GP MFSW retrofit complete!
Old 10-21-2014, 07:53 PM
keen's Avatar
keen
keen is offline
Installed my MFSW retrofit in #0425 today. Picked up a leather JCW wheel on ebay w/ switches ($250) (planned on a wheel swap anyway - not into the extra thick padding on the GP wheel), and a blinker/wiper switch from a countryman (SZL part #61313453991, $165).
Simple swap - fought my ICAN cable though with random errors when it was getting hot, but the next day everything went ok.
Just doing a SG_RESET on the SZL wasn't enough to get everything working - had to add $249 (MFSW) to the VO, FA_WRITE the VO to CAS and FRM, then ended up doing a SG_RESET on everything - remember it's not just the SZL, since the rest of the car needs to know that cruise should work...
So 425 now has cruise! And steering wheel control for the stereo! And a decent steering wheel.
btw - pulled both the new (used) and the GP's SZL apart - and sure enough, the header between the clockspring and the circuit board that the MFSW switches should connect to the board through is missing. If one really wanted to keep the stock switch, you might be able to add a header for it...certainly the module will accept a MFL aktiv, so the rest of the electronics might be there. Or just switch the physical wiper stalk over. If I dont do a rear wiper retrofit, I might do swap the stalk.......
And no, I didn't get pictures of the missing header. Sigh. It's sitting on the shelf, so I could if someone needs it...
Old 11-09-2014, 07:31 PM
e92oholic's Avatar
e92oholic
e92oholic is offline
I put the same column in this weekend. I didnt code it yet but the stereo controls work already. Cant wait, need to get my coding laptop working again. Just having the stereo controls is amazing. I have missed that greatly.
Old 11-10-2014, 07:02 PM
keen's Avatar
keen
keen is offline
sweet! I use the cruise almost every day (makes it that much easier to keep those looooong 35-40mph zones in check, ya know...).
Old 02-18-2015, 06:02 PM
BillDaCat8's Avatar
BillDaCat8
BillDaCat8 is offline
Pleeeease!
Ok. I get the hardware changes necessary. No problem. I can do that.
The big question tho is; Who can do the programming in or near AZ?
This car wants to go fast. I need cruise to stay outta jail.
My dealer won't even try. Everyone I've seen on NAM that can do it is too far away.
Old 02-21-2015, 04:31 AM
JackMac's Avatar
JackMac
JackMac is offline
Try talking with Jerry at EuroTechs
http://www.eurotechsaz.com
Old 02-23-2015, 05:05 PM
BillDaCat8's Avatar
BillDaCat8
Oh yeah?
Ok, I will. Thanks.
Is he someone you know?
Old 02-23-2015, 07:33 PM
JackMac's Avatar
JackMac
JackMac is offline
Only by reputation and exchanging a few messages recently. He is a GP2 owner as well, and has modded and serviced several GP2s in the Phoenix area. You'll be in good hands.
Old 08-19-2017, 06:18 AM
cansoykal's Avatar
cansoykal
cansoykal is offline
Just wanted to say thanks! But need to mention you must use a szl that is dsc and no rain sensor.
61313453991 worked for me ✌🏼
If using other szl $521 rain sensor must be added to VO to prevent ista/p szl conflict (learned the hard way)
Old 08-22-2017, 07:56 PM
keen's Avatar
keen
keen is offline
ahhh, good to know, thanks for the hard lesson.
Old 08-23-2017, 05:52 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
that's good it worked
Old 08-27-2018, 06:26 AM
R5002's Avatar
R5002
R5002 is offline
@e92oholic
Did you install the 61313453991 and the stereo controls works plug and play or what did you do?
Old 08-27-2018, 07:36 PM
e92oholic's Avatar
e92oholic
Originally Posted by R5002
@e92oholic
my radio controls worked with no coding. Cruise control required coding.
R5002 (08-28-2018)
Old 09-03-2018, 05:13 AM
R5002's Avatar
R5002
R5002 is offline
It works, I just installed the 61319253769 wich supersedes 61313453991 and the stereo controls are working.
Old 11-30-2019, 10:41 AM
brodzik's Avatar
brodzik
brodzik is offline
Unhappy
Hi, sorry to revive such an old thread but for some reason this doesn't work on my MCS.
I have 07 MCS that came without MFSW, I have replaced SZL and added buttons to the steering wheel. Radio controls worked right away so then I added $249 to the CAS and FRM and did SG_RESET on every module and cruise control still doesn't work, when I press cuise control buttons nothing happens.
Help
Old 11-30-2019, 03:22 PM
brodzik's Avatar
brodzik
brodzik is offline
Ok I got cruise control working, for anyone that is still trying to do this in 2019 if you have done SG_RESET on every module and it hasn't worked, do SG_CODIEREN. This worked on my MCS
Old 12-21-2020, 08:15 AM
Samuse's Avatar
Samuse
Samuse is offline
Hello everybody,
I'm new to this forum and new the Mini Cooper world. I am exploring the possibilities to get MFSW for my R60 Countryman 2014.
I tested a BMW MFSW steering wheel on my R60 but nothing worked (not radio buttons nor cruise control), I believe these have to be coded or something like that.
So far I have no idea how the coding works or what is needed for it. Can anyone here please explain what is needed for the coding and if there's any guide?
Many thanks in advance.
Old 12-21-2020, 08:23 AM
keen's Avatar
keen
keen is offline
Originally Posted by Samuse
Hello everybody,
You either need to pay a shop to do the coding work for you, or go learn a ton first. Things to ask a MINI shop - "can you use NCSExpert to code the modules for an MFSW?"
If you want to DIY, start searching NAM (and other mini/bmw groups) for NCSExpert.
I promise you, once you've gotten your hands on NCSExpert and gotten it running, the first post in this tread will make a lot more sense - so go back and read that afterwards.
Old 12-21-2020, 08:25 AM
Samuse's Avatar
Samuse
Samuse is offline
Many thanks for the tips @keen .
Old 12-21-2020, 08:30 AM
keen's Avatar
keen
keen is offline
Old 12-21-2020, 09:24 AM
Samuse's Avatar
Samuse
Samuse is offline
This is a huge help, thanks a ton @keen
I will give it a good read and give you an update.
Filmy
15
06-06-2023 06:27 AM
10-19-2015 08:07 PM
bbak11010
09-07-2015 08:08 PM
bbak11010
09-07-2015 08:03 PM
Norton70
09-07-2015 05:06 PM
Quick Reply: GP MFSW retrofit complete!
