First oil change on my used MINI, noticed something weird after..
Bought my 2011 MINI in Feb, with just under 70k miles, a little high I know, but I got such a good deal on it, I couldn't pass it up and service records show it has been well maintained.
It is about halfway between miles when I bought it and the scheduled maintenance miles it is telling me (about 7000 more). I decided that since I wasn't fully sure what oil was in it and like to know these things, I decided to do it myself so I know what is going on in there.
Up till this point, it has ran great - check oil every fill up, which is about every 2 weeks, and never had to add so it doesn't seem to be burning any at all.
I changed filter (OEM), and oil and used Castrol Syntec Euro 0W-30. I also went ahead and changed the air filter and cabin filter for good measure. All went well except that the forward 2 screws on the air filter housing won't tighten down for some reason, but the air box seems to be tight so no big deal.
I put in 4.4 Quarts per specs and then drove it about 7 minutes (up to 40 mph) to the gas station. Checked the oil with my Cravenspeed (HIGHLY recommended) dipstick and noticed 2 things that I hadn't noticed before but that may just be because I hadn't picked up on it but it may have always been like that. I don't know.
First, i did smell a little bit of oil burn and am assuming that may be due to some oil that may have dripped when removing the filter as I hadn't smelled burned oil before.
Second, as I had the dipstick out, something caught my eye - there was a little wafting smoke coming out of the dispstick tube. It was white, no foul smell really, and not that much at all. May not even be worth mentioning but since I noticed it and hadn't noticed it previously, I figured I would at least ask if this was normal or what it may be caused by.
Mike
Mike
Right after an oil change, I think what you saw is normal....
Oil drips when the filter is changed unless you are very careful....and you can get the hot oil smell...
Just be 100% sure that it's not leaking around the top of the housing...the o-ring on the top can sometimes slip off or tear when the cap is screwed in....
The steamy smoke...I'd guess it's just a bit of "burn off" from the oil getting hot the first time....which is some of the lighter components of it boiling off....
I would keep checking that oil daily until you know all is well.
I cannot explain this, I never knew why or what happened, but I've kept it as a learning lesson all these years.
Back in 2000 I was driving an '86 Celica. Made the switch to synthetic. Topped it off properly, put the car away, and drove to work the next morning. During the final 2-3 miles (35 total) of the commute, the car felt funny and smelled hot when I parked. Checked the oil and the stick was bone dry. Took a full filling of oil. Never happened again, but I figured the new synthetic lube was just so pure it burned right out or found a place to leak from.
Never happened again, and there wasn't a drop on the garage floor when I got home (yes, the first thing I checked was the drain plug) but from then on, anytime I switch a car to synthetic I check the oil like a madman until the second oil change
Oil Change
