F55/F56 brake caliper piston spreader
Old Dec 21, 2022 | 04:32 AM
Stu-mon's Avatar
Stu-mon
While I'm ordering a spark plug socket thought I'd go ahead & order a piston spreader for brake calipers to. what is the actual term for this tool ? Thanx
Old Dec 21, 2022 | 06:19 AM
RichsMINI's Avatar
RichsMINI
Hi Stu, the term you’re looking for is “retracting” and @ECSTuning sells the multi-piece one from Schwaben and it’s currently on sale.
https://www.ecstuning.com/b-schwaben...ces/pbk-11pcs/
I don’t own it however, it has good reviews, great price point and works on multiple makes/models.
-Rich
Old Dec 21, 2022 | 06:32 AM
Stu-mon's Avatar
Stu-mon
I seem to be having a real problem with ECS Tuning. every time I try to get in I get 403 FORBIDDEN WTF ?
Old Dec 21, 2022 | 06:48 AM
RichsMINI's Avatar
RichsMINI
Contact them and give them the heads-up on their website error (330) 331-2003.
If you do place an order for the kit the information is:
: MFG# PBK-11PCS
: ECS# ES#9747
: $42.36 on sale from $52.95 (20% off)
Old Dec 21, 2022 | 08:15 AM
cjv2's Avatar
cjv2
I can get to that product page now. Might be worth a retry.
Separately, one can "rent" a kit like this from places like Advance Auto Parts and O'Reilly Auto Parts. I have "rent" in quotes because the way the process works is they charge the price of purchasing it to a CC, and when you bring it back, they refund the full amount. If you don't bring it back before expiry of the rental period you are presumed to have purchased it and can't bring it back as part of the "rental" arrangement. I think O'Reilly has something like a 48 hour rental period, but Advance Auto is longer, or at least that is the case at each of their stores near me.
Old Dec 21, 2022 | 08:47 AM
RockC's Avatar
RockC
When I did the brakes on various cars I just used a good size screw driver to pry the pad (and force the piston) away from the rotor. Didn't try to rush this but it only took a moment or two. I was careful and neither the rotor or pads were damaged. Not that it made any difference anyhow since both were being replaced.
You want to make sure the brake fluid reservoir level is not too full so as you push the pistons back into the calipers the brake fluid reservoir doesn't overflow. 'course, no matter which way to spread apart the pistons this is a concern.
Old Dec 21, 2022 | 09:30 AM
TVPostSound's Avatar
TVPostSound
Not on the rears of these cars!!!!
Old Dec 21, 2022 | 09:44 AM
TVPostSound
I have one of these, for the rears,$9!!
Amazon Amazon
Stu-mon was close, on the fronts, they call the tool a pad spreader!!
Old Dec 24, 2022 | 05:57 AM
Stu-mon's Avatar
Stu-mon
is there a difference in front & rear pad spreaders ?
Old Dec 24, 2022 | 06:56 AM
RockC's Avatar
RockC
Having a hard time imagining how a screwdriver wouldn't work but I admit I never did the brakes on my MINI.
Old Dec 24, 2022 | 08:52 AM
TVPostSound
Rear pads have parking brake lever.
the lever use a screw though the piston to lock the piston against the rotor.
Old Dec 24, 2022 | 10:08 AM
TVPostSound
Old Dec 24, 2022 | 05:36 PM
ironhead3fan's Avatar
ironhead3fan
Likely your VPN. When I disable the VPN and refresh the page, it’s all there. Hope this helps.
AzBluesman1962
Suspension
Aug 5, 2018 06:03 PM
RudeJoe
Tires, Wheels, & Brakes
Mar 27, 2017 09:17 AM
muidaq
R60/R61 Stock Problems/Issues
Aug 17, 2014 03:08 PM
sprp85
Sep 20, 2008 09:43 AM
billblegen
Jan 9, 2007 04:31 PM
