How To Interior/Exterior :: Rear Foglight Retrofit
Old Jan 22, 2009 | 09:20 AM
  #51
Oxybluecoop's Avatar
Oxybluecoop
The wire is present on the Coopers it's just tucked up behind the bumper above the styrofoam.
Old Jan 22, 2009 | 09:45 AM
  #52
jbewley's Avatar
jbewley
Thanks, that is good to know and I will look for it. I do think it will have to wait for Spring however.
I see you are in NC. We plan to retire in Southern Pines with all the other horse folks.
Jim
Old Jan 30, 2009 | 11:11 AM
  #53
bentley5's Avatar
bentley5
HELP! I did the Rear Fog install on my '09 MCS and the dealer (MINI of St. Louis) cannot make them work. 'They told me' MINI USA Tech rep (theirs) said it wasn't possible unless the entire 'build code' was rewritten at the Factory and included that (rear fog light) option?? I work at a Bentley/Maserati/Lamborghini/Bugatti dealership and have never experienced this with the cars we sell. All have CAN BUS systems and can be coded for any factory option that was added (after purchase). If you had a dealer reprogram/code your R56 for the Rear Fogs, call out the Dealer name and, if possible, the Tech's name. Thanks for any and all help.
Old Feb 3, 2009 | 02:02 PM
  #54
schatzy62's Avatar
schatzy62
A few things to check that the dealer may not have done.
1. Is the bulb in the socket in the rear drivers side housinf for the fog light.
2. If the bulb is there is it good. I.E. does it light up if used in another location.
3. Is there a fuse that is blown or missing.
4. Does the dealer know how to program it properly. I know some have no clue.
As for the Mini Rep saying that it must have been on the build sheet. Is it possible that they made such a change? Yes it is possible but highly unlikely.
Old Feb 26, 2009 | 05:16 PM
  #55
jbewley's Avatar
jbewley
Originally Posted by Wolfshiem
I am starting a new thread to distribute a guide I put together.
After much waiting, worrying, and struggle, I was able to retrofit my MCS with rear fog lights and a new toggle! I now embrace full toggle glory.
I put together this handy guide for all interested owners.
One word of caution, this is not for the faint of heart...use at your own risk.
EDIT 1: As Paul points out below, rather than remove the top center vent completely, it may be easier to remove the two tabs in the vent (towards the driver and passenger sides) to access two of the screws holding the speedometer cover. This is something I didn't know about until after I removed the vent and wasn't sure it would provide the necessary access, but if it does, it's certainly easier than removing the entire vent.
EDIT 2: ColinMc has pointed out that you may need a T30 in place of the T25 torx bit. This may be due to differences in builds, or perhaps I mistakenly used the wrong bit. Either way, it may be worthwhile to have access to both sized bits before undertaking the project.
EDIT 3: I revised the guide to incorporate the above edits.
Can the switch cover and toggle be obtained from other then the dealer? I plan to try this, but can the parts, with the numbers you provided, be bought on lne?
Jim
Old Feb 26, 2009 | 05:25 PM
  #56
Oxybluecoop
Light assembly
Switch
Cover
Old Feb 26, 2009 | 07:32 PM
  #57
jbewley's Avatar
jbewley
Thanks OXYBLUECOUP, but the switch cover said "no responce found". Two out of three is not bad, but I also need the cover.
Jim
Old Feb 27, 2009 | 04:24 AM
  #58
jbewley's Avatar
jbewley
Jim
Sorry OXYBLUE. It was a bit past "Miller Time" last night when I saw your post. Looking with clearer eyes this morning I wound that the cover is indeed there.
Thanks for your help,
Jim
Old Mar 2, 2009 | 12:37 PM
  #59
jbewley's Avatar
jbewley
One more question. I printed out the retro-fit instructions and the part number for the switch cover is different. Does the one you gave me have the heated seats? Also can the heated seat switches be removed from the old cover and put on the new one?
Thanks,
Jim
Old Apr 13, 2009 | 01:51 PM
  #60
Flyinace2000's Avatar
Flyinace2000
How much did the reprogramming cost? I am def thinking of doing this. I was going to special order a car but the dealership found almost the identical car already built and on the boat. The only difference was the rear fog light.
