Where is the Purge valve on a JCW?
Where is the EVAP purge valve located on a 2009 JCW? I've tried to find it according to descriptions for other models...with no luck, and can't find a JCW specific thread on the purge valve.
Erik,
Thanks for the reply but, on my JCW Clubman, (Same as yours?!) the charcoal canister and the attached EVAP vacuum pump are located next to the right-rear wheel well and the purge valve (AKA fuel tank vent valve) is located somewheres unknown. On other MINI models it's located various places in the engine compartment. I can find the valve, for the JCW Clubbie, listed, on various vendor websites (Pelican parts, Penske parts, etc.) but not on any of their diagrams, not even RealOEM, so no clue as to its location. I have a persistent leak in my EVAP system and the vent valve is one of the suspect parts, but I can't check it if I can't find it. Guess I'll start tracing hoses.
Jon in SC
Jon in SC
* http://www.realoem.com/bmw/showparts...84&hg=16&fg=10
- Erik
Erik,
13537543285
I did find the diagram but still don't know where it is.
http://realoem.com/bmw/showparts.do?...=13&fg=15&hl=3
P0442 0x321C Tank EVAP or purge system leak
Yes...that unit is attached to the charcoal canister.
Jon
Do you have an accurate part number for the EVAP purge valve for a 2nd-Gen (R55 platform)?
What's the current fault code(s) from a MINI-specific scanner tell you?
Are you sure you're not getting confused with the Leak Detection Unit (DMTL) that pressurizes the fuel tank and evaporative system to monitor leaks?
Jon
13537543285
I physically see the right angle connection from line #5 near the firewall, above the rack-and-pinion of the steering system.
- Erik
Erik,
13537543285
Jon
13537543285
Jon
