How To DIY: Home Depot front lip
Old Apr 28, 2009 | 07:34 AM
  #201
TRuTH's Avatar
TRuTH
Originally Posted by ngweibing
i did the side of my car.... what ya think?
Attachment 34993
Attachment 34992
I like the look of that
Old Apr 28, 2009 | 08:24 AM
  #202
checkercoop's Avatar
checkercoop
Originally Posted by JIMINNI
I tried this mod and couldn't get anything to stick to my bumper And for the guy's that said they did this in 45 minutes and spent $12. yea right. I spent $20 just on tape and $15 on the seal and hours going to the stores and trying to get this to work Anyway, might try and strip whatever is keeping it from sticking and try again
^^^actually my seal was $8, tape $4, rivets were $3...total $15
Aligned and stuck, cut, jacked up car, drilled, rivet...1 hour
Yes it can be done, just gotta get the rubber slick off the vinyl, prepare for the worst, and know where to find the best prices
Don't question our superiority jk
Old Apr 28, 2009 | 09:37 AM
  #203
JIMINNI's Avatar
JIMINNI
Ok, I went to Lowes for the seal, tried 2 different kinds of tape, 3-M and some trim tape, stuff is not cheap. What kind of tape did you use? Also you didn't use fender washers on your rivets? I tried rivets, they pulled thru. Will go with a wood type screw that will grab if I attempt again.
Old Apr 28, 2009 | 09:58 AM
  #204
checkercoop
I used these rivets
http://www.lowes.com/lowes/lkn?actio...212&lpage=none
They really work awesome. They are long enough to get past the seal and bumper, hold really tight, and have a good sized washer built in. They come in packs of 2 and I used 6 total to minimize the wavy look at pressure points.
I had gotten a small thing of heavy duty, outdoor 3M tape just to hold the seal up while installing rivets and to give some support to the gaps. I wouldn't trust it alone though because I was running into the same problem you seem to have where its just not sticking properly to the surfaces. I don't know how the others have been able to go only 3M, for me the rivets were a must.
Old Apr 28, 2009 | 11:10 AM
  #205
JIMINNI's Avatar
JIMINNI
I used these rivets
Yea I looked a those, almost the same thing used on our cars already in certain spots Thanks.
Old Apr 28, 2009 | 12:10 PM
  #206
miniman101's Avatar
miniman101
Got mine done.
Old Apr 28, 2009 | 08:10 PM
  #207
checkercoop
Yeah I agree seems close to whats used to hold the wheel well lining and what holds the black plastic door sill on the bottom side of the car
Old May 1, 2009 | 09:56 PM
  #208
miniman101's Avatar
miniman101
I think I have to redo mine. The tape isn't sticking very good. Did I miss something? I got 3M double sided tape as pictured in first post, cleaned the underside of bumper good, stuck it and the lip on and bolted it. Now it seems to be sagging in between the bolts? Is there better tape our there, or did I just mess something up?
Old May 1, 2009 | 10:02 PM
  #209
thecigarman's Avatar
thecigarman
I have it front and rear and have had mine on for a few months and did not use screws or fasteners at all.
I used a hot glue gun and "tacked" it from the back and at the ends after I used contact cement on the bottom of the bumper (I let it get tacky) and stuck the strip on.
Old May 1, 2009 | 11:54 PM
  #210
KandyRedCoi's Avatar
KandyRedCoi
heres my attempt at the HD front lip
Old May 2, 2009 | 09:50 PM
  #211
MInI___Gz's Avatar
MInI___Gz
PICS??
Old May 2, 2009 | 10:18 PM
  #212
flingger's Avatar
flingger
Some jackass on eBay is trying to sell these without saying it's garage weatherstripping. ***!
Old May 3, 2009 | 04:44 AM
  #213
ngweibing's Avatar
ngweibing
show us the auction... hope itx not someone from here...
Old May 3, 2009 | 02:42 PM
  #214
MInI___Gz's Avatar
MInI___Gz
every1 is trying to make a buck these days
Old May 4, 2009 | 05:29 PM
  #215
tek1976's Avatar
tek1976
Old May 5, 2009 | 02:05 PM
  #216
ImagoX's Avatar
ImagoX
Use rubbing alcohol and a paper towel to wipe all the grunge off the underside of the bumper lip first - that will help the double-sided tape stick. I only used a few pieces though, just as security (which it didn't need). If you use the 1" washers with the self-tappers, then you shouldn't have any ripple (or at least MINIMAL ripple).
As for what you spent, I didn't spend that much - I have no idea why your parts were so expensive. I paid less than $14 for everything. My garage door stripping was $7, and the rest went to self-tappers, 1" fender washers (stainless) and a small roll of 2-sided tape.
Old May 5, 2009 | 02:41 PM
  #217
thecigarman
Yes to the alcohol and thorough cleanup.
The Lowes I went to only had the longer tape for double doors and I paid about 20 bucks for mine, but I have enough matching stuff to redo if it comes off or gets damaged.
Old May 5, 2009 | 04:25 PM
  #218
everytimeidie027's Avatar
everytimeidie027
I just saw that while searching for a new bumper haha
Old May 18, 2009 | 04:42 PM
  #219
tommy_zito's Avatar
tommy_zito
that is pretty sweet! i would have never thought of that for a mod....we nee more ppl like you around here.
Old Aug 10, 2009 | 02:52 AM
  #220
PowerPig's Avatar
PowerPig
Great mod, cool look & 100% BEST BANG 4 A BUCK! It's not everything in 'of the shelfe' stuff!
Done something similar with my Smart few years ago.
Old Sep 8, 2009 | 07:18 AM
  #221
daglafe's Avatar
daglafe
Very nice.
So for those that have had had this mod installed for a while, how is it holding up?
cheers,
dag
Old Sep 8, 2009 | 07:36 AM
  #222
R53 in SC's Avatar
R53 in SC
Mine is holding up fine. Haven't hit it yet...probably will on the way to work!
Old Sep 8, 2009 | 09:43 AM
  #223
TGL333's Avatar
TGL333
16000 miles and going...looks fine. has hit the ground on some steep driveways, withstood a trip across the country, and southern heat and humidity...
Old Sep 8, 2009 | 10:45 AM
  #224
daglafe's Avatar
daglafe
Thanks for the updates. I only ask because the bottom of my garage is not holding up so well.
I think I might give this mod a try.
cheers,
dag
Old Feb 12, 2010 | 08:13 AM
  #225
JimRoberts12's Avatar
JimRoberts12
has anyone done this to a r56 mcs? just wondering how it would look on that bumper
