Vibration from 30-40 mph
Old Oct 1, 2012 | 06:09 AM
enatal's Avatar
enatal
whole car vibrates where speed is from 30-40 mph
Old Oct 1, 2012 | 06:20 AM
ZippyNH's Avatar
ZippyNH
Have you switched rims or tires lately?
hit a big pothole?
Old Oct 1, 2012 | 06:53 AM
DarkenDioxen's Avatar
DarkenDioxen
Sounds like it could be a balancing issue. Usually if the vibration doesn't improve as you speed up it's alignment (or loose lugs).
a 10 -15 mph window of vibration points to a balance issue. Bang a pot hole or curb hard enough and toss a wheel weight and there you have it!
Old Oct 1, 2012 | 10:14 AM
enatal's Avatar
enatal
the only difference is that tires were emptied and re-filled with nitrogen-air mix. They had the same mix before.
i'll check the tires and rims anyway
thanks!
Old Oct 1, 2012 | 12:03 PM
ZippyNH's Avatar
ZippyNH
thanks!
...So the old air got stale, and you got new air? Just don't forget to fill your blinker-fluid tank!! JK on the last part, but could not resist!!
OK...OK...I'll give you the fact n2 filled tires hold PSI better and require less care to maintain PSI to get slightly better mpg
(now with built in tire PSI monitoring this is negated),........but mostly a up-charge at tire places to increase the average bill...a few folks who race MIGHT see a benefit.
But to get serious, if the tires were removed from the car to be filled, and the mounting surfaces not cleaned, that could be an issue, just like if the rims are aftermarket, and use hubcentric rings, one might have fallen off...
Safe to say the tires were rotated? if this was done without balancing...from rear to front, now you can feel it...before you did not...you MIGHT have a bent rim, or a wheel weight missing....
Good Luck! when this crap happens it is a pain, but remember, smile, and you can never be mad driving a MINI!! It is simply not allowed!!
Old Oct 1, 2012 | 12:23 PM
LethalR53's Avatar
LethalR53
I also get a vibration around those speeds. I have changed both my wheels and tires recently. Not sure what's causing it since I have exactly the same wheel and tire setup as the Stock cooper S 17" wheels and 205/45 tires :( I've had it balanced and aligned and still the vibration persists :( it goes smoothly at lower speeds tho :(
Old Oct 1, 2012 | 12:50 PM
LethalR53's Avatar
LethalR53
However I do have hubcentric rings. Could a crack in one of them cause vibration too ?
Old Oct 1, 2012 | 01:10 PM
AustinS's Avatar
AustinS
Sounds more like a power steering issue. You should check the fluid level.
Or...you could go to a good alignment shop and have them check it out.
Old Oct 1, 2012 | 01:14 PM
Klayfish's Avatar
Klayfish
Sounds like a missing wheel weight.
And I'd suggest ditching the whole nitrogen-air mix thing. Has no benefits, except to the person you're paying to do it.
Old Oct 9, 2012 | 10:31 AM
enatal's Avatar
enatal
Hello All
Problem Solved!
1. Wheels were disbalanced. Wheels balancec!
2. One rim was bent due to pothole. Wheel replaced!
Now runs better than before.
Thanks to everyone who contributed.
Filmy
15
Jun 6, 2023 06:27 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
minieater
Oct 28, 2015 02:15 PM
randeez
Oct 5, 2015 09:23 AM
gpwpat
Sep 15, 2015 11:58 AM
