Electrical Road Runner (Beep Beep) Horn
Roadrunner (Beep Beep) Horn
I am toying with the idea of purchasing one those "beep beep" horns to replace the soulless, personality-free one that comes as standard equipment with the MINI.
(http://www.jcwhitney.com/webapp/wcs/...atalogId=10101)
I was curious if anyone has one of these and installed it in place of the stock horn. Care you share your experience and process? Is it difficult? Did you get 2 of them (I understand that there are 2 stock horns one on the left and one of the right) ? Any help would be appreciated. Thanks.
(I did a search and didn't find anything on NAM or MINI2)
Originally Posted by neilgj
...horns to replace the soulless, personality-free one that comes as standard equipment with the MINI.
If anything, I would put an air horn on the Mini. For safety, I am glad the stock Mini horn is LOUD! Saving my soul... thank you personality-free Mini horn!
Originally Posted by minimonkey
Personally I like the soulless, personality-free Mini horn... because it's LOUD!
but the horn I was looking at claims to be 133dB which is typically characterized as sound louder than a jet engine about 100 feet away and having the possibility of inflicting pain at closer distances.
I have the road runner installed....but here is a good thread for info. I have one installed....but also kept the stock one for when i really need it. I use the road runner to let pedestrians know they can pass and for honking at my buddies when they are walking around campus and i pass by.
sometimes someone else searching helps
https://www.northamericanmotoring.co...ht=road+runner
There are indeed 2 horns. They are easily accessible by reaching down into the opening in the front of the wheel wells...
133db is certainly loud! You also might want to check-out a forklift horn as they also have that beep beep sound. I might do the same...
EDIT - forklight horns are around 100db apparently, so the one you referenced certainly is louder...
I'm going to hijack my own thread now...
Anyone familiar with this PIAA horn:
http://www.eautoworks.com/html/ORD-1-1-1-32230.cfm
Looks like a drop in replacement for the stock horn. Is it? How does it sound? Thanks for your opinions and viewpoints.
FIAMM makes a nice air horn setup thats the same as the one that MOSS offer, but at the small sum of about 19 dollars to buy, you need to make up brackets and tap into the horn wiring. its an easy install and it gets looks everywhere i go.
135db with the hood open, slightly lower closed because of the mounting position.
R50/53 More supercharger hulabaloo
one73ronin
23
Sep 22, 2015 09:56 AM
Sep 22, 2015 07:31 AM
