Drill hole in exhaust tips?
Old Oct 17, 2012 | 08:17 AM
rdmini06's Avatar
rdmini06
This relates to the black soot residue on the Mini exhaust tips. Has anyone tried drilling drain holes in the bottom of the exhaust tips so the black goop will drain out the bottom?
Old Oct 17, 2012 | 10:51 AM
Porthos's Avatar
Porthos
Why? It won't work.
Old Oct 17, 2012 | 12:55 PM
rdmini06's Avatar
rdmini06
Originally Posted by Porthos
Why? It won't work.
Why won't it work?
Old Oct 17, 2012 | 01:41 PM
Tank251's Avatar
Tank251
Just a guess.
Why won't it work?
Mind you I know very little. But I am guessing that the black goop is really smoke soot from the exhuast and not a liquid so it won't drip. The soot builds up slowly. I may be way off base.
Old Oct 17, 2012 | 03:09 PM
Porthos's Avatar
Porthos
Why won't it work?
A better idea is just clean it. Get some Super Clean and then a green scotch bright and clean it. Works for me.
Old Oct 18, 2012 | 05:54 AM
rdmini06's Avatar
rdmini06
i do clean it. I just thought there might be a solution to keep from having to clean it.
You said drilling the holes won't work. You didn't answer my question "Why won't it work?"
Old Oct 18, 2012 | 06:02 AM
Porthos's Avatar
Porthos
Because it is soot not a fluid. So there would be no draining it.
Old Oct 18, 2012 | 07:34 AM
allgrainer's Avatar
allgrainer
I have noticed that the "soot" that blacks the lower portion of the exhaust tips comes from the condensation when I first start. The condensation carries the soot and it drips down causing the black on the chrome. If the soot was not a liquid or not carried by a liquid I would think the whole tip would black out. I use purple power and a scouring pad it comes right off as long as you clean regularly.
Old Oct 18, 2012 | 08:25 AM
Pure87's Avatar
Pure87
You can try, but i don't think it will work since the soot coats the entire exhaust opening. It might help in preventing the concentrated buildup of soot on the bottom of the opening, but you will still have to clean them. I usually just give it a wipe during the weekly wash, using nothing special, and it looks fine for a few days. I imagine if you wash it twice a week, the soot will never be more than slightly visible.
Old Oct 18, 2012 | 11:31 AM
rdmini06's Avatar
rdmini06
The water that condenses in the exhaust system mixes with soot and that's what's dripping out the exhaust tips leaving the black residue.
Old Oct 18, 2012 | 11:41 AM
yetti96's Avatar
yetti96
In my OEM tips there is a hold in the bottom already. I don't clean my tips as I don't mind the matte black finish of full soot...death to chrome.
purplehaze05mcs's Avatar
purplehaze05mcs
Exhaust Soot
Maybe that's why my jcw tip and my other mini's sport tip are originally colored black around the hole so you wont see it.
Old Oct 18, 2012 | 01:38 PM
rdmini06's Avatar
rdmini06
The exhaust tips aren't chrome, they're stainless steel.
Old Oct 18, 2012 | 02:56 PM
Capt_bj's Avatar
Capt_bj
the <new> hole exposes untreated metal
wanna guess how long it takes for rust to root?
Old Oct 18, 2012 | 04:23 PM
Porthos's Avatar
Porthos
+1
Old Oct 18, 2012 | 04:41 PM
JerseyminiMan's Avatar
JerseyminiMan
SS does not rust
Old Oct 18, 2012 | 05:34 PM
yetti96's Avatar
yetti96
I was referring to anything shiny. I think the pipes are SS, but what about the tips? What grade SS is it?
Originally Posted by JerseyminiMan
SS does not rust
Sure it does, it's not supposed to but depending or grade and quality it surely does rust, especially with built up carbon deposits and random iron particles captured on it.
Old Oct 18, 2012 | 06:42 PM
Firewire's Avatar
Firewire
Collinite Metal Wax works great too. It is made for marine use.
I've had the same bottle for 5 years I bet. You can get it at Amazon or Marine places.
Collinite Metal Wax 850 Collinite Metal Wax 850
Old Oct 19, 2012 | 05:18 AM
MarinePMI's Avatar
MarinePMI
I was just about to ask if anyone has tried Wheel Wax yet, as it is suppose to stand up to high temperatures...may have to try it this weekend and see...
Old Oct 20, 2012 | 04:50 PM
jbobp's Avatar
jbobp
I buffed the tips on my MINI with sandpaper and spray painted them with barbecue paint, which withstands the heat; a tip I got from terryg. Soot? What soot? It’s all black.
Old Oct 20, 2012 | 05:36 PM
Melangell's Avatar
Melangell
I just painted my new VIP exhaust tips with 1200 degree black engine paint. Problem solved.
Much like Jbobp.
sevin
Feb 1, 2016 11:30 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
davavd
Aug 25, 2015 10:08 AM
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
