New Mods - AccessPORT & JCW Intake w/ filter
Old Mar 16, 2011 | 07:23 PM
Dallas JCW's Avatar
Dallas JCW
sounds great - very fast - at least for me.
Old Mar 25, 2011 | 12:27 AM
sooper_cooper's Avatar
sooper_cooper
Did you upgrade from the stock JCW flat filter to the JCW cone filter?
Old Mar 27, 2011 | 05:43 PM
Dallas JCW's Avatar
Dallas JCW
Yes - I went from the stock flat panel to the JCW kit intake with the cone filter.
It took me about 30 minutes to install. Wish they'd just put this one on in the first place, but what do I know.
I'm just glad that they used the correct strut brace when I ordered my car. I'm told that there are two, and that one doesn't have enough clearance for the JCW intake. Mine had plenty, although I had to snake the intake in when I intalled it - I didn't have the tools to remove the strut bar.
Any way, don't know if there is any performance gain, but it sounds a bit beefier upfront (I think). The AccessPORT really gives the car some oomph.
Old Mar 27, 2011 | 10:53 PM
sooper_cooper
I was thinking of doing the same. I wonder if the cone filter provides more flow?
Where did you buy your intake from?
Do you live in Dallas? If so check out metroplexmini.org. Great site for local Mini enthusiasts.
Old Mar 28, 2011 | 03:19 AM
Dallas JCW's Avatar
Dallas JCW
I bought it from Sheri at MINI of Dallas. She ordered it and it came in within about 3 days. You have to order the replacement intake which just drops in in place of the factory one, and a rubber gasket.
Everything including tax was around $300 including the MM discount.
Old Mar 29, 2011 | 02:02 AM
ej827's Avatar
ej827
Post a picture up. I thought the R56 did not have a JCW intake upgrade??
Old Mar 29, 2011 | 05:18 PM
Dallas JCW's Avatar
Dallas JCW
The Factory JCW has the same intake as a Cooper S as far as I know - with the flat panel filter.
I replaced that stock intake, with the flat panel filter, with the dealer installed kit's JCW intake - which has the cone filter. The filter box itself is larger than the stock box.
I took this picture from Way Motor Works website where they sell the dealer intalled kit's JCW intake. You take off the top section of the stock box and replace it with the JCW intake top section along with a thick rubber gasket.
Attached Thumbnails New Mods - AccessPORT & JCW Intake w/ filter-wmw_parts_500-7.jpg
Old Mar 29, 2011 | 11:42 PM
flatlander_48's Avatar
flatlander_48
What are your thoughts on the AccessPORT so far?
Old Mar 30, 2011 | 09:11 AM
Island maser's Avatar
Island maser
What year and details on your car?
Old Mar 30, 2011 | 10:08 AM
Dallas JCW's Avatar
Dallas JCW
I've got a stock 2009 Astro Black JCW. All the packages, with factory NAV. I got it in July 2008.
The only things I've added are the MINI short antenna, the AccessPORT tune, the JCW intake from the dealer installed kit, and soon to add the stiffer Alta spring for the BOV.
The AP makes the car scream. Where I used to have hesitation from a standing start, the car gets moving quickly. The car pulls strong in every gear. It pushes me back into my seat now where prior to this I didn't get that sensation. After the BOV spring, I'm done with mods for a while.
This is my fourth MINI, having had a 2003, 2005, and 2006 MINI Cooper S. I'm going to be keeping this one for a while. Only have 15K miles on it at the moment.
Old Mar 30, 2011 | 10:34 AM
sooper_cooper
I definitely agree about the AccessPORT. I'm running the stage 3 tune and it's insane.
It pulls off the like like mad and down shifting at speed for a quick burst of passing power will have you pressed back into the seat.
I can't imagine driving my JCW without it at this point.
Old Mar 30, 2011 | 02:46 PM
Dallas JCW's Avatar
Dallas JCW
Do you have the aftermarket intercooler, exhaust, etc. for the Stage 3, or are you running the Stage 3 on a stock setup?
Just wondering since I'm running the Stage 1 92 octane map on mine, and only experimented with the Stage 1 92 octane linear map - which I didn't like as much as the regular Stage 1 map. I also continue to press my sport button on every ride, as I did before the AP. I like the tighter steering, and the car feels more responsive with it pressed, even with the AP.
