Steering shaft U joint?
The joint near my rack and pinion is bad.
Does anyone know if an r53 shares the same lower steering shaft as an r56? Or atleast the same lower joint? There is an r56 in a local u pull it yard with the shaft still intact.
Better yet, does anyone know what size universal joint i need?
it just seems like a waste to swap out the entire shaft for 1 bad joint.
Suggest you go to www.RealOem.com and look the part numbers up. If you are close to the facelift, MY 2005, then be sure to have the month the car was built.
I dont think they are the same. They look similar but the ID might be different. I shot mine with some free all to buy some time and work it back and forth until it needs to be replaced.
https://www.northamericanmotoring.co...mc-w-pics.html
thanks for the replies guys.
No amount of lube is going to fix this haha. The joints is literally broke, not seized.
I will pull the shaft first chance I get and report my findings. Luckily this isn't my daily mode of transportation.
Yes, if its broke, its gone. No free all is going to fix that. haha
Let us know if they match up, from the pics on the site they look close, but MINI likes to change things up generation to generation. Good luck.
I'll pull the shaft from the junk yard regardless. The engine is already out of the car, and its right there in the open, and cheap part.
If that doesn't work. I have a very good industrial parts house locally that is very good with bearings and joints. Hoping they can match something up.
Again, please bear with me as I do my research...
No they aren't even close so you can't swap R56 to R53.
You need this complete lower shaft. I wouldn't get used as they have all been binding as they get worn.
https://www.waymotorworks.com/lower-...0-r52-r53.html
U joints
r56mini
Aug 23, 2007 07:58 PM
