Oil on the Solenoid Valve Wiring Loom
Old Feb 28, 2018 | 05:36 PM
32 ft. per sec2's Avatar
32 ft. per sec2
Completed Mini's free Car Care Clinic today where they discovered oil on the solenoid loom which in rare cases (3-4) has led to blown ECUs. It'll be $650 & half a day repair at the dealer but glad they found it as I wouldn't have noticed it.
Anyone else experience this? FWIW the car has 42K on it.
Just a heads up if you haven't taken Mini up on this free service that it might be worth an hour of your time.
Old Feb 28, 2018 | 05:43 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Common problem as I recall on N18's. I know my Countryman had it repaired under warranty early on.
Old Feb 28, 2018 | 08:12 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Yup, a common warranty issue on N18s. Talk with the service manager, they should cover it.
Old Feb 28, 2018 | 09:37 PM
LostbutFound's Avatar
LostbutFound
This is my first time hearing about this. What solenoid? Where is it?
Old Mar 1, 2018 | 12:42 PM
32 ft. per sec2
Well that'd be great but when I asked they said it wasn't covered. I have 42,000 miles, the standard factory warranty is 4 years/50,000 so they would have had to have caught it last year?
Old Mar 1, 2018 | 01:40 PM
squawSkiBum
Moderator
google search of "bmw TIS MINI oil solenoid wiring harness" turned up everything you need to know about this, including links to the repair kit from ECS ($31.23), pictures, and the official TSB. pdf attached.
IMHO since this is such a common problem that there's a TSB, MINI ought to cover it even if you're past the warranty date. You could ask the dealer to advocate for you with MINI/BMW. If that doesn't get anywhere or if it's too much hassle, it looks like a straightforward DIY for low cost. You should also show the TSB to the service manager and ask how this turns into $650. I'm not sure what 52 FRUs means in terms of time, but it looks like $30 in parts and less than an hour of labor to me.
File Type: pdf
Old Mar 1, 2018 | 01:59 PM
LostbutFound
Thanks squawSkibum
Old Mar 1, 2018 | 02:24 PM
jasonp's Avatar
jasonp
bmw FRU's are 5 minutes so 52 FRU's would be 4.3 billable hours.
DCon7
15
Sep 13, 2025 08:31 AM
randeez
Jul 8, 2019 10:59 PM
Matthew Campbell
Aug 22, 2017 09:17 PM
zgokart
Jun 30, 2011 10:03 AM
AlexMoultonIsMyMan
Mar 13, 2008 09:19 PM
