General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
What class am I? (SCCA)
Old Sep 22, 2009 | 06:46 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
I am considering going to an Auto-X event this weekend, and need to know what class I am in order to register. The drop down has easily 50 options, so I need some help picking the right one.
I have a 2009 MCSC with the JCW Tuning Kit installed. No other mods done, performance or visual. What class would I be in?
Old Sep 22, 2009 | 07:35 PM
kansasbob98's Avatar
kansasbob98
It all depends on what club is putting on the event. Is it SCCA? If so from my previous experience ( haven't run in 5 years ) dealer or port installed options - your JCW tuning kit makes it a modified class car. Regular factory JCW production cars run BS in SCCA. Your best bet would be a "street tire class" or STX.
If you must put down something for online entry use BS. Once at the event some one should be able to help correctly class the car.
Good luck!
Old Sep 22, 2009 | 07:58 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
It is a SCCA sanctioned event.
Old Sep 22, 2009 | 09:31 PM
Some Guy's Avatar
Some Guy
The SCCA has a list here. http://cms.scca.com/documents/Solo_R...nufacturer.pdf
However they dont say anything about the 09's so it might be at the discretion of the event chair or something.
Old Sep 23, 2009 | 06:03 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Eek, according to that chart the 02-05 Cooper S with Tuning Kit isn't permitted. I hope its not the same for the 06+ with Tuning Kit.
Old Sep 23, 2009 | 08:58 AM
Dinosaur's Avatar
Dinosaur
That is stock category, and no it won't fit there, try STX http://cms.scca.com/documents/Solo_R...nufacturer.pdf
or you may fit in DSP http://cms.scca.com/documents/Solo_R...nufacturer.pdf
My region has a forum where you can ask what class you fit in with your equipment and those that know will let you know which one (SCCA has more classes than a dogs got flees). Sign up as STX and ask when you get there, changing class is not difficult.
Old Sep 25, 2009 | 08:06 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
After speaking with the coordinators they suggest that STX was likely to correct class for me, that will confirm that Sunday.
Old Sep 30, 2009 | 11:00 AM
Gromit801's Avatar
Gromit801
Jeremy, if is a factory JCW, you are currently in B-Stock. Like I am.
if the JCW kit was installed after the factory, you're in STX.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
devenh
General Discussion
Sep 28, 2015 07:10 PM
minimofo
Sep 20, 2015 05:17 PM
hsautocrosser
Sep 15, 2015 09:35 PM
Accessory Products
Sep 9, 2015 10:29 AM
