There has to be a way! Driving Lights...
Old Oct 3, 2019 | 02:02 PM
  #26
d2mini's Avatar
d2mini
Originally Posted by SFMCS
Found this out, the PIAA LP550 come in two beam/power choices. It appears that one is SAE approved (street legal) for oncoming traffic and another that is night "driving beam" bright. Same price, different wattages. I remember finding that the SAE one is around 7W LED. Useless.
The ijdmtoy ones are 9 LEDs @3 W =27 watts each. Could not find the MINI oem wattage and would guess around the S/JCW driving lights on the lower front fender-not much. So if one could get the Cravenspeed kit with the actual "driving beam" (high) for the 399.00, it would be the way to go. The switch and relay numbers are the same for both PIAA's.
Ok wait.... so you are talking about this kit, correct? https://www.cravenspeed.com/rally-li...f60-2017-2018/
Except that would have the same issue of being too bright to run in normal traffic, unless pointed very low, correct?
Old Oct 3, 2019 | 02:11 PM
  #27
d2mini's Avatar
d2mini
This PIAA 550 does say "SAE-Y Compliant beam that eliminates glare for oncoming traffic and gives you peace of mind that you are running a street legal product."
http://www.piaa.com/lp550led
Old Oct 3, 2019 | 02:38 PM
  #28
SFMCS's Avatar
SFMCS
No, incorrect. The PIAA LP550 lamps come in two models, SAE and off road night version. Ask Cravenspeed, they are probably street legal SAEs in the kit. The SAE is street legal and really low wattage. Like the lower ones in the front fender on a stock MINI. The illuminate the sides of the road (berms) and do little up front. You do not have to dim them, probably. Off road lamps are really bright. In the really old days, a friend had to drive isolated country roads and he changed his bright lights to aircraft landing lights. He could see a mile or so down the road.
MVPeters is correct. 55W for headlamps, 7W-10W for fogs/street legal lamps (Phillips website). You could mount "off road" driving lamps and it's like another set of headlamps. You would blind oncoming traffic and are illegal almost everywhere. If you drive lonely back country roads, you could (and I have) used off road lights. You just have be careful of oncoming traffic. It is also hard on the battery and may not work on a MINI. If you go to a manufacturers website like Phillips, they may be able to help you out with bulb options.
Old Oct 3, 2019 | 02:48 PM
  #29
d2mini's Avatar
d2mini
OK so the link i posted is probably what Cravenspeed has? I know, contact them... just trying to be clear.
In the link, the graphic shows a pretty intense beam pattern, far outreaching stock headlights. That makes it kind of confusing.
Old Oct 3, 2019 | 02:52 PM
  #30
SFMCS's Avatar
SFMCS
I have the same problem, isolated roads but in the mountains. Most good brands of driving lights are adjustable. It may take a few tries to get them setup right. Good luck. Keep us posted.
Old Oct 3, 2019 | 03:01 PM
  #31
Capt_bj's Avatar
Capt_bj
thread morphed from HOW
to CHOICE ......
start a new thread . . .
Old Oct 3, 2019 | 03:55 PM
  #32
SFMCS's Avatar
SFMCS
HOW #2 https://www.cravenspeed.com/f56-auxiliary-light-kit/ INSTRUCTIONS FOR WIRING
Perhaps the question should be WHY?
Old Oct 3, 2019 | 05:05 PM
  #33
d2mini's Avatar
d2mini
to CHOICE ......
It's my thread and I'll do what I want with it. Na-na-na-na-na-naaaa
Old Oct 3, 2019 | 05:10 PM
  #34
d2mini's Avatar
d2mini
That's the thing though... as I was saying early on, I don't need the additional light to see. I live in a major urban area. I want them more to "be seen". Well, as the additional benefit to just looking good. lol
Because of this, I would never get to use them if they required that my brights be on. I never use my brights.
But yes, since they are adjustable they can be pointed lower.
I did confirm with CravenSpeed. Their kit is SAE 14w.
Old Oct 3, 2019 | 11:41 PM
  #35
MiniKar's Avatar
MiniKar
I took my power for my fog lights directly from the battery and put fuses in-line to protect everything.
You need to use a relay and a lighted switch so everything will work correctly.
If you are worried about passing any inspections, don't locate the switch out in the open; maybe place it inside the glove box
so its out of sight but reachable if you need to turn the lights on.
This set up allows you to turn on the fog lights any time you need them, with or without the headlights turned on low or high beams.
Also, you could pull the fuses so no power is going to the relay and switch during an inspection; tell them the lights no longer work.
Just a thought........
Old Oct 4, 2019 | 09:13 AM
  #36
d2mini's Avatar
d2mini
I'm not really concerned with inspection. You should see all the Jeeps running around here with all kinds of lightbars and other auxillary lighting with banks of switches, some right off the showroom floor.
Old Oct 22, 2019 | 07:50 PM
  #37
d2mini's Avatar
d2mini
Originally Posted by StevePDX
They're PIAA LP550 led white driving beam kit (item #: 05572). I added the yellow film.
Still have to get back to this project, but where did you get the yellow film? Pre-cut or you cut it yourself?
Old Oct 22, 2019 | 08:22 PM
  #38
dube53's Avatar
dube53
Have you ever thought to replace the bulbs in your fog lights? I replaced everything with LED. This has been a big improvement and I also drive isolated and mountain roads. I never liked the look of a Mini with the tiny driving lights.
Old Oct 23, 2019 | 08:52 AM
  #39
d2mini's Avatar
d2mini
Get out of this thread then.
oh, and my fogs and headlights are OEM led.
Old Oct 23, 2019 | 08:59 AM
  #40
StevePDX's Avatar
StevePDX
It's Oracal 8300 Transparent Brimstone Yellow. I had some laying around, so I cut some rounds and applied them myself.
Old Oct 23, 2019 | 11:16 AM
  #41
MVPeters's Avatar
MVPeters
[font=Arial]I think there's a little confusion over 'Watt' ratings - Watts measure electrical current consumption, not light output.
LED bulbs use roughly 1/3rd of the energy of incandescent bulbs. I say 'roughly' because LED performance varies drastically.
So as an incandescent baseline:
Parking, side marker & tail lights are around 10W
Directionals, brake & reverse lights are around 21W
Headlights, fog lights & driving lights are around 55W
DRL's are usually around 21W, often by dimming the headlight bulbs
& that's what's been fitted to just about every car for the last 40 years or so!
So LED equivalents are roughly:
Side etc - 3-5W
Directional etc - 7-10W
Headlights etc - 20-25W
So a 20W LED should provide about the same amount of light on the road as a 55W incandescent, it just uses 1/3rd of the current.
d2mini - for what you want to do - 'To Be Seen' - look for auxiliary fog-style lights with 7-10W LED bulbs.
These should be safe to use in all conditions, much like DRL's.
Just be cautious that some States limit forward-facing white lights to a maximum of 4, so low beams + fogs + the new ones could be a no-no (despite all the Jeeps!).[/font]
Old May 16, 2020 | 09:44 AM
  #42
d2mini's Avatar
d2mini
Finally got the lights from CravenSpeed and installed them!
Work great. Not too bright. Can turn on any time i want. Install was a cinch with really clear instructions. Perfect.
fishbulb
Jun 15, 2020 06:51 PM
mat2050159
May 23, 2013 08:06 AM
minicooper5232
Electrical
Aug 8, 2007 07:01 AM
rhasenohrl
Electrical
Dec 2, 2006 10:55 AM
rlfletch
Jul 18, 2005 01:03 PM
