F55/F56 DRL stopped working in one headlight
Old Aug 24, 2024 | 03:44 AM
asdfasdf128's Avatar
asdfasdf128
Hey guys, the wife has an F55 (2021 Cooper S; 4 door) and i noticed yesterday that one of her DRL headlight 'rings' wasn't on. I tried searching for answers but just got articles/videos on headlight upgrades. Thoughts on where to start first? I usually do research before jumping in. Thanks!
Old Aug 24, 2024 | 02:00 PM
RichsMINI's Avatar
RichsMINI
Hi @asdfasdf128 you are correct, there is not a lot of information out there.
I’m wondering if the plug for the DRL/turn signal module became loose/disconnected 🤔
Below is the thread for the yellow DRL LED module upgrade with the installation video. In the video you can see the cable in order to further troubleshoot.
https://www.northamericanmotoring.co...ring-swap.html
If the LED module failed and needs to be replaced below is the link to Seattle MINI’s online parts catalog and the module is number two.
- Please contact them with your VIN to confirm 100% compatibility.
https://parts.seattlemini.com/a/MINI...D/63_1960.html
Good luck, keep us posted and motor on -Rich
Old Aug 25, 2024 | 03:10 PM
asdfasdf128
Thanks for the leads Rich!
I took a look at the light today and the headlight with the issue is dimly lighting up the halo. I didn't have time to disassemble the heat shield to look at the innards of the light.
Old Jan 22, 2025 | 07:43 PM
asdfasdf128
Update:
The PNs for the led DRL assembly is:
Led Unit - Mini (63-11-8-737-591)
Led Unit - Mini (63-11-8-737-592)
You can also buy the DRL pcbs from AliExpress. I bought a set for $31. No affiliation with the seller, just sharing a link so people are able to get an idea.
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Old Feb 15, 2025 | 07:35 PM
asdfasdf128
The AliExpress DRL pcb was no good- it's been around 2 weeks and it's back to being dim
Old Feb 17, 2025 | 11:11 AM
https://www.ecstuning.com/Search/Sit...-11-8-737-591/
and
https://www.ecstuning.com/Search/Sit...h/63118737592/
I will reach out to Valeo whom make its, my guess is they never released them into aftersales, thus only MINI.
Old Feb 18, 2025 | 04:50 AM
asdfasdf128
Thanks! I'm trying to avoid paying for the full assembly since it's just the pcb that's gone bad. I tried searching for the part number printed on the pcb, but didn't have any luck. Here's a picture of the oem pcb that crapped out on me, just in case you have more luck with valeo
Old Feb 18, 2025 | 06:04 AM
Yea, valeo has a bunch of part numbers and they dont release them into aftersales ever, its just how they do business. OEM contracts come first.
I have reached out to them to see what they can find. Otherwise IND has those chips in yellow. https://www.ecstuning.com/b-ind-part...-f5x-ydrl~idd/
Jonandystokes
Jun 16, 2014 07:20 AM
stt816
May 14, 2011 07:13 PM
MGCMAN
Detailing 101
30
Jan 3, 2007 05:44 PM
dcsmd007
Feb 10, 2004 10:09 PM
