Silly Brake Question
Old Jun 4, 2007 | 09:14 AM
pray4dirt's Avatar
pray4dirt
when you park your car what do you do?
place the car in
1. 1st gear
2. reverse
3. use hand brake
4. combination of hand brake and 1st gear/reverse?
and what do you do for these situations:
1. parked on inclines
2. parked in declines
3. parked on leveled streets
i get different advice from people and just want to know what is the correct way of parking for my r56. i don't want to cause greater wear to my clutch by doing the wrong thing. by the way i have a 6 speed.
thanks
Old Jun 4, 2007 | 09:18 AM
mauberley's Avatar
mauberley
1st gear + brake, regardless of slope.
Inclines with curb, front wheels away from curb.
Inclines without curb or declines, front wheels toward.
If I'm not mistaken, the majority of wear on the clutch comes from starting from a complete stop. I'm not aware that parking habits would be significant.
Old Jun 4, 2007 | 09:25 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
I park the car in 1st gear and use the handbrake at all times. If on an incline, I will turn the steering wheel in the direction that would make the car roll to the shoulder/curb if it were to drift. If there is an actual curb parallel to my spot, I will turn the steering wheel such that the front wheel will touch the curb when rolling donw the incline. If there is no curb, turn the wheel so the car will roll onto the side you are parked against instead, and not into the street.
Parking with the car in gear does not cause any wear of the clutch, nor the transmission. Leaving the car in gear but without setting the parking brake can allow the car to roll when on an incline, or pushed.
Old Jun 4, 2007 | 09:29 AM
Loony2N's Avatar
Loony2N
If you are parked facing downhill, you should but the manual in reverse gear.
Old Jun 4, 2007 | 09:33 AM
Yucca Patrol's Avatar
Yucca Patrol
Why?
Old Jun 4, 2007 | 09:40 AM
Loony2N's Avatar
Loony2N
because the car still can be moved in gear and it isn't easy to roll uphill.
Old Jun 4, 2007 | 12:51 PM
Greatbear's Avatar
Greatbear
Using 1st gear as a 'parking brake' is slightly more effective than reverse since in all manual transmissions the 1st gear ratio is slightly lower (higher numerically) than reverse. Working backwards through the wheels to the engine, more force would be needed to spin the engine over if left in 1 than R. Plus, keeping the car in 1st is a bit safer, since people tend to react better to sudden forward motion than backwards (think accidently sidestepping the clutch when starting the engine, etc).
When applying the parking brake, give it a nice sharp upward tug rather than a mild pull, I tend to lift the brake handle with about 20-30 pounds of force. When coming to a stop I often tug the e-brake to halt my motion once in the spot, I can feel the brake holding. I then shut the engine down and release the clutch with the trans in 1st.
If parking head-into a row of spots, a bit of security can be gained by parking with the wheels turned hard to one direction or another, this will frustrate a tow operator trying to take your car without authorization. It wont prevent it, but will extend the time needed.
Old Jun 4, 2007 | 12:58 PM
Loony2N's Avatar
Loony2N
Except in NYC, where they have big platter they just put under the car, lift the whole thing and pull it out sideways. I based my post re: reverse on what was in the driving manual I got when I was learning to drive (which was some time ago).
Old Jun 4, 2007 | 03:36 PM
pray4dirt's Avatar
pray4dirt
thanks for all the replay. i will use 1st gear and hand brake.
Old Jun 5, 2007 | 08:04 PM
dix's Avatar
dix
I park in first gear, use the hand brake and try to park wayyyyy back from any other cars!
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
tippin
Aug 5, 2015 08:43 AM
