Buzz @ 3k RPM
Old Aug 20, 2008 | 09:48 AM
kingbc's Avatar
kingbc
Buzz @ 3k RPM
Anyone running into additional buzzing from the exhaust at ~3k? I seem to get it when the car is warm on decel. To me it sounds like a heatshield or something similar.
Thoughts? Experiences?
Old Aug 20, 2008 | 12:10 PM
Motor Head's Avatar
Motor Head
Not at 3K, but I'm getting a similar buzzing sound when engaging the clutch briskly from startup.
Old Aug 20, 2008 | 12:43 PM
MINIspud's Avatar
MINIspud
have you checked the red plastic piece on top of the tach?
It is the spot that would blink red if you have the alarm installed.
Mine was buzzing and then i reached up and put my hand over the small plastic there. It has just enough room to slide a bit. I havnt figured out how to keep it locked in place. If i hold it, no more buzzing.
Old Aug 21, 2008 | 10:00 PM
Danyes's Avatar
Danyes
i'm getting a real high pitch buzz/rattle from my driver side lock button, or what ever you call that thing, i think it is touching the mount and causing the noise, real annoying since it is right by my ear.
Old Nov 16, 2011 | 09:12 AM
Wizeguy9999's Avatar
Wizeguy9999
I'm having the exact same issue. It's just a hair below 3000 rpms. If I rev up to let's say 4000 rpms, and let the car slow itself down to 2500, around 2900 it starts buzzing, and stops around 2600 rpms.
Did you ever figure out what it is? I'm still under warranty for a few months so I would like to get it fixed.
Old Nov 16, 2011 | 01:08 PM
Drobinson1692's Avatar
Drobinson1692
it must just be a perfect harmonic coming from the vibrations at that rpm. With the stock exhausts on JCW, it would not be suprising since you all report this. I actually get the buzz on acceleration, not engine braking.
Old Nov 16, 2011 | 01:46 PM
kingbc's Avatar
kingbc
My issue turned out being a piece of a band clamp that had managed to get wedged in between the transmission and the subframe. It fell out when I installed my torque arm insert. Problem solved.
Old Dec 3, 2011 | 03:39 PM
default's Avatar
default
I get this sometimes during songs when the stereo is turned up
If lock the door, it goes away
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Mini ni
Sep 24, 2015 05:42 AM
mtwaddle
Sep 13, 2015 08:10 PM
Sep 2, 2015 11:15 AM