Old Mar 30, 2011 | 03:58 PM
Grimnebulin's Avatar
Grimnebulin
With Stage 3, did you do any other upgrades like clutch/flywheel or transmission?
Old Mar 30, 2011 | 04:19 PM
sooper_cooper
I have a custom 2.5" Magnaflow exhaust with the stock downpipe and a Helix FMIC on the way. I kept the stock JCW intake and if I upgraded it I'd probably only go with the JCW cone filter like you did, unless I could get more power from a custom tune using another aftermarket CAI. I plan to upgrade the downpipe sometime in the future but I'm broke right now after all these mods...
I didn't like the linear maps either so I'm using the regular 92 octane maps. I've tried all three and each makes more power as you go up. I also press the sport button every time. It's habit now!
I need to buy the mod that puts it into sport mode automatically when the car is started.
I didn't upgrade the clutch or flywheel. The AP adds impressive power, especially the stage 3 map, but I don't think it's enough to overwhelm the stock clutch/flywheel. So far it grips fine.
I do have the NM charge pipes and the NM torque arm bushings, as well as coilovers with lower control arms and a thicker swaybar. The bushings and suspension upgrades REALLY cut down on torque steer. When I was running with the stock JCW suspension and nothing else, the first time I loaded the stage 3 map the power was so high that the torque steer really took me by surprise and the wheel nearly got away from me.
Hold on tight if you load it and decide to go WOT on takeoff!
I'd say the suspension/bushings were necessary more so than clutch upgrades. At the very least I'd recommend to buy the NM bushing for sure. Helps a lot to reduce torque steer.
I'm waiting to install the Helix intercooler and then the best way to get power for your car specifically is to have a custom tune done. Hopefully I can get that done this summer some time. The AP canned tunes are good but they can't compare to a custom tune.
Old Mar 31, 2011 | 08:40 AM
Grimnebulin
Thanks for the info!
It's pretty interesting that the stock car clutch/transmission can handle Stage 3.
Which bushing from NM did you get? On their website, I can do a search for bushings, but when I click to see info/buy, the bushing page I click on is coming up blank... If you have a link, that would be awesome.
Old Mar 31, 2011 | 09:02 AM
sooper_cooper
I got mine from Way Motor works:
http://www.waymotorworks.com/nm-engi...nt-insert.html
It's an easy install if you have a torque wrench and some jack stands. There's even a thread here somewhere that gives a step-by-step on how to do it with pictures.
It's a really good and cheap mod that makes a big difference in how your Mini will feel afterward.
Old Mar 31, 2011 | 09:23 AM
Grimnebulin
Perfect - thanks! Yeah - I have jack stands and a TQ wrench. This will be on my list of things to do. Now to find more stuff to mod!
Old Mar 31, 2011 | 09:58 PM
sooper_cooper
I can relate!
I think this will be my next mod: https://www.northamericanmotoring.co...heck-this.html
Looks pretty easy, not too expensive, and the results seem impressive.
Old Apr 26, 2011 | 11:53 AM
Grimnebulin
I can relate!
Did you do it?
If not, it looks like DoS just released a similar product.
https://www.northamericanmotoring.co...speed-com.html
Old Apr 26, 2011 | 01:13 PM
sooper_cooper
Did you do it?
I didn't end up doing it after reading through this thread:
https://www.northamericanmotoring.co...bov-valve.html
DoS is selling the Way Motor Works DV which isn't an upgrade for the JCW, unfortunately. I think I may try the Alta spring upgrade or the Forge that WMW sells:
http://www.waymotorworks.com/forge-blow-off-valve.html
The spring is a lot cheaper so I may go that route for now.
Old Apr 26, 2011 | 02:11 PM
bk_mini's Avatar
bk_mini
There is no thoughts... just get it.... I believe there is a return policy...
But I don't think I have heard anyone returned it..
Old Apr 26, 2011 | 02:27 PM
Grimnebulin
Ahhh....didn't realize that. Thanks for the edumacation!
sevin
May 2, 2026 06:11 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
The_Kid
Aug 28, 2015 04:50 AM
minipopkart
Aug 13, 2015 05:22 AM
