Changing the side indicator lens....
Old Apr 16, 2007 | 09:45 AM
STEWIE's Avatar
STEWIE
from the orange to clear. Do I need to get amber light bulbs or can I use white??? Not sure if there are safety issues or laws regarding this. Also does the lense just pop off without having to remove the entire unit from the inside???
Thanks for the help.
Old Apr 16, 2007 | 09:49 AM
chrisneal's Avatar
chrisneal
There are laws. Usually the white lenses will come packaged with amber bulbs. The lens pops out very easily; you just have to push it toward the front of the car, and it will come right out along with the bulb, wire, etc. Then you have to rotate the bulb assembly with respect to the lens to get that to pop out. Very easy!
Old Apr 16, 2007 | 09:52 AM
STEWIE's Avatar
STEWIE
Thank you. I didnt even check to see what color bulb came with it. Im going to go try and change them out now. I will let you know how it goes
Old Apr 16, 2007 | 10:27 AM
STEWIE's Avatar
STEWIE
Im not doing something right. I cant get it to come out. Will the vent pop off too?? Everyone says this is SO easy. Maybe Im not pushing hard enough??? :impatient
Old Apr 16, 2007 | 11:17 AM
rkw's Avatar
rkw
The vent does not need to come off. I push the lens towards the REAR of the car, then lift off the front edge. I can do this with just my fingers and fingernails, but if you are doing it the first time the front edge may be tight and you might need a screwdriver to help.
Old Apr 16, 2007 | 11:22 AM
chrisneal's Avatar
chrisneal
GAH! Sorry if I said it backwards! It will feel as if it's spring-loaded, and once you pull it all the way back, you should be able to pull it away from the car.
Old Apr 16, 2007 | 11:46 AM
STEWIE's Avatar
STEWIE
Thanks both of you. Im going out to try it again. I will give you the outcome soon. Wish me luck
Old Apr 16, 2007 | 03:32 PM
STEWIE's Avatar
STEWIE
Success!!! They look great!!
Thank you!!
Kimolaoha
Jul 5, 2023 01:04 PM
sprp85
Aug 22, 2015 06:16 AM
cm.d
Aug 19, 2015 08:51 AM
FLYM1N1
Aug 16, 2015 01:17 PM
