Engine Failure Question for the Experts
Old Oct 12, 2011 | 05:09 PM
  #101
cmt52663's Avatar
cmt52663
just for semantic clarity!
dirt·bag (dûrtbg)
n. Slang
A filthy or vile person.
vile (vl)
adj. vil·er, vil·est
1. Loathsome; disgusting: vile language.
2. Unpleasant or objectionable: vile weather. See Synonyms at offensive.
3.
a. Contemptibly low in worth or account; second-rate.
b. Of mean or low condition.
4. Miserably poor and degrading; wretched: a vile existence.
5. Morally depraved; ignoble or wicked: a vile conspiracy.
filth·y (flth)
adj. filth·i·er, filth·i·est
1. Covered or smeared with filth; disgustingly dirty. See Synonyms at dirty.
2. Obscene; scatological.
3. Vile; nasty: a filthy traitor.
Old Oct 13, 2011 | 03:47 AM
  #102
quality_sound's Avatar
quality_sound
that was actually in the dictionary?? LMAO I love it!
Old Oct 13, 2011 | 02:55 PM
  #103
Island maser's Avatar
Island maser
Originally Posted by ACEkraut11
I am not so convinced. He has come and gone with his posts and remember, lawyers get paid by the HOUR....it could take months!
"The case has been settled and the car is being repaired."
Old Oct 13, 2011 | 03:00 PM
  #104
DneprDave's Avatar
DneprDave
Did you have to agree not to tell about the settlement?
What can you tell us? Did the warranty cover it after all?
Dave
Old Oct 13, 2011 | 03:29 PM
  #105
cop1406's Avatar
cop1406
Hmmmmm. Need more info. I'm thinking joint settlement. Island would have been more boastful if MINI was covering the entire bill, unless there is a gag order.
Old Oct 13, 2011 | 05:15 PM
  #106
cmt52663's Avatar
cmt52663
Good. I wish you better luck going forwards.
Cheers,
Charlie
Old Oct 13, 2011 | 05:46 PM
  #107
cccplus's Avatar
cccplus
congrats
Old Oct 13, 2011 | 06:21 PM
  #108
Neitherfanboy's Avatar
Neitherfanboy
Well, they say a good arbitration result is one where neither side is completely happy. I hope at least Island is happier than they are; best of luck to you, Island.
Old Oct 13, 2011 | 07:42 PM
  #109
turtle343's Avatar
turtle343
Glad to hear.
Old Oct 28, 2011 | 02:40 PM
  #110
Jakchef's Avatar
Jakchef
Ours lasted 5 years and 71k before it's engine blew up. Even with all scheduled maintanence and lots of repairs along the way.
Old Nov 20, 2013 | 09:07 AM
  #111
digolfa's Avatar
digolfa
Interesting posts. Being an ex machinist, working in dealers as a Service Advisor and manager, has anyone determined the exact failure? I mean a burnt piston is very different than valves contacting the piston. Justb/c one revs to 7k which I do repeatedly on my R56 JCW does not mean that caused the failure. These motors have a rep of burning pistons from being lean.
Old Nov 20, 2013 | 02:39 PM
  #112
1guru2's Avatar
1guru2
Also being an x-machinist, and motor head, you are right on. If a valve had contacted a piston it would have bent the valve, and you would know it right away. The thing that destroyed this engine was not valve float from too many RPM. It was detonation that probably burned a piston and scored a cylinder wall when it was being tracked. The thermostats on pre-2013 JCW's and MCS's as set by the ECU was 105C. As you state they also ran lean for mileage and emissions reasons. On the 2013 JCW's and GP2's the ecu sets the thermostat at 90C and leaves it there. Maybe BMW finally realized the cause of the burned piston problem. I don't know about 2013 MCS's thermostat settings. I have a 2011 R55 MCS that runs 105C steady state. Also have R56 JCW that runs 90C steady state. Both have JCW temp and rel torque gauges. When I checked into why the difference between the two vehicles is when I found the 2013 JCW and GP2 both run at 90C. Probably to avoid detonation under severe load. If anyone has a temp gauge of any kind on a 2013 MCS please post the steady state running coolant temp. Just curious!!
