Plastidip headlight ring
Old Jun 15, 2014 | 02:33 PM
Jonandystokes's Avatar
Jonandystokes
Hey guys so I am thinking of plasti dipping my headlight rings.. I have the Mini Cooper r50 2002 plate and taking the rings off seems a bit of a ball ache I have no tools to take the headlights out to then remove the rings, if anyone can suggest a more simple way I will. But my plan is to plastidip the rings, do I need to try and mask the headlight lamp itself or shall I just simply spray over the whole headlight and then try and peak off the excess plastidip on the lamp and leave the rings? Thanks
Old Jun 15, 2014 | 02:50 PM
buzzsaw's Avatar
buzzsaw
Mask the rings only. That eliminates breakin the clips. Worked for me - twice. Good luck.
Old Jun 15, 2014 | 02:53 PM
Jonandystokes
I am spraying the rings did you mean mask the headlight?
Old Jun 15, 2014 | 03:03 PM
Jonandystokes
Hi I am spraying the rings did you mean mask the headlight?
Old Jun 15, 2014 | 03:04 PM
Jonandystokes
Has anyone actually sprayed all of the headlight as well as the rings
Old Jun 15, 2014 | 05:49 PM
grueinthebox's Avatar
grueinthebox
I'd probably mask a few cm from the ring on either side, making sure to mask a wide area of the bonnet, bumper, etc. Plastidip peels off easy in sheets, but if you get fine over spray around you'll probably end up using a clay bar to get it all off. Not masking too closely will allow you to peel around the ring when the plastidip is still not completely dry and if done correctly it'll tear off at the ring and leave a nice edge.
Old Jun 16, 2014 | 06:54 AM
buzzsaw's Avatar
buzzsaw
I masked everything around the rings including the headlight. It's the easiest method without breaking anything during a ring removal. Being **** masking the area between the headlight/fender and the ring will pay off in appearance.
Old Jun 16, 2014 | 07:09 AM
dosomething's Avatar
dosomething
Cover the headlights and be patient, slowly and surely you will love it. Good luck.
Old Jun 16, 2014 | 07:20 AM
Trizzz's Avatar
Trizzz
I did it once, but you are better to just mask it, otherwise your just waisting plastidip because you will want to put the same number of coats over your headlights for an easy removal
elverado
Jan 18, 2022 02:51 AM
Kevdog
Electrical
17
Jun 4, 2016 02:20 PM
pkrysR56
Sep 19, 2015 07:58 AM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
tylewis
Sep 6, 2015 07:36 PM