Old Apr 13, 2009 | 02:42 PM
  #61
jbewley's Avatar
jbewley
Conformation on the 2009 Cooper: Just behind the rear bumber there is a black foam cover which extends the entire width of the car. Just under the rear fog light opening there is a small hole cut on the edge of the foam. You can work your fingers under it and pull it down enough to get your hand in, but it is very tight. Reach around and you will feel a wire just above it. The connector is taped there and its wire is looped and taped just behind it. I was able to cut through the tape with my finger nail, but this is done blind. Don't pull too hard or you will pull the harness out that it is taped to. Once lose, fit the wire in the whole (it is slotted) and attach to the light.
Jim
Old Apr 14, 2009 | 07:31 AM
  #62
Wolfshiem's Avatar
Wolfshiem
The dealer charged me a half hour of labor for the programming, which ended up being a little less than $60.
Old Apr 14, 2009 | 08:00 AM
  #63
Flyinace2000
Alright, that is not to bad. Thanks!
Old Apr 17, 2009 | 01:35 PM
  #64
superc00per's Avatar
superc00per
Crappy iPhone install pics
1. This pic was taken after install, but shows where to pry.
2. Using a flathead screwdriver, pry the foam downwards.
3. Wire bundle is taped above. I yanked on it a little to break the masking tape.
4. Poke hole in 'handle' shaped indent. Pull harness thru. Replace foam. Install light.
Thanks to all original posters
Old Apr 17, 2009 | 02:02 PM
  #65
Flyinace2000
AWESOME PHOTOS! Thanks.
-Will
Old Apr 24, 2009 | 03:40 PM
  #66
jbewley's Avatar
jbewley
I need some thoughts froum you folks:
The dealer siad they could program the rear fog for me so I made an appointment. I went today ad they siad it would take half an hour costing $60.00.
Then they tell me that there as some module they have to program as well and it will take 1.5 hours costing $140.00. I say OK.
Next they tell me that the computer took the code and recongizes the switch, but it won't work. The icon on the speedo does not light nor does the fog light come on. They check it again as tell me that every thing with the computer seeing the switch is fine so I must have messed up the install. All I did was stick a plasic toggle in it's slot and plug in the fog light.
I bought a new bulb, but it did nothing.
Am I missing something??
Jim
Old Apr 25, 2009 | 07:12 AM
  #67
Flyinace2000
Besides $200? Not really sure.
Old May 4, 2009 | 01:27 PM
  #68
jbewley's Avatar
jbewley
Jim
Now this is getting very strange and I could use some thoughts from the folks here.
As I had said above the service tec said that the computer recongized the switch, but neither the light on the dash nor the rear fog would work. I then do the fog to break light conversion, disconnect the rear fog harness and tuck it away. Now when I start the car it tells me I have a bulb out.
It was said above that their switch was faulty and had to be replaced. If the switch in the center stack was bad then why would the computer say the bulb was out when disconnected? If it is bot faulty then why didn't the light work?
Got to be an answer here somewhere.
Jim
Old Jul 19, 2009 | 09:47 PM
  #69
tuber999's Avatar
tuber999
does the old switch cover have an actual 'hole' for a new toggle switch? I'm wondering if it's possible to re-use the switch cover instead of having to purchase a new one. i've checked the prices for this part and they are now going for 100+.
i guess i'll have to live without the lit symbol...
Old Jul 20, 2009 | 03:08 AM
  #70
jbewley's Avatar
jbewley
Yes it does have a hole and can be used. What you see is a plug that can be removed from the rear.
Jim
Old Jul 20, 2009 | 08:50 PM
  #71
tuber999's Avatar
tuber999
Jim
thank you ! i think this may be the first mod i'll attempt when my MCS arrives in a few weeks.
Old Jul 29, 2009 | 09:25 AM
  #72
Chemdean's Avatar
Chemdean
I completed the mod last weekend. It took a little work, but it was not too complicated if you follow the DIY guide. I ordered my kit from outmotoring.com, and for a reasonable price you can order all that you need. GOOD LUCK!
Old Jul 30, 2009 | 06:28 PM
  #73
Flyinace2000
Anyone have any luck yet getting the computer programmed on a 09? If not i might just do the break light mod.
Old Jul 30, 2009 | 07:05 PM
  #74
Lil Q's Avatar
Lil Q
I did the brake light mod and LOVE IT! We really don't get the inclement weather here to have "always" on fog lights so for them to illuminate with the lights in general, then get brighter with the Brakes on is great! I haven't seen any other MINIs with it either making our unique.
I did ask my dealer before getting the brake kit if they could program the fog lights and they stated no.
Now I just need to decide if I am going to add the Driving lights.
Old Jul 30, 2009 | 08:14 PM
  #75
jbewley's Avatar
jbewley
Nope. Go with the break light.
Jim
