the top center vent grillr?
Old Aug 11, 2014 | 10:35 AM
Welcome,
Have not seen the that dash part removed yet looks like part of #11 which has those screws #7 holding it. Then #5 and #7 under #13 holing the front portion. I would think then that whole piece would come, out , just be careful and take your time. That's all the info I have.
Old Aug 11, 2014 | 05:03 PM
Erin Argent
There are several rectangular slots on top of part #11 to receive the vent grill. Just can't figure out how exactly it connects. I don't want to break any of the tabs pulling it off the wrong way. If anyone has done this before, please chime in. Thanks.
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
