F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 Lock confirmation beep too loud
Old 08-20-2018, 09:11 AM
RobbC2's Avatar
RobbC2
RobbC2 is offline
Is there an easy way to lower the volume of the confirmation beep you get when locking or unlocking the Countryman? Or removing the sound entirely? I can't find a command in Vehicle Settings. I'm fine with just the lights flashing. The beep is ridiculously loud. Thanks!
Old 08-20-2018, 01:48 PM
jrodri7's Avatar
jrodri7
jrodri7 is offline
I thought there was an option to uncheck, under Doors I believe that states acoustical sound on lock/unlock?
RobbC2 (08-21-2018)
Old 08-20-2018, 03:49 PM
MIminiclubman's Avatar
MIminiclubman
MIminiclubman is offline
It is easy. Go to settings, doors and keys. Uncheck acoustic signal. I had to turn off after software update at the dealer two weeks ago.
Ther era is no sound level in the menu but maybe you could code that.
RobbC2 (08-21-2018)
Old 08-21-2018, 10:16 AM
RobbC2's Avatar
RobbC2
RobbC2 is offline
Thanks so much, everyone. I found the command. I hadn't scrolled far enough down on the Settings. Thanks for the help.
Old 08-22-2018, 07:31 AM
MrFunk's Avatar
MrFunk
MrFunk is offline
It's obnoxiously loud. I turned it off but my wife likes the beep for some reason. I tried to code it to a lower level but it didn't work.
Old 08-22-2018, 12:59 PM
jrodri7's Avatar
jrodri7
jrodri7 is offline
It is loud and i think louder than on a BMW that has the same horn in a similar location. Maybe it could be the difference in the wheel well liner material? Or the thickness of the steel body panel? Perhaps removing the wheel arch and applying some sort of acoustical material or some type of noise isolating foam in the area may deaden the sound of the horn. Or wrapping the horn in some sort of material.
Just a thought I had. I have an X1 and the sound of the chirp is definitely louder than on my old MINI.
Old 08-22-2018, 01:13 PM
MrFunk's Avatar
MrFunk
MrFunk is offline
Well - you want it to be loud if someone breaks into the car. If it were my car that I drove daily I'd just turn off the confirmation beep.
Old 02-24-2019, 08:43 PM
bluonyx's Avatar
bluonyx
bluonyx is offline
Bringing back an old thread, so where is the speaker located exactly?
On my old car, I was able to wrap some foam around the speaker so it deadened the chirp just enough to not make it so annoying, I'm sure it could be done again on the my CM. Just don't know where the darn speaker is located.
Old 11-21-2019, 08:42 AM
Michelle Monday's Avatar
Michelle Monday
Michelle Monday is offline
Can someone post a pic of where you turn the alarm on in the settings? I have gone into my settings and thought I turned it on but when I lock the doors it still does not chime/beep. I like having the feature on so that I know the alarm is armed and so that I don't have to listen for my doors to lock. It's also nice when you have to locate your vehicle in a parking lot.
Also, I read that you could active your alarm by holding the back gate open button for an extended period of time but that doesn't seem to work either.
pgifford
03-30-2006 07:50 PM
muppetmandan
08-03-2005 12:06 AM
neilgj
Electrical
06-06-2005 06:50 PM
StingerD
25
05-11-2004 08:36 PM
Quick Reply: F60 Lock confirmation beep too loud
