Question on Needed Repair
Old Nov 21, 2018 | 03:54 PM
SeattleSilver's Avatar
SeattleSilver
Hi! The shop told me that my front brakes/pads were worn down to "less than 5 percent," which was one reason I was seeing the car-on-lift and "brake" warning lights on the dash (the other reasons were general service needed and a brake flush). Between the flush and front pads replacement I'm out over $800.
My question: why wouldn't I get a warning light sooner than 5 percent? Could the shop have been misrepresenting facts and status on pads and necessity of replacement?
Old Nov 21, 2018 | 05:43 PM
AZdsrt's Avatar
AZdsrt
How many miles? Brakes on these cars are good for about 40k miles. $800 for a brake fluid replacement and front brakes (including new rotors) sound about right for a dealer. I can't really comment on the 5%; when the wear sensor goes, it's time to replace them.
Old Nov 24, 2018 | 03:51 PM
wildwilly2004's Avatar
wildwilly2004
Wait...Front Pads and a flush is 800.00?? Are you kidding me.....that like 15 dollars in parts from Rock Auto....Hell, I'll do your next one for 400. lol
Old Nov 24, 2018 | 08:40 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
1) if you're asking for advice on maintenance/repairs, it really helps to include what year/model you have, and how many miles.
2) read the owners' manual to understand what those lights are telling you. Yes, there's a wear sensor that lets you know when your brake pads are worn and need replacing.
3) check with the NAM forum vendors to understand what parts should cost. Pads are a lot more than $15, you need to replace the sensor also, and there's some labor involved, but certainly not $800 even with a brake fluid flush. But it sounds like you had a general service done as well. Check itemized parts cost on the bill from the shop against the prices you find on line and you'll know whether to go back or not.
Old Nov 24, 2018 | 10:27 PM
MrGrumpy's Avatar
MrGrumpy
^ +1 This is good advice for any service that has you questioning whether or not you think you may have been taken advantage of.
Keep in mind though that there is labor involved as well. That’s usually where the large amount of the cost comes in. These cars are tight room-wise to work on, and one thing I have found out since buying a Mini is that there usually is more labor involved than on most cars.
For example, the oil filter housing is a common spot for an oil leak. I was quoted over $800 to replace the gaskets at a shop. The gaskets themselves cost about $40, the rest was all for labor. It’s kind of crazy in a funny-not funny way! The labor cost is based on the time required to do said job according to a flat-rate manual. So labor costs may vary some by mechanic but hours charged should be pretty much universal.
I refuse to pay that much for something I can do myself. If it’s something I’m comfortable with taking on.
Good luck and motor on
Old Nov 25, 2018 | 04:40 AM
wildwilly2004
1) Pads are a lot more than $15, .
Not for mine:
https://www.rockauto.com/en/catalog/...brake+pad,1684
Old Nov 25, 2018 | 12:03 PM
squawSkiBum
Moderator
^ Personally I wouldn't trust my car and maybe my life (or someone else's) to brake pads that cheap. But if you're ok with the performance you get...
Old Nov 25, 2018 | 12:24 PM
wildwilly2004
Let me tell you, I have had better luck with their stuff than I have with OEM parts. Rotors and brakes have been phenomenal. Always get the right part.....Been using them for many years on various models.
Old Nov 27, 2018 | 06:40 AM
Derek86's Avatar
Derek86
$350.
Even buying pads from the local auto store,the job would be less than $50.
Old Nov 27, 2018 | 06:51 AM
wildwilly2004
Originally Posted by Derek86
$350.
Even buying pads from the local auto store it would be less than $50.
This is true. I had an experience with Autozone Duralast Gold Brake pads.....their premier line, lifetime guarantee...… I was driving, residential area, not going fast, hit the brakes and my foot went to the floor. Thinking I popped a brake line, I limped home using only the ebrake. When I got home, I saw a brake pad hanging out of the caliper. I pulled both front wheels and all 4 pads in the front had separated from the backing. I have never seen anything like it. What are the odds that all 4 pads would separate? Those were my last autozone brakes.
alistaircookie
Sep 2, 2014 01:39 AM
rexracerx9
Dec 29, 2008 04:09 PM
hardtail15
Jun 7, 2008 07:39 AM
MJCMini
Suspension
25
Mar 10, 2007 09:59 PM
lounytoon
Southern California
Sep 28, 2003 07:59 AM