Old Nov 20, 2013 | 02:57 PM
  #113
jkapinos's Avatar
jkapinos
On a 2013 MCS R59. Normal highway is about 220 degrees. If you go into sport mode it is 185 degrees. If you really push it not in sport mode. It drop temps as if in sport mode.
Old Nov 20, 2013 | 04:38 PM
  #114
1guru2's Avatar
1guru2
Thanks for the info on the sport mode. I just had the JCW gauges put on my wife's R55 MCS last week. I had the gauges on my R56 JCW when I bought it new in March this year. So, I thought it unusual that the MCS ran so much hotter than my JCW. Yes, indeed the MCS cools off to 90C when you put it under load, but comes back to 105C in steady state running. I'll try the sport mode in the MCS. Thanks again!
Old Nov 21, 2013 | 07:42 AM
  #115
digolfa's Avatar
digolfa
The coolant temp is controlled by the DME. They do run at 220f normally which, historically speaking, is really quite hot. When one runs hard the DME does drop temps to 185f. Not sure if i agree with the sport mode affecting the DME controlled coolant temp as I have gauges, run in sport often incl at the track but on the freeway, in sport temp stays at 220f unless I start hammering it. I dynoed my ride 2 weeks ago and it was lean 14:1or so under load. These cars have a knock sensor so in theory they should not detonate. I never hear detonation but.....kinda loud in there under full throttle. Regardless, a proper tune should really help avoid burning piston an/or valve(s)
Old Nov 21, 2013 | 09:01 AM
  #116
1guru2's Avatar
1guru2
This all started with me when my wife's 2011 R55 MCS had a thermostat failure. The DME didn't get a reading from the thermo, and the temp gauge read 0. It gave the 1/2 power light. After a few starts it finally gave a reading of 60C, and the 1/2 power light went out. I took it to the dealer and they R&R,d the thermo and all was well again. I had just put gauges in the car a week before, so without them I wouldn't have had a clue what was going on.
Then I had a question of why my 2013 R56 JCW only ran at 90C or 195F and no hotter by a few degrees, even with an outside AT at 113F in the desert this summer. I know 2 people who have GP2's who tell me their cars also only run 90C. I have to think that BMW finally is realizing that detonation can be a problem in these 1.6L engines. So, it looks like a 2013 JCW is a rare car indeed. It is the only one with the N-18 engine, and a DME that only allows the coolant temp to run no more than 90C or 195 F.
I have noticed on long trips of 2K or more the R55 MCS auto gets about 2MPG better than the R56 JCW manual, so the A/F mixture must be richer overall on the JCW manual which would help with the detonation problem.
I agree also that the sport button doesn't change anything temp wise, as I tried it on both cars with no change in temp!
Old Nov 21, 2013 | 02:49 PM
  #117
jkapinos's Avatar
jkapinos
On a 2013 MCS the coolant temp will drop from 220 degrees to 185 degrees after hitting the sport button. I drive 140 miles a day. On the highway it's between 118 - 220 normally. After I get off the highway I always hit the sport button and it will quickly drop to 185 degrees. I have about 25,000 miles and a Scangauge II. I have seen this happen daily for more then a year. I stopped looking at engine temp. I monitor AFR, coolant temp, batt volt and boost.
Old Nov 21, 2013 | 04:47 PM
  #118
1guru2's Avatar
1guru2
I believe what you say. I'm happy to hear that the 2013 MCS's can be cooled off with the sport button. Maybe BMW/MINI are finally catching on that they may be damaging engines running them that hot. I do know that our 2011 R55 MCS temp is not affected by the sport button. The 2012 R55 MCS I had before I bought my 2013 JCW didn't either. Hopefully this is a change for the good in 2013 and will continue in coming years!
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
thebordella
Aug 31, 2015 01:37 PM
danraabe
Aug 18, 2015 09:32 AM
